Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
Washer dryer doesnt heat and washer stoped working the water its in it can not empty it
  • 1 more comment
  • Frawa Jul 25, 2008
    Hello, I have the same problem with my whirlpool thin twin:
    the dryer doesn't heat anymore and the washer only get water, after that, nothing hapens. Another strange thing is that the washer only "works" (just get water!) when the dryer is on.
    I guess you know well this product, can you help me please ?
    Thank you
  • melnkids Sep 15, 2008
    my washer quit working over a year ago, same thing, it filled, then wouldn't empty, wouldn't agitate, nothing...then last night, my dryer stopped heating. It has been working perfectly for over 2 years, but last night, it just stopped...
  • botbotbobot Oct 12, 2008
    washer doesn't work
  • 734 Answers
I am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 12, 2008
My dryer stops after a few minutes and all the lights flash. It stops turning and doesnt get warm or hot in that time. I have cleaned all filters and emptied the water. Can anyone help?
I believe it has something to do with the computer circuitry. You might try to reboot it. Unplug your dryer for a few minutes, plug it back in and see if that works. It did for my washer. Good luck.
Feb 07, 2015 | Dryers
Water in my dryer when it is empty
Sounds like your problem might be the washer not spinning the wash enough not the dryer unless it is not heating properly.
Aug 23, 2017 | Maytag Dryers
WIDL102 indesit washer dryer not working properly
check heater element/ should read about 32ohmns on multimeter if not reading replace,if ok replace stat
Apr 03, 2010 | Indesit W 123 Front Load Washer
Our Bosch Classixx Condenser Tumble Dryer works but there is no heat. I have cleaned the Condenser Unit and the filter and emptied the water, but still no heat. Please advise. Thanks Craig
my wte84105gb condenser dryer (bosch) as a symbol on it looks like a glass with wavey lines inside it will not dry please advise what to do .
Feb 26, 2010 | Bosch Axxis WTA4400 Dryers
Timer Stoped Working,and Wont Shut Off And Doesnt Heat Up
most models will not advance the timer if it is not heating.sounds like you have a bad heater element ot thermometer's staying open.
Jan 30, 2010 | Kenmore 73952 Gas Dryer
It is very cold in my garage where my Fisher and Paykel washing machine is. First it would not fill it just ran and ran without filling, then it started filling fine, but then after a while started...
water freezes. sounds like first your fill pipes were froze then the pump froze. if you can find a place inside the house for washer or you may have to build a room around washer and dryer and heat it
Dec 13, 2009 | Fisher and Paykel GWL11 Top Load Washer
My tumble drier dont heat up. It works but its
there will be a red overheat switch on the rear on most models, simply pull the machine out and press reset, the most cpmmon cause is running when empty or a build up of lint. if the doesnt work then it will be an open circuit element.
Apr 13, 2009 | Dryers
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
159 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
