Question about Vacuums
How to change kirby vacuum belt? - Vacuums
  • 438 Answers
Greetings,
Here's a video where we show you how to replace the suction fan on a Kirby Generation vacuum cleaner (also known as the impeller blade). I hope this video helps;Chris Jones
GoVacuum.com
Posted on Mar 18, 2010
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=809909
Generic problem for all Vacuums
How to change Kirby vacuum
Posted by wkgnkicks on July 20, 2008
How to change Kirby vacuum belt?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The belt install on a Kirby is to raise the height adjustment to the highest level and then dial the belt off counter clockwise so it is loose and not on the fan pulley, release the top lever on the bell housing, then remove the bottom plate and unhook the brushroll on one side, slide the old belt off and then slide the new one on, replace the brushroll with the screws facing the carpet and re-hook the bottom plate on the Kirby. Then take the bell housing and hook that back on to the Kirby and lock it down. Then dial the belt on clockwise all the way and the belt should be on the fan pulley. The belt should be ready to go, plug in your Kirby and then do the step down on the vacuum height adjustment until the tone changes, then try to see id it picks up, if not go one more height adjustment and that should be the correct setting.
http://kirby.com/
Customer Service – U. S. & Canada
1-800-494-8586
Hours 8:00 am to 5:00 pm (EST)
Mail To: Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 21, 2008
Arius
  • 446 Answers
SOURCE: how do you install the belt on the kirby vacuum
Step 1:
UNPLUG YOUR KIRBY VACUUM CLEANER. Before you go any further, take your time with this belt change. It's not that difficult, just a little different than most other vacuums. These belts are very easy to find on the internet. kirby-oldstyle1.jpg Step 2:
You should be facing the front of your Kirby vacuum. The height adjustment lever will be on your right. Push the lever all the way down. Lift the light hood with your left hand. Turn theKirby vacuum belt lifter counter-clockwise with your right hand. Unlock the accessory lock. The accessory lock is located under the light hood. Move the lock to the left to disengage it. Remove the front of the vacuum cleaner.
kirby-oldstyle2.jpg kirby-oldstyle2a.jpg Step 3:
Turn the vacuum belt lifter all the way clockwise until the belt drops down. Unlock the roller plate by releasing the two latches on the rear. Pull the roller plate up slightly and then off. kirby-oldstyle3.jpg kirby-oldstyle3a.jpg
Step 4:
Bend one end of the roller bracket just enough to remove the roller. Remove this end of the roller. If you need to replace the roller take it all the way out. Remove any carpet fiber, string, or hair from the roller with a scissor.
kirby-oldstyle4.jpg kirby-oldstyle4a.jpg Step 5:
After you have removed the old belt, slide the new one back on the middle of the roller. If you're Kirby vacuum cleaner has a belt indicator light, the roller will have a magnet built onto one end of it. It's very important to install to install a roller with a magnet on the same side as the indicator light. The roller actually will only fit into the roller plate one way.
kirby-oldstyle4.jpg Step 6:
Place the roller back in the roller bracket. Place the roller bracket back and lock it into place with the 2 latches. Rotate the vacuum cleaner belt lifter counter-clockwise. You should feel the the belt catch. Look inside to make sure the belt is being stretched onto the vacuum belt lifter. Reassemble the machine. After you have reassembled your Kirby, turn the belt lifter cockwise, releasing the vacuum belt onto the vacuum motor shaft. kirby-oldstyle2.jpg
Posted on Nov 27, 2008
VacuumRepair
  • 438 Answers
SOURCE: i need to know how to put my belt back on my kirby
Greetings from GoVacuum,
Here's a very informative video that we've recorded explaining in detail how to correctly install the belt on your Kirby Generation vacuum cleaner. I hope this will help you.
Kirby Belt Change Video;
If this video was helpful, please be sure to rate this Solution by clicking on the 4 Thumbs Up icons in the top right hand corner of the page. If you have any questions, please feel free to email me, I'm more then happy to answer any questions you may have.
Chris Jones
GoVacuum.com
Posted on Mar 19, 2010
b0sslady2001
  • 357 Answers
SOURCE: kirby G5 vacuum
Here is a link to the help you need,,,
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
The G5 manual is out of print, but the G6 and Ultimate G models are exactly the same and wil work perfectly for your questions.
