Question about Apple iPhone Smartphone
My iphone doesn't startup
When was turning off then on my iphone it doesn't turn on just stop at the apple sighn on the screen.what do i have to do please.thanks
  • Anonymous Feb 17, 2009
    I have an older version Iphone i somehow restored it and it turned off now i cannot turn it on neighter it connects to the computer it just stops at the Apple sign...i hope someone could help me out.
  • seifedino Feb 18, 2009
    when i open my iphone it doesn t open it just stops at the apple acon what cn i do plzz tell me
Connect the iphone to the computer open itunes and restore
Posted on Jul 21, 2008
My screen not working
its Hardware issue check display connector and belt
Aug 02, 2014 | Apple iPhone 4 Black Smartphone
hello,ensure you are not clicking on the key wrongly,i would advice you put the phone off and on back to see if the problem stops.if it doesn't i would also advice you ensure you close any application you are not making use could also be as a result of accumulated opening of applications. if that does not stop the problem,i would suggest you get the phone flashed by a mobile phone authorized repair engineer around you.
wish you good luck,
take care.
Jun 30, 2011 | Apple iPhone 3G
Replaced iphone screen because of cracked glass.Put every thing back together and wont turn on.Tried everything and shows no sighn of life.Doesnt even register on the computer.
You most likely didn't connect a component to the board or one of the ribbon cables. I'd go back into the phone and follow the steps again to try and determine anything that wasn't connected as well as you'd thought.
Jan 29, 2011 | Apple iPhone Smartphone
My phone freezed,I can't even have access to it,
do a soft reset, hold the power and home buttons at the same time until the phone turns off, keep holding until the apple logo shows up, then you can release and let your iphone boot. this will work great.
May 11, 2010 | Apple iPhone Smartphone
The apple appears on the screen and never goes away. 3GS
Turn the iphone off, hold the menu button, now plug in the usb cord that is connected to the computer. Keep holding the menu button until a dock connector appears on the screen. You're now in recovery mode and should be able to restore your iPhone. If that doesn't work you may have a broken logic board. Here is an iPhone Repair Guide that shows how to open an iPhone. Boards are easily available on Ebay2_bing.gif. If you want somebody else to do it for you go to iPad Repair
Mar 09, 2010 | Apple iPhone Smartphone
My iphone 2g only shows the apple for 10 seconds then shuts down
Try restoring's how...
  1. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  2. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  3. Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
    Note: If you see the message "Charging... Please Wait" , let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
  4. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  5. When you see "Connect to iTunes" on the screen, you can release the Home button andiTuneswill display the recovery mode message:
    If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
After this you'll need to jailbreak it too....
Sep 04, 2009 | Apple iPhone Smartphone
My iphone wont charge/turn on/turn off
free tutorial on how to jailbreak and unlock iphone here on my website and many other iphone tutorial are available as well..
Hope it helps
Jul 03, 2009 | Apple iPhone Smartphone
My iphone 3g is frozen on the apple sighn how can i fix? it i already tried to reset it on itunes but it sais there is an eror pleas help me....
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 04, 2009 | Apple iPhone 3G
Non responsive touch screen on iphone
i guess ull jus have to replace the screen
Dec 08, 2008 | Apple iPhone Smartphone
If a hard reset (press menu and center button together for 5 sec) and software restore doesn't cure it , you have a broken digitizer of your iPhone screen assembly. There is an iphone repair guide website that shows you how to do the replacement yourself and a third party iphone repair company that can do it for you.
Apple iPhone Smartphone Logo
65 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
