Ge washer it's a washer not a fridge
    Master:
  • 382 Answers
yeah i know its a Washer..As far as it spins with a certain amount of you can be sure the gear drum is not broken!!..Thank you!!..Dont forget to rate the solution in premium zone!..thank you buddy!!..
Posted on Jul 20, 2008
Samsung side by side refrigerator not cold
Defrost problem. If ice builds up on coils behind the back panel in the freezer it will prevent cold air from being blown to the fridge.
Nov 23, 2017 | Samsung Refrigerators
O have a GE Fridge Model GFSS6KKxass i am having a issue with water accumilatimg under the both crisper drawers not sure what is causing this?
My GE Fridge did the same and the repair man I called said there is a little drain hose that goes from the top to the bottom of the Fridge at the rear see if that hose is plugged. I unfastened it at the top and blew air through it and the water is no longer a problem.
Jul 19, 2014 | GE Refrigerators
My GE TFX22Z has served me well over the years. Recently, I noticed that the refrigerator side door has lowered about 3/4 of an inch when compared to the freezer side door. In other words, they no longer...
from the description given I came up with;
possibly the screws are lose on the top door hinge, the top or bottom hinge is worn, the door is warped or damaged.
Aug 21, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
GE top loading washer Washer wwse5200- Agititation?
it is a "trany" problem...just buy a new washer or it is a plastic cap inside that spiral part, that cap have groves...it is maybe goes bad....
GE as a brand has a lot of problem with washers, dryers, microwaves and fridges...and dishwashers so try to stay away of repairing or buying a new GE....
Sep 05, 2009 | GE WWSE5200B Top Load Washer
Fridge always running
Check the fan which cools the compressor from behind the fridge . If not working , replace the fan motor . ALSO , check to be sure the coils under the fridge are clean of dust (from the front only ) .
Aug 01, 2009 | GE Refrigerators
Suddenly our GE side-by-side fridge door doesn't shut
Check the bottom of the freezer door at the hinge to see how it is suppose to look and work, assuming the freezer door still works right. Then look at the ref. door and compare.
Sounds like something is broken or damaged. Usually there is a white tefflon washer which is beveled to allow the weight of the door to help it close. Check with an appliance parts store, you may be able to buy just the washer or the whole hinge assembly may come in a package.
Jan 25, 2009 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Iced up pipe in back of ge side by side refridgerator
Hi there, yes this will happen when the fridge has been over charged with refrigerant. :) If fridge under warranty get them to come and have a look :)
Sep 07, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge Fridge freezing in fridge area
The freezer should be set to 0 degrees and the fridge 37 degrees according to the manual. If your unit has only numbers then it would number 4 or 5 for the freezer and 6 or 7 for the fridge.
Jun 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Pos ge washer WCSR2080B
Sounds like u might be having trouble with the lid switch.. U need to also check you water pump out.. this model has a electric pump that may be plugged... dont take much to plug this pump up.. have you taken front panel off yet ? Post what ya find
Oct 16, 2007 | GE WDSR2080D Top Load Washer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
