Question about Canon i860 InkJet Photo Printer
Prints mostly purple & black
My Canon i860 has been suddenly and more aggressively printing purple and black rather than the proper colors. Naturally I've tried all of the maintenance procedures built into the software but the problem doesn't go away. For almost as long as I've owned the printer (4 years?) I've used the Staples ink cartridges instead of the Canon cartridges (too expensive), but have not had a problem before with them.
  • bethgothmann Aug 27, 2008
    In some programs (Microsoft Excel) we can print in black - in others (Microsoft Word) all we get is purple. The blacks in photo printing is messed up (almost velvety) - all other colors seem to be fine. We've done printer maintenance, performed printhead cleaning, deep-head cleaning and have put in new cartridges.
After long uasge the printheads can become clogged and need to be replaced.I buy my replacement print heads on Ebay,but I suggest you compare prices and shipping before you buy.
Posted on Jul 25, 2008
Hi there I have the original canon cartridges in the printer and they all have lots of ink in them, but suddenly when printing the 'black' parts of a photograph looks purple. But when I print text in...
When you are printing a photograph, the back is resultant of combination of RGB but when you print a latter of document it usages only the black ink. So since the black is properly printed when it's combining RGB that means any of the color is low on ink. Replacing the color cartridge will solve the problem for you.
Mar 15, 2011 | Canon Pixma iP4500 InkJet Printer
My Canon I860 has stopped printing any of the colors. When printing a color picture, the printing takes an extra long time and then only the black colors are printed.
To solve the problem follow the mentioned stages bellow:
1.Click start, then printer and fax icon
2.click maintenance tab, then clic ink cartridge setting
3. Select auto dedection or Black and colour cartridge.
Then cloge all.
Thank you.
Aug 27, 2010 | Canon i860 InkJet Photo Printer
Printing wrong color
bad ink, try with original cardridge or use a profiler.
Feb 04, 2009 | Canon PIXMA iP1600 Printer
Prints suddenly red & cleaning doesn't help
The Color printer catridge ink might be low . You nned to replace.
Dec 15, 2008 | Canon i860 InkJet Photo Printer
Canon i860 won't print deep colors
I had similar problem: everything muted and with brownish tint. Tried everything, finally discovered that I installed wrong cartridge: 6PC instead of 6C. The "photo" cartridges are pretty much the same, make sure you have the right ones: 6C, 6M, and 6Y.
Nov 17, 2008 | Canon i860 InkJet Photo Printer
Canon MP 730 prints wrong color tones
I was having a similar problem-- what was happening was the print cartridge head seemed to be letting the colors leak into each other. (the science behind this is beyond me!)-- I noticed that instead of being cyan/magenta/yellow, my yellow cartridge had actually turned green, magenta was picking up blue and was turning purple, etc etc. I ended up replacing the printer's printhead and all the color cartridges and then it worked.
You can order printheads online.
Not sure if this fixes the original reason why they got all mixed up in the first place-- if the printer will continue to allow the print head to leak the colors into each other-- but hopefully that's a fixit!
Aug 10, 2008 | Canon SmartBase MP730 All-In-One InkJet...
Purple Color Printing in b&w mode
When you do nozzle cleaning there is a print test that canon performs. I think it prints out each color. Did the Colors come out correctly? Cuz from there I think you can determine which color is really clogged. I have the solution somewhere but I need to know if the test print comes out correctly or not.
Jul 22, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
One color
yep, print head needs proper clean, here it is.
OK, Canon will hate me for posting this.
1. Remove ink cartridges
2. Remove print head
3. go to sink or tub (stainless steel, not plastic type), pick up a roll of paper towel on the way.
4. Fold several layers of paper towel and place on flat surface.
5. Run hot water until HOT!
6. Turn hot water back to a dribble.
7. Run the dribbling hot water through print head, be careful not to wet the gold contacts.
8.When water running through print head is clear, place print head on paper towel.
9. Repeat number 7 and 8 until no colour shows on paper towel.
10. Gently DAB print head (DO NOT WIPE) inside and out with dry paper towel until dry.
11. I normally replace print head after drying, but you may wish to let it air dry overnight.
12. Replace print head in printer and install cartridges
13. Start printing.
I do this to all 4 of my Canon printers every 6 months or so.
If any colour fails to print after this process it means your print head probably needs replacing.
Jun 29, 2008 | Canon i860 InkJet Photo Printer
My ip90 Canon printer only prints in purple
Try selecting an option in the printing properties to print in grayscale or black and white (you usually only have either one or the other). This will utilise ONLY the black cartridge, the color will remain dormant which should make your prints come out in black and white - if not, your black cartridge, or the space between the bottom of the black cartridge and the paper is contaminated with color ink. Good luck!
Sep 07, 2007 | Canon PIXMA iP90 Mobile Printer
Canon i860 InkJet Photo Printer Logo
158 people viewed this question
old marine
old marine
