Question about Jenn-Air JCD2389G Side by Side Refrigerator
Left door ajar for a week
Do we have to do anything to get fridge to start up
  • 165 Answers
No, just make sure the coils are clean (under the fridge) true for all times
Posted on Jul 21, 2008
Left hand door not closing easily anymore. lubricate the hinge?
It could be the fridge is tilting forward.
Up turn the two front screw beside the door to make the fridge tilt backwards, or lower down the two back screw to allow the fridge to tilt backwards.
Then the door will automatically close by the weight of the door itself!
Jan 24, 2015 | KitchenAid Refrigerators
Door ajar warning light/interior light won't come on
Good Afternoon bibliophilel, based on the symptoms you are describing, may I suggest resetting the refrigerator. This can be done by either unplugging it or flipping the household circuit breaker off. Wait roughly ten minutes and then turn the unit back on. If the issue persists, then more than likely the light socket and/or the door switch that triggers the bulb and alarm are faulty. In this regard, I would suggest contacting an Authorized Service Technician that will be able to assist you in the exact diagnosis of the appliance and repair.
Jul 19, 2013 | Frigidaire Refrigerators
This is s top freezer type. the bottom door was left ajar for several days. freezer seems to get cold but the bottom doesnt get cold.
Shiut down the fridge and let the fridge defrost off maybe about 8 hours. When the door was left open there could have been frost build up in the evaporator and blocked the vents.
So once the frost has been cleared off the fridge can be switched on to perform well.
Aug 28, 2010 | Maytag Refrigerators
GMC 2003 1500 HD Crew Cab, Door ajar light goes off and won't reset, even when nothing is wrong, I have had it looked at five times and no help. They replaced some things and took out the remote starter...
Who looked at it ? Dealer ? Did the place's you had look at the vehicle hook up a factory scan tool an view data to door module's an the BCM ? Door ajar is a fuction of the door modules an the BCM - body control module . One of these modules is seeing an input that makes it think door is open .
The door ajar indicator system consists of the following components:
• The driver door module (DDM)
• The passenger front door module (PDM)
• The body control module (BCM)
• The instrument panel cluster (IPC)
• The driver information center (DIC)
• The driver door ajar switch
• The passenger door ajar switch
• The left rear door ajar switch
• The right rear door ajar switch
• The liftgate ajar switch
Driver Door Ajar And Passenger Door Ajar
The DDM and PDM receive a discrete input from the respective door ajar switch to indicate the status of the door. The DDM or PDM then communicates this status to the IPC via class 2 message. The IPC, upon receipt of this class 2 message, will illuminate the appropriate door ajar message in the DIC and also send a class 2 message to the radio to activate the door ajar audible warning when the following conditions are met:
• The transmission is removed from PARK
• The vehicle speed is greater then 8.05 km/h (5 mph)
Left Rear Door Ajar And Right Rear Door Ajar
The BCM receives a discrete inputs from both the left and right rear door and liftgate ajar switches to indicate the status of the doors and liftgate. The BCM then communicates this status to the IPC via class 2 message. The IPC, upon receipt of this class 2 message, will illuminate the appropriate door ajar message in the DIC and also send a class 2 message to the radio to activate the door ajar audible warning when the following conditions are met:
Could have DTC'S - diagnostic trouble codes . Looking at data paramiters on the scan tool tool would show what switch is faulty or what part is .
Sep 05, 2017 | 2003 GMC Sierra
Freezer Cold Fridge not cold, vents clear of obstructions. Vent at top left of fridge making a clicking sound, some cold air coming out of vent, probably not enough,Freezer control on 2 ,Fridge control on...
Need to defrost fridge completely for about a day then switch on again. Possibly door was left ajar on freezer, or auger motor iced up due to product being to close to outlet..
Sep 21, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Leak - water not evapourating
check your doors may be not clossing (ajar) or check control to high
Apr 02, 2009 | Westinghouse Refrigerators
Servis fridge freezer
Hi ,
ngafm at your service,
If its cold and frozen it may be that the door switch that activates this light in the case that the door is ajar, is faulty.
Or it may be that the temperature is dropping to slowly for you to see it by eye!
The whole purpose of the, "door ajar" light is to protect you food from spoilage and to warn you before it gets to warm!
Door ajar or not!!!
My advice is to fix the problem now no matter if it is only the switch causing a false alarm.
Or the worst case scenario !
You need hands on service!
Bless You ,
please give me a good rating before you sign off.
Thank you.
Sep 07, 2008 | Freezers
Refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Nov 16, 2007 | Amana AFD2535DES French Door Refrigerator
Frige problem
This is almost a word for word common problem. On frost free fridge freezers of this type all cooling is generated through the freezer side and is merely forced into the fridge side through airflow. Therefore if you have a problem with the fridge you have a problem with the freezer section. The most likely cause is that the coil is frozen up. We would always suggest defrosting unit overnight in case it was simply a door left ajar being the cause of the fault. If the unit then pulls the fridge temp down and it was not the door ajar then you probably have a defrost problem (heater or defrost thermostat, or defrost timer). If it fails to pull the fridge temp down on restarting then it could be the fan or part of the defrost circuit or even possible the cooling circuit. The normal outcome after defrosting is that the temp will drop in the fridge due to air circulation improved, which will probably remain cool for 2-3 weeks until the coil becomes frozen again. On either result I would contact an engineer on the 2nd failure occurrs so that the engineer can establish the exact cause. Hope this helps.
Aug 13, 2007 | Maytag MZD2768G Side by Side Refrigerator
Jenn-Air JCD2389G Side by Side Refrigerator Logo
41 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