Marci
Posted on Oct 25, 2007
SOURCE: Kirby Sentra vacuum burning belts
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=565459
posted by campoclan on May 02, 2008
Have had Kirby vacuum for a couple of years since I've had it I burn at least two belts in two months. I keep roller clean, what is the problem?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Some of the problems that people have is that they feel they have to have the vacuum head all the way to the floor and that makes the belt work that much harder. The key to the best cleaning is to raise the height adjustment all the way to the top and once it’s there then drop it down one notch or setting @ a time until you here the tone change. Then try it to see if the vacuum if picking up well if not drop it down one more notch and that should be the setting it is supposed to be for your type of carpet. And remember to use the genuine Kirby belts instead of the Kirby replacements, they will work better. And your suggestion that to keep the brushroll clean and free spinning on each end and also keep the bottom plate clean of dirt and grease because if there is a build up it will move slower and leave black marks on the carpet. I hope this will help and if not contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/ Customer Service – United States & Canada 1-800-494-8586
Hours 8:00 am to 5:00 pm (EST) U.S. & Canada Fax # 1 (216) 529-6146
Mail To:
Consumer Relations
The Kirby Company
Cleveland, OH 44102
Go Ahead. Use Us.
Posted on Jun 27, 2008
  • 10 Answers
SOURCE: How to put a Kirby Vacuum belt back on
To put on a kirby belt all you need to do is put on the belt on the brushroll, put the brushroll into the housing making sure the marks on the end of the brushroll are the same. Take the spin dial in the front and "hook" the belt till the dial reads off. Put the head back on the machine and spin the dial to "on".
Posted on Jan 27, 2010
Change belt on Kirby heritage vacuum
It is the same as installing a Kirby Generation belt.
Here is a walk through:
Install Kirby belt and nozzle
800-775-6586
GpodVac com
Sep 15, 2014 | Kirby Vacuum Fan Heritage G3 G4 G5 Ult G...
Tip
How To Replace a Belt on a Kirby Generation G3-Sentria Vacuum Cleaner
Greetings,
Below we explain how you can replace a vacuum cleaner belt on the Kirby Generation upright vacuum cleaner. All you will need to perform this repair is a new Kirby Generation Upright Belt, and some time. No tools are needed to perform this repair. This repair is the same for all Kirby Generation models including: G3, G4, G5, G6, Ultimate G, Kirby Diamond Edition, and the Kirby Sentria. The repair procedures have to be followed exactly in order for the vacuum to work properly. This should be done at least once a year even if the belt doesn't break, because these belts will stretch out over that year time period and will not work as well as a new belt would.
I hope that you find this video helpful. If you do, please be sure to rate this Tip as helpful by clicking the Thumbs Up Icon in the top right hand corner of the Tip.
Feel free to send me an email anytime if you have any questions on the repair of the Kirby, or any vacuum cleaner.
Video Repair on how to Change a Belt on a Kirby Generation Vacuum Cleaner;
Thank you so much,
Chris Jones
GoVacuum
on Mar 19, 2010 | Kirby Ultimate G Bagged Upright Vacuum
How do I change the belt on the diamond series kirby vacuum
http://www.kirby.com/Portals/0/videos.html
This web page has a video that will show how to change the belt.
Dec 27, 2011 | Kirby Vacuums
How do we change the belt on our Kirby Vacuum Cleaner
Here is a link to a video explaining how to change the belt on a Kirby vacuum. It is at the bottom of the page
http://www.totalvac.com/videos/kirby-vacuum-cleaners-videos.htm
Jun 02, 2010 | Kirby Heritage II Vacuum
How do you attach the belt for the roller-brush on a Kirby Generation 3, up-right vacuum-cleaner?
Greetings,
Please see the attached video on how to replace the belt on a Kirby Generation Vacuum Cleaner. This is an easy to follow step by step direction on the proper way to replace the belt, as well as do basic maintenance on your Kirby's roller brush which will prolong the life of your belt greatly if done regularly. I you find this video to be helpful, please be kind and rate it well by clicking the thumbs up icon below.
Feel free to request a repair clarification if you have any quesitons on how to replace the belt on your Kirby.
How to Replace the Belt on a Kirby Generation 3 (G3) Vacuum Cleaner:
Thanks for watching!
Chris J.
Jun 14, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Belt
go here
Rob
Mar 06, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby heritage 2 sweeper
the above link shows you how to change the belt on the g-series kirbys but it will apply to the heritage edition as well...the only difference is the color...some of the arrows may be missing on the front belt lifter knob...but they are little differences...
hope this helps!!!
Feb 06, 2008 | Kirby Heritage II Vacuum
Changing a belt on kirby G6
I have written an online guide to help with this issue. Click on the link to view the guide.
Hope this helps...
Marci
Oct 15, 2007 | Kirby G6 Bagged Upright Vacuum
Vacuums Logo
324 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
