Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. It still can be repaired.
Using your original remote go-to the settings menu then goto the convergence section. Try to adjust the red and then the blue convergence. You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight. If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem. Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix Reply
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. If you have never done this before we would advise calling a technician or if you want to do it yourself get a complete kit with instructions and support from TvRepairKits.com Their kits include a step by step instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.Thanks! hope you rate my response
