Bosch classixx washing machine softner dispenser fills with water will not empty
  • Anonymous Aug 09, 2008
    I HAVE THE SAME PROBLEM- MY BOSCH NEXXT 100 SERIES IS LESS THAN 2 YEARS OLD.
    THE DISPENSER FOR FABRIC SOFTENER FILLS UP WITH WATER
    I HAVE TRIED PUSHING THE BUTTON FOR SOFTENER WHEN STARTING A NEW LOAD OF CLOTHES...NO HELP
  • janeadley Mar 10, 2009
    same problem
I have had this problem and found that it is due to not enough water getting into the softener chamber. THere are holes above the drawer in the inside that can sometimes get clogged up with muck, if you clean these out the water will flow and the syphon effect will work correctly.
Posted on Jan 20, 2010
Fabric softner dispnser filled with water
Try siphoning it out or pumping it out .
Feb 06, 2013 | Washing Machines
My bosch classixx 1200 expressnot taking fabric softner
Okay first try removing the soap try and cleaning it,secondly get a jug of water and partly fill the softner tray, at this point it should automaticly drain if not then looks like the Solonoid coil valve is at fault quite easy to replace cost of parts around £20......Good luck, hope the first part solves this......
Feb 02, 2011 | Bosch Washing Machines
The bleach and softner dispenser does not work. The liquid softner would still be there at the end of the wash - never dispensed. I took out the dispenser and cleaned it, but no change. When I leave the...
Don't know if this is the answer, but my dispensers stayed filled also. repairman said the water wasn't flowing into the machine quickly enough and therefore not tripping the sensor that told the machine when to disburse the softener and/or bleach. He took the cold watersupply line loose, and the mesh was full of sediment. He said it wasn't necessary to replace the mesh. Sure enough, it started working immediately. He did the same for the hot water line..it wasn't clogged.
Aug 08, 2010 | Maytag Neptune MAH5500B Front Load Washer
Conditioner is staying in draw when water should be feeding into draw at end of cycle it is going into both other draws but not the conditiner one any ideas
Hi, welcome to Fixya. Immediately what comes to mind, actually two things. Fabric softner can often be too thick to dispense properly in front load dispenser's unless deluted half & half with water before adding. The other thing is this, it could be the water inlet hoses connected backwards, i.e. Hot going to cold and cold to hot at the washer, hence in the rinse cycle when cold water should enter the fabric softner chamber it doean't. Let me know what you find as I will look for your reply. Thanks for visitng "fixya". Please take a moment and rate this info accordingly but also let me know if you need further assistance. Good luck. Macmarkus :)
Jun 22, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Conditioner left in drawer after wash
the conditionre is washed out by adding water which fills the level in the dispenser up until it activates a syphon effect. I found with mine that years of dampness had led to all sorts of muck blocking flow of fresh water. Take off the machines's lid, then extract, take apart and clean the plastic unit that is above the conditioner dispenser.
Jan 17, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Conditioner not emptying in Bosch Classixx 1200 Washing Machine
ITS NOT THE DRAW THATS NEEDED CLEANING ITS THE JETS ABOVE IN ROOF OF DISPENSER THESE ARE DIFFICULT TO CLEAN UNLESS YOU USE HOT SOAPY WATER AND A SYRINGE TO FORCE THE BACTERIAL GROWTH BACK DOWN THE PIPES,IF YOU DO THIS KEEP GOING TILL NO MORE BLACK STUFF COMES OUT THEN TRY IT IT SHOULD WORK LEAVE THE DRAWER AJAR WHEN NOT IN USE THIS WILL CUT DOWN THE MILDEW GROWTH.
Sep 16, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Classixx 1000 Express washing machine won't fill with water
cheak the filter witch is at the intake and if when it is going to fill does it buzz if dose that means the vale is working if not call a repaire man out hope this helps
Jan 22, 2009 | Bosch Classixx WVF 2402 Front Load...
Fabric softner dispenser
take the soap dispenser drawer out and clean the drawer and the underneath the drawer, then clean the inside of the machine where the drawer fits into to. It could be caused by a build up of soap.
Oct 30, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosh washer won't dispense softener. cleaned the tray and tested it by filling with water and it drained completly out, so i know its not clogged. washed another load and softener still there at end of...
I had the same problem. I went to www.justanswer.com and asked the same question as you. I have copied my questions and answers into this reply. My Bosch Nexxt 500 Series washer has stopped dispensing fabric Sent to Appliance Experts 10/25/2009 at 3:24 PM My Bosch Nexxt 500 Series washer has stopped dispensing fabric softener; I also find water in the softener dispenser cup (little cup that pops out for washing - has two sides, one for softener and the other for bleach) after every load. I have tried soaking and cleaning the cup with a brush as the manual indicates with no changes; water still standing. I removed the dispenser and filled it with water. The water didn't run out until I angled the end with the drain hole slightly down. Then the water came out through the drain hole fine. I thought maybe I hadn't cleaned it properly and bought a new dispenser assembly; this is a big part with the dispensers for detergent, softener, and bleach. I replaced my softener dispenser cup with the new one. Same problem. Help.
Optional Information:
Make: Bosch Nexxt 500 Series
Model: WFMC3301UC
Already Tried:
I stated my case in my question, but I did disassemble the dispenser cup. There is no blockage. It looks just like the new dispenser cup in the new assembly I bought. I also have only ran bleach through the detergent dispenser 2 times in 3 years.
Status: Awaiting Expert Reply Value: $28 Answer 10/25/2009 at 3:26 PM (2 minutes and 40 seconds later) if the dispenser is clean, then you need to replace your cold water electronic water valve. This water valve has 2 solenoids. Once for the softner and one to fill the tub. The solenoid that fills the tub can be working normally while the softner solenoid will fail to open as far as it needs and will either not send water into the softner compartment at all, or will only fill very slowly leaving diluted softner in the compartment at the end of the cycle. Here is a link to the part you need to replace. This is the part that the cold water fill hose connects to on the back of the washer.
Here is the link to the part with its description. Good luck! http://www.repairclinic.com/SSPartDetail.aspx?s=t-WFMC3301UC-%3d%3di1105556&PartID=1105556
Jul 28, 2008 | Bosch Washing Machines
Bleach and softener dispensers filled with water at end of cycle
Yes, remove the dispenser tray by pressing on the button on the softner and pulling out tray completely. Now lift the flap over the softner compartment and clean thourougly with hot water, making sure all tubes and holes are free from residue softner/detergents. Replace flap by making sure the bigger tube fits OVER the smaller tube and click into place. Replace tray. Water is present due to the "syphon effect" of the dispenser not working, caused by residue detergents blocking the tubes/holes. Oshie
Oct 28, 2006 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
186 people viewed this question
Top Washing Machines Experts
Richard Roth
Richard Roth
