Samsung pcj522r Could the board that plugs into the bottom of the blue crt throw off the convergance at the top and bottom of the screen?
  • 8,617 Answers
No but the board which is on the upper neck of the green CRT could its the velocity board which has an effect on all 3 tubes convergence.
Posted on Jul 20, 2008
My Samsung 52" Older Big Screen went out. When I plug it in, it makes a funny sound like it's trying to come on then starts clicking sounds like a cricket noise. any ideas??? model pcj522r
The convergence is dead.It cause 3D colors misalign
and clicking chirping noise with no power on.Know how how to solders?The 2 Convergence ICS must change and all it resistors. Tries Tv Repair World.com,Tvrepairkits.com for the convergence kit to repair it ur self.The shop will cost $300 for parts and labors.
Feb 07, 2010 | Samsung PCJ522R 52" Rear Projection...
Samsung pcj522r
If they tested the convergence board and thats ok, the only other Items it could be are the Digital convergence unit or the Velocity comando units that control the convergence yokes. If the convergence isnt adjustable with magic focus adjustments wont help it. Is the repair shop an authorized samsung repair facility? If you need more assistance let me know.
Jul 26, 2008 | Televison & Video
Samsung pcj522r
That sounds like a solder issue on one of the CRT drive circuit boards. Check the CRT boards for bad solder joints especially on the socket connections.
Jul 23, 2008 | Televison & Video
Samsung pcj522r
Check the Blue CRT pcb for solder cracks especially around the tube socket
Jul 18, 2008 | Televison & Video
Samsung pcj522r
Not really, its possible that the Convergence yoke rings may have gotten misaligned when installing them onto the replacement Tube. Usually you need to realign when installing a new tube.
Jul 16, 2008 | Televison & Video
No blue manual convergence - Samsung pcj522r
Thats a very strong possibilty the phosphorus may be burned off the CRT face. Does the blue project when powerd up and looking in from the raer of the set? Look into the blue CRT lens while its playing If you can see a clear picture I would think that you have some open resistors in the blue circuit, If you cant see a picture its time for a CRT. If you need a CRT let me Know I have a good source for them Used.
Jun 21, 2008 | Televison & Video
No blue convergance
need to replace the convergence ICs. If you need a link to get replacement ICs let me know.
Jun 07, 2008 | Samsung PCJ522R 52" Rear Projection...
Convergence Problem
I'm not a 100% positive this would fix your TV, but I found the convergence board on PartStore.com for about $80. Hope this helps.
Nov 16, 2007 | Akai PT5598HD 55" Rear Projection...
Samsung PCJ522R Pictures is completely shaded with yellow
Everybody here seems to have basically the same problem so I will write a general fix for these Samsungs. First what you got is known as Convergence failure, A Ic or resistor, fuse or some other component has failed in the convergence circuit. So finding the service menu and trying to align the colors or spinning magnets on the CRT’s or a real bad idea of tipping a CRT or mirror would be the equitant of ripping the transmission out of your car because it had a flat tire. When the convergence fails no adjustment will bring it back, and if you do one of these stupid things then you have two problems. Now most of these Samsungs have an easily replicable board that all the convergence amplifiers are on. This can be found by removing the back and seeing if there is a board about 9 X 5 inches big and mounted to the CRT mounts, there will be 5 connector to this board. Now if your set does not have this board and instead has the two convergence Ic’s (these are about the size of a playing card and have the numbers STK392-040 on them) mount down on a board below and to the right ( this is known as the deflection board) this repair will not work for you. Instead you will need to component level repair the convergence circuit. But if you do have this separate convergence board the repair is fairly straight forward. Go to www.vancebaldwin.com or some other supplier and order BP95-00142E this is the convergence board. This board has been crossed several times through the years but this is the current version. Now once you get this board simply replace it making sure to get al the connector back in there original spot. The fire up the set and run Flash focus and for about 95% this will fix the set
Oct 25, 2007 | Samsung PCJ522R 52" Rear Projection...
Sony kp-51sw500
Jul 21, 2007 | Samsung PCJ522R 52" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
