Question about Canon PowerShot A520 Digital Camera
Memory card Our old memory card stopped working in the camera. It said "memory card error". I bought a new card, 8gb duracell sdhc card, and when I put it in it said"memory card error" again. I tried formatting the card but it would not allow me to. I put the card in my computer and the new one works fine. I gave the old card to my brother in law to look at it, but he is on vacation, so I can't test it in my computer. I put the card that came with the camera in and it works fine, but it is a mmc16m cannon card and only holds like 12 pictures. If that card didn't work I would know it's the camera, but because it does, I'm confused
  • rickhavas Jul 22, 2008
    Thank you for your help
  • 2,039 Answers
Unfortunately, the A520 does not support SD memory cards with more than 2GB capacity, and doesn't support SDHC at all. (1GB max for MMC cards.) I know memory is much cheaper than when the camera first came out, but in 2005 2GB was about as large as you could get.
Posted on Jul 21, 2008
Samsung s1030 digital camera keep showing memory full but have inserted new sdhc card how do i clear this as i cannot take any pics
Clear it by putting in a compatible memory card. The S1030 works with SD cards. Your 8GB SDHC card in not compatible. You need to use SD cards, 2GB and smaller.
Sep 08, 2012 | Samsung S1030 Digital Camera
Gateway digital camera DC-T50 5.25 megapixels put new memory card and a card error message appears
The camera uses SD cards. I assume your new card is 8GB, not 8MB as you stated. If this is the case, it's an SDHC card. While it fits into the slot, it is electronically incompatible and will not work in the SD-only camera. You need to use SD cards, 2GB and smaller.
You may download a copy of the manual here.
Apr 04, 2012 | Gateway DC-T50 Digital Camera
I bought two new 8GB SDHC memory cards for my canon ixus500. the old memory card is 1GB ad still works but i wanted more memory cards. neither of the two new cards work. they both say memory card error AND...
If your camera is the type that uses SD cards, then your problem is that the camera was developed in 2004 before SDHC cards were invented. Your camera cannot use them.
Sep 15, 2011 | Canon PowerShot S500 IXUS 500 Digital...
Bought a new sony sd/sdhc memory card 8gb and it will not format/load for my camera--what do I need to do?
The problem is that your camera is only compatible with SD cards, not SDHC cards. You bought a larger card for your older camera, not noticing that it was SDHC (or not knowing that it mattered). The new card doesn't work, not because it or the camera is broken, but because it's not compatible.
Cards up to 2Gb are generally SD.
Cards of 4Gb are generally SDHC.
Cards over 8Gb have to be SDHC.
(There are exceptions. Sometimes, manufacturers make 4Gb SDHC cards but some have errors; they disable half of the chip and sell it as 2Gb, but it's still SDHC. 4Gb cards are almost always SDHC because they're cheaper, but 4Gb SD cards do exist. They are so rare that I've even seen a guru on this site claim they don't. I did own one once, but it was very expensive and turned out to be so unreliable that I had to return it. I don't recommend looking for one, because of the problems.)
Your solution is to go find a 2Gb card, and be extra sure that it doesn't say "SDHC" on it.
Feb 23, 2011 | Samsung Digimax D53 Digital Camera
I bought a new 8GB memory card for my kodak easyshare Z612. However it's not formatting. Help!!
The Z612 works with SD cards, which max out at 2GB. It will not work with larger SDHC cards.
May 20, 2010 | Kodak EasyShare Z612 Digital Camera
EasyShare Z612 Digital Camera: I bought a new 8GB memory card for my kodak easysh...
May 18, 2010 | Kodak EasyShare Z612 Digital Camera
I have just bought a 8GB Panasonic memory chip for my Kyocera Finecam M410R camera. But it comes up with card error on it. I put back my little old 124mg card and it is fine. Can I use a panasonic card...
The brand isn't important. The 8GB card is an SDHC(secure digital high capacity) card and the smaller one is an SD. Your camera may not be able to use an SDHC card. Try formatting it in the camera before giving up on it.
Feb 14, 2010 | Kyocera Finecam M410R Digital Camera
Card error
Your camera was designed (2004) and manufactured (mostly 2005) before current generation SDHC cards became available. It will therefore be incompatible at the basic hardware level. There were some non-standard SDHC cards around in 2006 but your camera was never designed for those either.
Stick to regular SD cards, in theory your camera can handle 4GB maximum but the design team wouldn't have been able to certify compliance with that size of card as they also weren't available at the time. To be safe, stick regular SD cards with a 2GB maximum capacity.
Sorry there's no way for you to use your SDHC with your present camera but at least I hop that I've prevented you from wasting time and money on buying another incorrect memory card.
Please return the favour by taking a moment to rate my answer.
Oct 06, 2009 | Acer CE-5330 Digital Camera
Canon PowerShot SD 630 Digital Elph "Memory Card Error"
I'm sorry to tell that PowerShot SD 630 does not support SDHC cards over 2 gig.
If you want the camera to take a card over 2 gig then you are stuck standard SD cards.
The other camera does support the card because it's a higher model.
Regards.
Sep 03, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
SDHC card won't work
Your card is an SDHC, your camera supports only SD/MMC cards. I know this because i found thisp ostlooking for a way to make it accept SDHC cards, a software update could easily work in theory but someone would have to write that update. Technology changes fast doesnt it.
Dec 22, 2008 | Kodak EasyShare Z710 Digital Camera
Canon PowerShot A520 Digital Camera Logo
177 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
