Question about Dell Inspiron 1525 (dndppa1_3) Intel Core 2 Duo T5550 (1.83GHz/667Mhz FSB/2MB cache) 120GB/3000MB PC Notebook
Cd drive my cd drive will not stay shut it keeps popping open
    Genius:
  • 2,028 Answers
This has to do with a malfunction in the ejection system in the drive. Sometimes this can be caused by a little dirt or corrosion on the mechanism, however, a majority of the time the problem cannot be fixed and the drive has to be replaced. Start by removing the drive from the machine, taking it apart, and cleaning the inside where the ejection mechanism is. If cleaning doesn't work, then I'm afraid you'll have to replace it.
Posted on Jul 20, 2008
Door won t stay closed
The door catch is down or has lost a spring inside the hook
No simple fix but too replace door latch inside
In order to drive car with door that way no back seat passengers till fixed but use tie down ratchet straps from door to door inside handles
This will keep door shut then can drive vehicle normal till door catch is fixed its simple hour job to replace just buy parts have mechanic shop install
Sep 08, 2014 | 2000 Toyota Camry
Emachine desktop pc dvd/cd drive keeps opening
Here are a few possible solutions:
  1. Check your wiring and connections for cracks and dirt. Spray the connection and the tracking laser (looks like a little red or green led light) and wipe with a lint free paper towel.
  2. Have Microsoft perform a free diagnostic scan and fix. It requires only three easy clicks on your part. CLICK HERE.
  3. Replace the cd/dvd drive. A tutorial video is linked below.
May 26, 2012 | E-Machines eMachines Desktop PC
CD player on PC keeps popping out. When I shut down the PC I have to hold the door closed to keep it from popping back out. And when I start it up in the AM it pops out and stays out. Sometimes it just...
I had the same problem once turns out the techs told me i needed to update the device firmware.I did,,,,, it worked.... then it started to do the same thing again.So i replaced the drive.
Good luck
Sep 11, 2009 | Computers & Internet
The door will not open and eject the cd. the amber light stays on all the time
Try going to "my computer" and right click on the icon that shows your cd drive. Then select eject to see if the cd will eject.
If it does not, then shut down your computer. Look for a small pin hole below your cd tray. Unbend a paper clip and insert it into the hole and press. The cd tray should pop open so you can remove that cd.
If the problem continues then it's time for a new cd drive.
Hank
Jun 29, 2009 | Computers & Internet
Cd tray is stuck in open position on my HP computer
In Some Cases The Button May Be Stuck In Causeing It To Keep Pushing It Open In Other Cases The Arm May Just Be Stuck To Extending The Tray Out. I Recommend Seeking A Computer Technician If You Do Not Know Anything About Computer Componants
May 12, 2009 | HP Computers & Internet
I have a Sony AR230GSeries and all of a sudden the cd tray will not stay shut, it keeps popping open. Thanks
A gear has jumped track or the insert sensor is malfunctioning. These are cheap, and you can do it yourself. Go to the Sony support site to order the part.
Mar 27, 2009 | Computers & Internet
Tje cd rom isn't working properly
your cd rom motor needs to be replaced..so it is better to take it to nearest service center...
Jan 04, 2009 | Gateway Computers & Internet
Cd door will not stay shut
There might be some problem in ur CD rom motor that control the tray eject,,so u have to take it to nearest service center..
Dec 09, 2008 | IBM ThinkPad R40 2722 Notebook
I'm having several problems 1 I can't defrag hard drive it shuts off. 2. can't download because it shuts down unless you keep moving mouse. 3. opening screen user account control pops up can't get rid of...
You may have a voltage problem, but it seems more like you have your power-save settings saved wrong. Check those. You may also want to check your device manager to make sure things are malfunctioning causing your shutdowns.
Aug 14, 2008 | Gateway Computers & Internet
Opening CD/DVD Drive from the screen
none. it is already a hardware faliure. it can only be opened by your bare hands.
Feb 22, 2008 | HP Compaq Presario R4000 Notebook
Dell Inspiron 1525 (dndppa1_3) Intel Core 2 Duo T5550 (1.83GHz/667Mhz FSB/2MB cache) 120GB/3000MB PC Notebook Logo
59 people viewed this question
Alun Cox
