Question about Kenmore 22812 Bagged Canister Vacuum
Power cord recoil
We cannot get the power cord to uncoil and I do not known how open the the case to repair it
  • 2 more comments
  • jkloster1 Jul 20, 2008
    The model number is 116.2451290
    Fixed it, thank you all
  • Anonymous Sep 10, 2008
    I cannot find a way to get to the coil inside the vacuum to uncoil it. I don't see any screws, just plastic which I'm afraid to pull. I don't want it to crack. Please help me.
  • benchracer Jan 04, 2009
    Have the same problem. Can see the screews under the power cord return pedal, but can not get to them. How does the pedal come off.
Well, there were two problems, the first being that the cord got jammed and I did not know how to get inside to clear it up. Finally we got under a dark gray cover which exposed screws which I was able to open everything up and fix it.
Then the motor for the brush stopped working. We kept playing with it and it intermitantly operated. Obviously a connection that opened up from time to time. I may need to get another vacuum. I cleaned all the obvious connections.
Posted on Jul 22, 2008
How do you repair the cord recoil when it won't retract the cord on a vintage Electrolux?
It's very difficult to repair a cord wheel that's not working properly. There is a tightly wound spring that can cause harm if it comes uncoiled. It's best to try to find a replacement cord reel.
Jan 14, 2017 | Vacuums
Why does nothing happen when power button pushed?
The Dyson cords are known to go bad, test the cord and see if there is voltage. If this is too mechanical for you, please take the vacuum to your nearest vacuum repair shop
Mar 21, 2016 | Dyson DC44 Animal Handheld Vacuum Cleaner
HOW TO REPAIR THE RECOIL POWER CORD ON A KENMORE MOD 116.23613300 VACUUM
generally you need to replace the spring mechanism. contact the manufacture for parts/cost. Most local shops don't carry parts to repair vacuums, unless it's a new model, most vacuums are designed to work until they don't then you replace. unless you spend more than 400-500 bucks on it that is.
Nov 25, 2014 | Kenmore Vacuums
My cord wont rewind
The rewind tension spring may be broken or fully extended. Try to yank hard on the cord and pull toward you with some force. Pull until the line will no longer come out and if it won\'t recoil then it needs to be repaired.
Apr 01, 2014 | Electrolux Vacuums
Hoover s3670 opening the vacuum case
there are screws under the power switch and the cord recoil switch. the switches pry off lengthwise. once the switch covers are off you will see the rest of the screws. it was pretty straight forward from there.
Jan 02, 2012 | Hoover S3670 Bagged Canister Vacuum
Have just purchased vax c90 vacuum cleaner,have a problem re-coiling the power lead.have followed instructions to press down on designated button,but power lead does not recoil.
On pressing the cord has to coil into the holder and if this wont happen there is some mechanical fault in the recoiler or spring.
You can pull the power cord once again outside and let it slide inside, repeat this sequence to allow the winder to respond and then it might pick up.
Apr 06, 2011 | Vacuums
How do i open the housing of an electrolux ambassador model #c101j to fix cord recoil
This can be a complex undertaking, so I highly recommend taking it to the nearest Aerus Electrolux store for repair. I've seen many disassembled machines come in to the shop because the owner couldn't figure out how to put it back together. Any misplaced wires during reassembly can result in nonworking vacuum, shock and even fire hazard.
Taking it to the shop may cost more, but I believe is less expensive in the long run. They'll do it right.
http://www.aerushome.com/storelocator/
Dec 14, 2010 | Electrolux Lux 5500 Canister Vacuum
Dead Miracle Mate Vacuum cleaner
You don't have to open the cannister. You can easily remove the black plastic collar through which the cord is supposed to emerge. The collar has a little springy tab that holds it in place. Once the collar is removed, you can reach in and grab the cord and pull it out.
Steve
Aug 02, 2009 | Vacuums
Power cord retrieval
Depending on which model you have, take the bag door or lid off by pushing it back and it will unhook and come off, there are 4 screws that hold the cover on over the where the cord rewind button is, take that cover off and you can get to the cord reel.
Feb 12, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Kenmore 22812 Bagged Canister Vacuum Logo
356 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
