Question about Acer Aspire L100 PC Desktop
Removing L100 hard drive
Hi my L100's hard drive is nadded (technical term) I'm planning on removing the hard drive putting it into an external sata case thing so I can recover some files of it. I've opened the case but everything is so tiny and I can't see how to remove the drive. Instructions would be much appreciated.
Thanks
- Angie
    Problem Solver:
Remove the front panel by gently lifting the three flat plastic tabs. Remove one screw at the corner of the disk drive and lift the disk drive and DVD drive upward by the plastic handle on top. Disconnect the two SATA connectors from the disk drive by simply pulling them off. Disconnect the ribbon cable from the DVD drive gently lifting up on the black tab at the ribbon connector. This is hinged and releases the ribbon cable.
The unit is now free and you can turn it over and remove the screws securing the disk drive.
Posted on Aug 04, 2008
How do i put my hard drive inside? me
Open the external case, by removing some screws, and sliding the cover away from the insides.
Connect your disk-drive to the "power" and "data" connections, and secure the disk-drive with the mounting screws. Close the case.
Jul 25, 2011 | BYTECC ME-350V4-ISA SATA or IDE to USB 2.0...
Windows detected a hard disk problem
Hard drives fail very often in computers. You can sometimes save your personal information by removing the hard drive and installing it in an external enclosure, and then accessing the drive by usb from another computer.
SATA hard drives are low priced and very easy to replace. You can order a new one at Amazon or NewEgg.com. Make sure you are getting the correct size (desktops accept 3.5" drives and laptops use 2.5" drives).
May 05, 2011 | Samsung M7E HM321HI 320 GB SATA Hard Drive
Hd will not spin up, Green light blinks. Can I fix this issue
The simple way is to TEST the drive by removing it from the enclosure and trying it in a regular PC that has the same interface either SATA or IDE
If that fails to read the drive then the drive itself is probably dead.
Also double check you are using the cable that came with that drive as not all cables are the same on some of these things even though they look identical.
If you hear clicking at all this would indicate a dead or dying drive.
Sometimes the fix is simply removing it from the case and putting it back in.
Feb 26, 2011 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
My samsung sata hard disk HM120JI is not working fine. Windows is not coming up. I have replaced the hard disk and now want to copy data from samsung sata disk to the new disk. Could you please tell me how...
You can buy a SATA dongle that plugs in to the hard drive and plugs into the USB port on you computer $20 or buy a external SATA case to put the hard drive in $40 at most computer retailers.
Feb 06, 2011 | Samsung SpinPoint M60 HM120JI 120 GB SATA...
Hi, i have the noted type hard drive and i have just moved house. since then my hard drive wont connect to my pc. the light comes on and every thing looks ok but she wont connect. my other hard drive works...
does it just beep and is not reconized by your P.C.? if so continue to read,
If you get no joy using the Troubleshooting Guide then try this...
don't worry if you are a novice like me, the thread is very easy to follow.
Look inside your P.C. 1st to check SATA data connection type.
eSATA is a different connection from SATA so you might need an eSATA data lead if you follow the guide in the link, not sure if it just external connections only and plain SATA connection inside.
Google image 'eSATA' data lead/cable and you will see the difference between the eSATA and SATA connection if you don't already know.
My neighbour has the Seagate FreeAgent Desk 500GB, and in under 2 weeks it started to beep and was not reconized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t​=84 Thread can be found in 'Technical' under 'General Technical Issues'
Aug 18, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Screen does not light up
Hi
disconnect the power cable and remove the battery nad then press nad hold the power button for a minute. then connect every thing back and then see if the screen comes on.
in case it does not then again remove the battery nad power cable and remove the hard drive nad ram and put it back in again.
nad then check still does not work see if the screen comes on an external moniter, still if it does not come on call HP if it is under warrnty they would give you free repair.
Apr 12, 2010 | HP Pavilion dv2000t Notebook
Im planning to buy an external disk drive. Can i store games in it? dadz
In terms of storage external drives work the same as internal drives in there ability to store anything.
Jan 02, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor one touch iii unable to read drive; the external hard drive previously worked and now it doesn't read the drive
please remove the raw drive from the casing
it may be a sata drive of maxtor please power it up directly to your pc with a sata power and sata cable
the drive will get recognised .
if it gets recognised it means the interphase between the disk and the ext casing has been damaged
if you fail , the disk has lost its firm ware or rom chip rom bin file.
both can be flashed and recover the drive
BEcaerful you can break the plastic casing while removing the raw drive as it had been machine dyed and fixed and you may not find any screw s outside
datarecoveryfactory
Sep 04, 2009 | Maxtor OneTouch III FireWire 400 (F01G500)...
Trying to install hard drive on Dell Dimension 8200.
Sounds like the drive from the 4700 is a SATA drive which uses a different connector than the 40-pin IDE. I couldn't confirm it, but the 8200 may not have SATA connectors for this type of drive. Although the 4700 appears to have both SATA and IDE.
Dec 07, 2008 | Dell Dimension 8200 PC Desktop
Hard drive
at first you have to check it out, whether your hard drive is related on ide or sata. sata is the new technic used now in the recent years. ide is the old technic that comes with the wide bus cables. but sata is a small red colored cable that transfers data more faster than ide.
after that, you have to check it out the mother board settings for connecting with sata cable. because, the older pc have no more settings for sata. if it is available means, no problem to update your hard drive. or you can just go for external hard drives.
Jul 21, 2008 | Dell Dimension 4600 PC Desktop
Acer Aspire L100 PC Desktop Logo
206 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
