Heating & Cooling Logo
Posted on Feb 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I replaced the batteries in my wireless honeywell Cm61ng thermostat but it doenst' seem to be working with the unit next to the boiler. i think it may need pairing / re-programming. how do i go about doing this?
vance jones
Level 2:
Scholar:
  • Expert 120 Answers
  • Posted on Feb 02, 2011
vance jones
Expert
Level 2:
Scholar:
Answers
120
Questions
0
Helped
43350
Points
251
Correct signal does not seem to be sent from the controler to the boiler,either CH comes on or HW but not necessarily when they are supposed to. Boiler engineers have been out twice and both times advise...
we had one of these and found out the battery inside had failed. the battery is none replaceable. did try to replace it but it lost its memory and was only good as a switch. think when the battery fails it loses it memory and things start going wrong. so would say change it. now thinking on it should of changed the battery why having the old one on and taken the old one off after installing the new one.
1helpful
Failure of my Honeywell CM61ng wireless thermostat. Replacement advice
Probably not. There are replacement models available.
The T6661B programmable room thermostat is also known as CM61.
CM61 1 day wireless programmable thermostat is replaced by CM921.
CM61 1 day wired programmable thermostat is replaced by CM901.
Replaced amp now the honeywell just flashes and the boiler is switched off
If the power to the boiler is off, and you have a power stealing thermostat (tstat with a common), there may be battery backup. In which case, the thermostat is flashing because it is on battery backup. Not sure what you mean by replaced amp now.
Honeywell cm61ng binding with relay box issue
Make sure all the pins line up, and your thermostat wire is not causing the binding.
Honeywell visionpro
Um...., you changed the controller and it worked, then put the old one back and it doesn't work >> replace controller!
2helpful
2answers
I have a honeywell cm927 control unit, and the red light on the receiver keeps flashing. i can manually turn the boiler on and off at the HC6ONG receiver. i've tried the faqs in the manual but to no joy....
The red flashing light means that there is an issues with the RF comms between control unit and receiver. You can reset by switching the boiler off and back on and then re-sending the temperature signal. You need to check batteries in you thermostat and also the position as the signal could be interfered with or it may be too far away from the receiver.
39helpful
4answers
Honeywell - cm61ng- Keeps going on and off all night
Instructions on how to turn off your optimum start:-
Turn off ‘Optimum Start’
Step 1 Put the thermostat in the OFF position.
Step 2 Press 3 buttons together (at the same time) which are the INFORMATION BUTTON (i) and PROGRAM BUTTONS 3 & 4.
This will show a code of ICL 1 – now let go of the buttons.
Step 3 Press PROGRAM BUTTON 2.
This will now show a code of 30t 1
Step 4 Press the + BUTTON (on the left of the display), tap through until you reach 15 OP 1
Step 5 With the TEMPERATURE DOWN BUTTON; change the 01 to a FLASHING 0. Confirm the FLASHING 0 with the INFORMATION BUTTON ( i ). The 0 will now be static.
Step 6 Put the Thermostat back in the ‘AUTO’ position.
‘OPTIMUM START’ is now switched off.
Top Honeywell Heating & Cooling Experts
Paul Carew
john h
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
