Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Ice maker whirlpool refrigerator mod.ED5FHEXNB00 is having problem about the ice cube in the tray not dropping.The motor is not moving to turn the cubes to drop.I do not see anything stock or in the way for it not to turn the cubes just sit there.Can anybody tell me whats wrong because maybe there is just simple solution.thanks
  • 1 more comment
  • domenl Sep 24, 2008
    I have a brand new Fridge (I moved in on 9/20/08). No ice. I can hear it trying to make it, but nothing.
  • rogerblair Sep 25, 2008
    The ice maker is making a weird light "roaring" type sound and no ice is coming out. It's been doing this for about 2 days now and the sound is getting louder.
  • mdm138 Oct 01, 2008
    The ice maker will make cubes for a while then stop. Is there a reset switch or defrost problem.
  • 24 Answers
Check the ice dispenser is there ice in it and if not check water supply to it.
Posted on Oct 08, 2008
Whirlpool ice maker quit.
If it's similar to my Samsung, mine did the same. There is a reset button at the front of the box which contains the ice cube tray. If you press it, the ice tray rotates to dump the cubes, then refills. Hope this helps.
Sep 03, 2017 | Whirlpool Refrigerators
Ice maker on whirlpool quit working .
If it's like my Samsung, there is a reset micro switch button in front of the box containing the ice cube tray. Press it and the machine resets, the ice cube tray rotates, dumping the cubes. It then rights itself and fills with water. Hope this helps.
Is there an adjustment for the fill level on the whirlpool ice maker? Its to full. Cubes are all linked together.
You are exactly on the right track...
but without a MODEL NUMBER one could only take a wild STAB in the be-wilderness.
You older generation twist tray... and heasted sweep tray
had TWO (2) adjusting screws immediately under the front cover
of the ICE-MAKER head...
Neither took much of a twist to SIGNIFICANTLY affect fill level... or change the TRIGGER temperature
resulting in SLOW DELIVERY... or FAST DELIVERY of hollow (partially frozen (under-done)) ice-cubes....
A really GREAT IDEA would be to get the OWNERS MANUAL... &
(ready)... ((drum-roll))....
READ IT.
I'm just saying...
ELSE ... disclose which of the millions of Whirlpool
ice-makers you might be referring to.... Mod. number!!!
Me...
Carnac the Magnificent
Jan 19, 2017 | Whirlpool Refrigerators
Whirlpool mod#ED5FHEXNB00 isn't making ice
Freezer temp has to be below 10 degrees for ice maker to work. Also check to see if water/ice is in the tray. If no ice in tray then the water solenoid valve is not feeding the unit. If ice in tray then the heater is not working to melt the ice a bit so it can be scooped out into the ice tray. And make sure the feeler arm is down into the ice tray bin - if not, ice maker is shut off.
Oct 05, 2015 | Whirlpool Refrigerators
Whirlpool ice maker not working
Ice makers are some of the most worked part of a refrigerator and have about a five year lifespan. There are just too many things that can go wrong that can stop the ice making process. To explain the process of a Whirlpool ice maker I am going to post a Whirlpool Ice Maker Troubling pdf and a short YouTube Icemaker Repair toutorial. If you have any questions I will be here to assist you, Thanks Sea Breeze
May 23, 2012 | Whirlpool Refrigerators
Not making ice,checked optics ,good ,water valve coil tested good, no restrictionsbut i get no water in tray,also freezer temp is 8 degrees.
OK you mentioned the ice maker had no cubes or not making cubes, try filling tray with water from tap. Let freeze and if the ice drops into ice bin the ice maker is OK. Most times the ice maker thermostat is at fault (pt. 27 in photo) if not cycling. Read OHM's between both coils and they should be very near to same reading, if not replace water control valve=> 4389177 by applying first 120VAC to see if valve opens. If water goes into ice maker this way or OHMs between the two are nearly the same your Ice Maker=>2198597 Ice Maker Assembly may need replaced. If you would like to rebuild your Ice Maker here are the part Breakdown view=>
GS5SHAXN Ice Maker Replacement Parts
Let me know how your ice or water turns out, Thanks Sea Breeze
Feb 11, 2011 | Whirlpool GS5SHAXN Side by Side...
Ice maker does not extract ice cube's to the pan
Take a short piece of #14 insulated wire and strip both ends about 1 inch. Bend the wire into a "U" shape. Insert the stripped ends into terminals "T" and "H" inside the ice maker cover. The gear should start to move. After the gear has moved 1/4 turn,remove the jumper wire.If the heater and thermostat are good it will drop ice and refill. If not it will stall.
If the motor does not move at all or the motor stalls, replace the ice maker.
May 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice Maker not working
Get me the model number. Put tap water in ice maker tray and make sure arm is down. Let it freeze. Wait and see if the ice will drop, this should allow water to come into the ice maker for another run. Let me know, Thanks, Sea Breeze
Apr 27, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice maker not working
Depending on the ice maker style, they typically work off a motor timer. The timer motor rotates to set up the ice making process... starting with letting water into an empty ice mold tray, allowing ample time for that water to freeze and then to rotate that mold so that the cubes fall out into the bin. In conjunction with that process, a small heater is turned on to release the frozen cubes from the tray. The 'ice tray full' lever signals the system to stop making ice so you may want to verify that the lever is down and not causing the ice maker to stop, If that's down then I suggest you monitor the position of the motor gearset underneath an access cover. With power applied, the gears should rotate and cycle thru an ice making process. If it does and ice fails to fall out, your heater may be defective. Hope that helps...
Jun 22, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
138 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
