Microwave Ovens Logo
Posted on Feb 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Our microwave/ oven is aprox 2yr old.bought for a new home so has had aprox 1 yr use.turntable has stopped turning.
  • hi_b Feb 12, 2011
    A waste of time
Richard Roth
Level 3:
Top Expert:
  • Whirlpool Master 9,472 Answers
  • Posted on Feb 12, 2011
Richard Roth
Whirlpool Master
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2627430
Points
28464
The drive coupling which on this model is part of the ring under the plate is your problem. If you could post your model number, I will be able to direct you to the part.
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Feb 02, 2011
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
130
Points
14
Sorry i cant help u
Panasonic microwave oven turntable is not turning
If less than 1 yr old call them 0871-964-0028. They will advise you pal
2answers
The turntable in the microwave won't turn at all. Unit is <1 yr old. The turntable on/off selector doesn't help it. Any suggestions?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Hi I have an Emerson microwave oven MW8998B. The turn table will not rotate while cooking. The smaller bags of popcorn just burn the bag. Does this need a repairman or can I fix it myself. Also, I am able...
Hi, I had the same problem with my Emerson microwave. As I rent out the house, and the turntable stopped working while I was away, my rental agent bought another Emerson microwave. On my return I tried using the new (brown) plastic turntable on the old microwave, and found it worked perfectly. Maybe it would be possible for you to order a replacement turntable part. Hope this helps. Good luck, Rosalind
Turntable wont stop turning, even when not in use
The turntable is a seperate intenty from the microwave itself, I would presume that the switch that turns off the turntable when the door is opened needs replacement.
Microwave stopped working
to indutolia
The original problem was probably a bad turntable motor, which is pretty easy to replace.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Now I'd say you have a bad door switch (whether upper or lower depends on the model number) or a problem with the door switch mount.
This is a pretty simple problem to fix, too: http://www.microwavedisplay.com/doorsw.txt
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
to lostonisland - Your problem is different enough that it should be a separate post. Please include your brand and model number when you repost.
1helpful
Microwave is not working
One of the door switches needs to be replace.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Noisey turntable
try pulling on the plastic drive and inspect it you just pull up on it to remove it
GE JVM1650 truntable noise
Sounds like the turntable motor is going bad.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Top Whirlpool Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
