Dell Dimension 2350 DVD/CD Rom Drivers
My DVD/CD rom does not work on my computer and device manager is telling me that I have the wrong drivers installed. I did a system restore but that did not help.
Thank you in advance for any useful information.
Giovanni NEC NR-7900A
  • 300 Answers
According to the info in your post, here a firmware update for you drive from Dells site. This assumes that you have xp as listed on dells site.
If you do not have xp, you can look at the service tag on the side of your machine (it should be 7 digits). After you have that you can enter it here http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
After you get that info you should have a screen that list the different components of your system. You will want to click the + beside CD/DVD. Then you will want to look for your model number that you listed above and dowload wants available for it.
It usually automatially installs and corrects the issue but if not you may want to open the device manager by clicking Start > Run and typing devmgmt.msc. This willl take you to the Device Manager. Open the DVD/CD section and right click the drive listed above and choose Remove or Uninstall. After it disappears, restart the machine and install the firmware update that was downloaded earlier.
Thanks
Posted on Jul 20, 2008
About 2 years ago I downloaded a DVD/CD Rom program. After that my 'Mutimedia Audio Controller' went out and I could not even find it on my computer anymore, and I done all I can think of to recoop the...
hi, for you to be able to delete audio drivers, you need to go to the device manager,
Start
Right click on My Computer
Click Properties
Click Hardware tab
Click Device Manager
Expand the Sound then right click on the drivers under sounds then click uninstall, name of the driver is usually realtek
then restart pc
Hope this will help... Youre response is very much appreciated...
Jan 20, 2011 | Dell Dimension 2350 PC Desktop
Hello i want buy solution cd-rom driver..... my
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties you will have options under general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
Jan 16, 2011 | Dell (074JH) Internal 48x CD-ROM Drive
I was just given a Dell Dimension 3000 by my daughter, who said there was no problems with it. It has a CD-Rom drive and a DVD-RW drive. When I power it up and click on MyComputer, neither of these drives...
They probably can't load because they are loading at the same time and XP can't sort it out.
Remove the cable from the CD ROM and re boot but enter the BIOS and make sure it is no loonger there.
The nachine should load the DVD rom.
You can try adding the CD rom now, it may work but being XP it may grab the wrong driver again and hang up.
Download new drivers from Dell.com
Hope this helps.
Jan 02, 2011 | Dell Dimension 3000 PC Desktop
System thinks r/w cd drive is not a write drive. Have written to drive in past and copied many files.
Go into control panel and get into the device manager. Uninstall all cd rom devices on your computer. Reboot find good cd burning software like Nero install it and then see if it works, also try new writeable media also.!
Jun 12, 2010 | Dell Dimension 2350 PC Desktop
Can i burn dvds on my 2350 dell dimension computer if not what do i need
well if u have a dvd burner or a dvd writer installed on ur computer
then u will need to install softwares like NERO or ROXIO on ur computer
first chk, i thnk it mite be already installed on ur computer.
use them and u will be able to burn DVD's
Nov 02, 2009 | Dell Dimension 2350 PC Desktop
Computer doesn't recognize CD-ROM
Click on the link below and click on the "Fixit" button. It's a registry patch from Microsoft for unrecognized CD/DVD devices. Best of luck.
Greg
http://support.microsoft.com/default.aspx?scid=kb;en-us;314060
Jun 10, 2009 | Computers & Internet
Dvd/cd rom not working
Are you fimiliar with the Inside of a computer box?
Apr 03, 2009 | Dell Dimension E520 PC Desktop
My solution would be to do a system restore but to restore your pc to before the problem occured. This helps with certain driver problems sometimes.
Jul 19, 2008 | LG CRN 8245B (CRN-8245B) Internal 24x...
CD rom
hi
open your pc case
open screw of rom then remove power and data connection from rom then pull your rom.
then install dvd burner.
power and data code connect.
install burner soft
ok
u have done
Mar 24, 2008 | Dell Dimension 2350 PC Desktop
Computers & Internet Logo
120 people viewed this question
David Payne
David Payne
