Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Cruzer Micro 4GB won't Light or be recognized in any USB port on any computer
Is there a recovery process for this smart drive? Is there a self test for it? Problem is there is no connectivity to initiate a self-test and I have 4 computer systems (XP/Vista) that refuse to acknowledge its presence.
  • 101 Answers
Some time self test is not working just cheack it self test option is working or not please try it as normal pen drive then select again the more options
Posted on Jul 23, 2008
When i plug my 4g cruzer micro usb memory stick nothing happens the cpmuter dosnt read that it is plugged in
Try a different USB device on each of the USB ports on your computer.
Hopefully, all your USB ports are working correctly.
Try a different USB port on your computer.
Hopefully, the SanDisk will be detected on one of the ports.
Try a USB port on a different computer.
If the SanDisk still is not detected, then spend $10 to buy a new 4GB flash-drive.
May 22, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
My usb sandisk 4gb cruzer micro has ' not recognize ' and my usb port is working well.
Try on other computers with a Windows 7 or linux. If not working on other computers as well, the drive is damaged.
Aug 07, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Device not seen by computer
Try inserting the device into another computers usb port, if the symptoms persist there is most likely an internal issue with the cruzer. If you need the data on the device contact a professional recovery service like http://happydatarecovery.com
Mar 30, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I plug in the sundisk cruzer 2.0 GB USB device and all it does is blink. It will not show up on my computer for the drive.
Hello
If the computer recognize that there is a device plugged into the system, then just try to plug the flashdrive into another port at the back of your case.
If the computer does not recognize that there is a device plugged in, there is a problem with your flash drive. It still gets power from the computer(Bliking light), but there is no data transfer between computer and flash drive.
If it is still under warrenty, send the flash in for repairs(presuming that your USB ports work), otherwise try and see if it works on a other computer. If it does, the the problem is with the USB ports on your computer. I really hope this can be of help.
Best regards
Andrea
Oct 28, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
San Disk Micro Cruzer 4GB
Try plugging it in to a different USB port on your computer. Make sure the connecter on the Cruzer is clean and there's no dust inside.
Also, try plugging it in on a different computer.
If none of these work,
I'm afraid it's a hardware problem and there's nothing that can be done about that.
Hope I helped!
Tom
Jun 20, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Sandisk 4GB cruzer micro usb
Are you connecting it to the back of your computer? Sometimes the port in front does not have enough power to power it on.Also please try another computer
Feb 12, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
SanDisk Cruser Micro
sounds like the usb ports on your computer are going dead.. You may have to use your drive on another computer to retreave data then put it on cd..
Nov 21, 2008 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
SanDisk Cruzer 4Gb not found on XP
I have the same issue. I have found a temporary solution though. I have a Sandisk 4GB Cruzer and an HP Laserjet 1022N connected VIA USB. When I uninstall the USB Printing support driver from Device Manager then plug in the Cruzer it recognizes it right away. Not quite sure why this would happen though
Apr 02, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Cruzer micro 4GB, unreadable in USB ports
sounds like your USB connector of the flash drive is damaged. Could be a loose/broken solder joint, or one of the pins on the USB connector could be damaged.
If it was my drive, I would open the case, solder a new connector on the board and backup the files.
Nov 09, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
75 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
