Question about Maytag Dryers
I have Dryer model LDG5005AAE and it recently quit drying the clothes adequately. I thought this was due to a vent plugged with lint as it has been in the past but the vent is clear. The dryer begins with hot air, as the air coming out the back vent is hot initially, but after about 5 minutes, the air cools down and the clothes do not dry. What is the problem? What part do I need to fix this? and How do I fix the problem myself . . . what panel needs to be removed, where is the part located . . . as I do not have the original paperwork. Thanks for your help.
catriver
  • 878 Answers
SOURCE: Whirlpool GEW9200LQ0 Gas Dryer
Andeb, 90% of the time long dry times are caused by blocked vents. If you are sure that this is not the case there are a couple of things to check. First check the sensor; press the more time button and less time button 4 times until 88 shows in the display.(more time,less time, more time, less time). Open the door and you will hear a beep and a see a code. On the inside just below the vent screen is the moisture sensor. Moisten your finger and lay it across the sensor strips covering both. If you hear a beep, the sensor is good. Sometimes they build up with fabric softner and need to be sanded lightly. Another issue might be the burner coils. Remove the bottom panel and check to see that the burner is igniting and remaining lit. Sometimes these coils become week and will not sustain the flame. I will attach a diagram, look at number 13 and 14 on the picture. These are the coils. Catriver..post back.
Posted on Sep 18, 2006
SOURCE: gas dryer/ whirlpool
Hi my Whirlpool dryer is not generating any heat and makes a
grind like noise then goes away after a min. model# LGR4634EQ3
Type # 121-00 anyhelp please thanks
Brian
Posted on Apr 16, 2008
  • 67 Answers
SOURCE: whirlpool dryer wed5700sw
you need a dryer vent brush first,bought at home depot cheap,and clean the entire vent to the house,then clean where the vent hooks up to the machine,if your filter is where your door is pull out the filter and stick the brush in there and pull out lint,also use your vacume,remember you let some lint out when you let the hose blow out but theres a lot more there to clean,and also unplug your machine as you do this,if this helps please give me a fix ya vote
Posted on Jul 14, 2008
danromarris
  • 101 Answers
SOURCE: elec. Whirlpool dryer shuts off before clothes are dry, unplug to
I doubt it is your motor that is causing the problem. It's always nice when someone says that it is the most expensive part to fix and that is the only solution. It's an electric dryer and there are tons of things that could be causing the issue for you. It sounds like the problem is probably the thermostat. What this does is shuts off the dryer if the heat is getting to high in the dryer. It is a safety feature to prevent it from catching on fire. It is a easy and cheap fix. The thermostat is located usually somewhere near the heating element housing and only costs around 20 dollars at any appliance repair shop. There is a wire diagram located behind the backing of your control panel. Just remove the few screws and take off the housing. It will help you locate the thermostat. If the motor was the problem your dryer wouldn't shut off the way it is. The thermostat is just shutting it down for safety and that is why you need to keep unplugging it to reset it. Change it out and it should work just fine for you. If you have any other questions let me know and good luck to you.
Posted on Jan 22, 2009
  • 15 Answers
SOURCE: Dryer air heats up but does not dry the clothes. Just replaced the timer but did not fix the problem. Air vents are cleared.
One of two possiblities:
1. Dryer vent is blocked - check the air coming through the outside vent
2. Blower Fan is clogged - remove the lower front panel and clean out the fan wheel
Posted on Apr 30, 2009
My 1993 Maytag Clothes Dryer heats up, turns but does not dry the clothes unless I place an absorbent towel in with the items. It sweats water from the bottom of the dryer. What is going on?
To dry clothes, we need 2 things:
1-heat to evaporate the water from the clothing
2- adequate air flow to exhaust the moist air, thereby drying them.
Your heat seems to work.....if you stop the dryer mid-cycle, the clothes should be hot.
It sounds to me like you have a lack of air flow through the dryer. If you can get to the exhaust vent grill outside, then see if you get a large volume of air coming out of it. If not, then look for the louvers stuck closed on your outside grill, or any kind of blockage in your ductwork.
Perhaps undo the vent at the back of the dryer TEMPORARILY
Mar 20, 2013 | Maytag Dryers
Takes longer to dry clothes
Most of the time when your dryer is taking longer and longer to dry the clothes it is due to a clogged dryer vent. Just take the vent off and clean it. If the dryer cannot vent it cannot circulate the air inside the dryer
Jul 15, 2011 | Amana Maytag Dryer Lint Filter Screen...
I bought the fridgedaire dryer in 2005 and it has to run 3 times for ~40 min each to get the clothes dry. At first I thought it was from the # of turns prior to vent access in my apt (3 elbows and 30 ft...
due to the issue you had in your old home this is what id look for,,,,lint is bilt up in your unit remove the filter and use a dryer brush to clean lint as best you can,,,,,,second remove the vent hose from the back of dryer then with vent OFF try a load to dry if it drys in one setting then you have deturmind the dryer is ok but the vent hose is bad,,finally a bad thermostate or broken heater coil may be the issue and wold needservice,,,try the free stuff first thoe and good luckwww.myabcspace.com/washerwizzards
May 17, 2010 | Dryers
Cloths take way too long to dry. Heat is working in dryer. Timer works, counts down from 60 min, buttheremo drying timer takes way too long.
