My ac is running but no air is coming out - Heating & Cooling
  • 52 Answers
Your a/c fan is not working. It's either the belt is broken or the motor.
Posted on Jul 20, 2008
RV. when furnace is turned on , fan on rooftop AC unit runs continually
i would say its the relay board or communication cabl between stat and board.
Jun 18, 2014 | Dometic Rooftop RV Air Conditioner
1995 Oldsmobile 88 Royale - AC Issues
So the ac is not working. Is the compressor running when you have the control set for ac ?
Jun 27, 2013 | Oldsmobile Eighty Cars & Trucks
My central air unit comes on but it's not cool and
to me it sounds like filter are dirty, need to be cleaned or replaced, home systems, packaged or otherwise are hermetically sealed and should not need freon recharge. Always start with airflow and/or unit being set too low. An AC unit of any type will build ice if a) the filter is plugged up and can't move enough air, b) it has been run without the filter, clogging the coil, again, not moving enough air, c) setting an AC unit below 68 degrees F will almost ALWAYS cause icing, and d) running a standard AC when it's warm inside and cold outside (unless equipped for "low-ambient operation"). When in doubt, a bit of maintenance(thorough cleaning) by someone with AC skills can cure a b, common sense will cure c d.
Reply
Jun 23, 2011 | Goodman CKL42AR42 Air Conditioner
When we turn on our split AC, outside unit is not turning ON
The blinking light is because the unit is waiting for the outdoor unit to come on. If in heating mode, the indoor fan will not run before enough pressure and therefore heat has built up. You should check that the indoor air return sensor is not faulty and therefore preventing the outdoor unit from coming on.
Nov 15, 2009 | Amcor NanoMax A12000E Portable Air...
1990 model RUUD AC unit. Fan runs, no cooling
Is the outside unit running? Fan and compressor?
Jun 29, 2009 | Heating & Cooling
Freezing up, home ac unit no air flow after running a while
A low freon level in the unit can cause them to freeze up. Are the fins behind the filter clean?
Jun 19, 2009 | Whirlwind FH-778 Air Conditioner
Compressor will not stay on
do you know if the fans are running constantly? and if so when the compressor comes on it trips out and the fan remains constant? i would like to know the running amps are they correct.
Jun 08, 2009 | Heating & Cooling
Keeps tripping breaker when running ac
you need to check that the breaker it rated high enough for the ac unit
Jun 04, 2009 | Dometic Rooftop RV Air Conditioner
AC running but no air is coming in
hi,
Check your furnace fan. The air conditioner unit can be running but the air circulation is usually done with the fan on the furnace. If you have a fan switch on the thermostat, check to see if it is in the auto position. If it has the settings on/auto/off, you can switch it to the on position and see if you get any air movement then. If not, you could have a broken belt.
May 29, 2009 | Dometic Rooftop RV Air Conditioner
AC working but no air coming in the house
Unit iced up or bad fan or fan relay. Goodmans have time delay fan relay and they go out often.
May 29, 2009 | Goodman CLJ30AR32 Air Conditioner
Heating & Cooling Logo
49 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
