Television philips magnavox model number: tp3261c102
My screen goes crazy and the piture and color get distorted. I hear a buzzing noise coming from inside. I removed the cover and when this happens i see a spark come from the circuit board (not the board on the back of the lamp, the other one) if i flick the board lightly or cycle toe power on my telelvision this fixes the issue. can that small circuit board be replaced and how do i remove it to replace it?
  • 8,617 Answers
Not sure which board you mean, can you reply to this same post with your model number and possibly a picture of the board youre needing?
Posted on Jul 20, 2008
Tv making a buzzing noise
I would check the Flyback, and horizontal output transistor. Could also be a grounding issue. If you're not familiar with fixing them get it serviced.
Dec 28, 2012 | Philips Magnavox 27MS343S 27" TV
My Samsung HL-S5065W will turn on, it makes a humming noise. The picture comes on after a 1 minute or so the screen will go black and the tv shuts down. What could this be?
Hi,It sounds like you might be
experimenting a color wheel problem.The
color wheel is a rotating disc that has a
gamma of colors it spins at high rpms.The
light of the lamp goes through it to create
the colors on your tv.When it starts to go
bad you will hear ,humming,buzzing,high
pitch noises ,you might also experiment
color distortion ,black and white
picture.Here's a link that will help you
replace it:
http://www.fixyourdlp.com/guides/samsun
g/bp96-01579a.php Part # is BP96-01579A and you can find it here: http://www.discount-merchant.com/Samsung-Replacement-Color-Wheel-HLS-HLT-Series-p/samsungcolor_wheel_bp96-01579a.htm?Click=48173 Have a blessed one!
Apr 29, 2010 | Samsung HLN5065W 50" Rear Projection...
Loud grinding noise when the lightbulb is on
Hi,If your tv is a dlp you might be experimenting a color wheel problem.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming ,grinding,buzzing noises.
Apr 06, 2010 | Philips Magnavox 9P6034C 60" Rear...
I have a hdtv magnavox 27 inches flat screen, it does well for a while and the I loose the picture or the sound goes crazy
This television is having problems with intermittent component operation. The components have not failed as yet but will with continued use. This could cause more problems with your television. The television should be test for faulty component operation. The Magnavox customer support telephone number is 1-800-705-200. Tell them the model number of the television and the problem you are having with the intermittent operation of the video and sound.They will be able to help you find a service center to test and repair the television.I hope this information helps you with your problem.
May 18, 2009 | Philips Magnavox 27MS343S 27" TV
TV doesn't come on
Your SSB Module is Bad Part # PH3912725881.
Jan 02, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Magnavox 50" DLP Tv power light comes on but then i hear a buzzing noise and then two red lights come on the tv. at no point does the picture turn on during this time. Can you please give me a possible...
Your bulb is burned out. I have had the same problem. It seems this television has an overheating problem--and short bulb life. I have had our 50 Magnavox dlp for two years and just put in the second bulb before Christmas. You can buy the bulb from a dealer on ebay for $99 and install it yourself. I is not in the housing so you have to carefully take out 4 screws and replace the bulb without touching the face of the bulb. To buy the one from Magnavox with the housing is much more expensive. I think the first time my husband replaced the bulb it took about 45 minutes--this time it took about 20.
Dec 16, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Philips Magnavox 51MP392H Rear Projection Television
are you getting sound, was it moved laterly, did you just get it from somone, did it get wet, does it make clicking noises, was the picture color/ convergence blurring before this, were the colors slowly seperating such as red/blue/green?, did the picture bow on top and bottom or sides prior to tihs, was there anything note worthy prior to the blank screen.
generally its IC convergence problem with the larger philips projection TV's however I need more info on your TV, also size make model # anything you can provide gets us a more narrowed solution.
hope this helps....
Aug 17, 2008 | Philips Magnavox 51MP392H Rear Projection...
Buzzing noise on Samsung HL-R5667W DLP
You have a noisey color wheel. It is a little tricky to replace but not too bad. Also, there are several different versions of these for different models so be sure you use complete model number from sticker on side of set. Must remove light engine and will need extra long philips screwdriver (magnetic). That is to get color wheel cover off/on. When switching ribbon cable, notice it only has contacts on one side so make sure to put new one in same way. Good luck, Russmann.
Apr 20, 2008 | Samsung HLR5667W 56" Rear Projection HDTV
Distorted picture
tv has red & blue converge problem,tried to fix it with remote by multipoint lining the t,s up didn,t help
Jan 12, 2008 | Philips Magnavox 51MP392H Rear Projection...
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