You will need to check the dryer venting system for a restriction. If there is a restriciton in the venting system the dryer will get hot but the clothes will stay wet due to the moisture never leaves the dryer. First check the air flow at the vent exit located outside. Verify that there is plenty of airflow. Make sure the vent screen is not plugged. Then remove the screen and visually inspect for excessive lint. Then go inside and check the moisture vent hose behind the dryer. Verify that the vent hose is not kinked or restricted. Then remove the hose and clear out any excessive lint. Then check the vent opening at the back of the dryer for any excessive lint build-up. There is a vent cleaning kit that you can purchase from any home improvement store that you can use to clean out the venting system also. When you are done airflow should be good and clothes should properly dry.
Jan 22, 2010 | Maytag Dryers
Moisture inside dryer door when clothes are drying. Model number DBXR463ED2WW
If you are experiencing moisture inside the dryer drum, then you have a clog somewhere. A dryer needs proper air flow in order to dry efficiently. If you have not had your dryer exhaust vent ducting checked anytime recently, now might be a good time to do so.
HOW TO DETERMINE IF YOU HAVE A DRYER CLOG:
Remove the dryer exhaust vent hose from the back of the dryer and attempt to dry a load of clothes as you normally would. The air escaping the back of the dryer should be forceful and warm (about 140 degrees F).
If the air flow is normal and the clothes dry properly, you need to check the ventilation from the point where it leaves the dryer, to where it exits your home. Check for kinks, sags or significant bends in the vent ducting that may be causing choke points where lint can accumulate. In addition, it is strongl;y recommended that you use the semi-rigid aluminum ducting as it resists crushing and is heat resistant.
If the air flow is weak, then you have a clog INTERNAL to the dryer. The lint screens do not catch everything. Some lint, along with moist air from your clothes gets exhausted through the blower fan housing and out through the ducting. This is normal. Lint can accumulate over time, however. If allowed to restrict the air flow, the moist air cannot escape and tends to permiate the lint with moisture. Once the lint becomes moist, it sticks inside the ducting and collects more lint to the point where it starts to restrict air flow and reduce the dryer efficiency. It is highly recommended that you check your dryer blower fan housing and internal ducting about once per season to prevent this.
If gone unchecked, the dryer will actually overheat to the point of failure. Accumulations of lint is also a major fire hazard. The majority of the dryer failures I have repaired were caused by poorly installed, kinked, or clogged dryer ventilation.
If you have any questions, please let me know. I hope you find this information helpful.
Jul 28, 2009 | Dryers
Dryer is taking several cycles to dry clothes.
Very common problem. You need to call a duct cleaning company and tell them to clean your dryer vent. Rule-of-thumb: dryer vents should be cleaned every couple of years to prevent them from being clogged with lint and causing lint fires. This is definitely your problem. Good luck :)
p.s. one way to verify a clogged vent is to go outside where the vent exits the house and feel the air-flow. should have adequate air-flow.
Jul 13, 2009 | Amana NGD7200TW Gas Dryer
Dryer taking too long to dry clothes
Hello :)
Good luck :)
Apr 03, 2009 | GE Profile DPSB620ECWW Electric Dryer
Clothes take a long time to dry
Good luck :)
Mar 27, 2009 | Whirlpool LER7646J Dryer
I think The dryer takes very long time to dry clothes
Good luck :)
Feb 24, 2009 | Amana NED7200TW Electric Dryer
Kenmore Elite Heavy Duty Dryer 11063012101 Takes Forever to Dry
I think your vent has lint in the line between the wall and the outside of your house not allowing the moisture to get out
FIX
1 when the dryer is running go outside and observe the vent to see if hot air is coming out
2 Turn dryer off, disconnect electric from wall
3 pull dryer out from wall
4 take a nut driver or screw and remove the clamp that attaches the flex vent pipe to the wall
4 Also remove the flex pipe from the dryer
5 Inspect inside vent connection inside dryer for any trapped lint
6 inspect inside flex line for any lint
7 Look inside wall vent for lint you can also reach in with your hand to feel for lint
8 If you have a leaf blower or can borrow one(electric is best) from your neighbor put the snout of the blower into the vent going into the wall seal the area between the snout and the vent pipe at the wall ( i use duct tape you can use wash clothes rags etc
9 start blower and blow any lint in the line out through outside THIS WILL CLEAR THE LINT
10 Reattach the flex to the wall vent and dryer , plug in. run a load and you should be back in business
Good Luck
Jan 04, 2009 | Kenmore 63012 Electric Dryer
Dryers Logo
116 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
