My Vaillant ecotec 415 boiler is reading F.22 on the display and i can't seem to get any hot water. Any ideas please?
4 Suggested Answers
zeusfaber
  • 247 Answers
SOURCE: Vaillant Ecotec combi boiler -
David,
The fact that you're getting a little burst of domestic hot water suggests that the boiler is capable of circulating hot primary loop water through the heat exchanger, but doesn't necessarily do so when it needs to.
What seems to be lacking is a recognition that domestic hot water is now being drawn off, and that the boiler needs to fire up and divert the primary flow through the heat exchanger.
A good place to start might be the flow switch (usually in the bottom of the boiler, where the cold water supply comes in) or the electrical connections to it.
A.
Posted on Oct 07, 2008
SOURCE: my vaillant boiler is displaying
Have you topped the system up with water? The pressure gauge should be showing an operating pressure of 1.5 Bar in the green section.
Posted on Jan 13, 2009
  • 30 Answers
SOURCE: Vaillant combi boiler problem
when the tap is turned on and the water light on the boiler doesn't this means the diverter valve is not operating it could be down to low water pressure in the house this can be checked at the cold tap in the kitchen. if there is plenty of pressure then it could be the diagphram in the diverter valve is worn or split. the diagphram is only a few pounds but it depends on the engineer you get as to how much money he wants to fit it.
the egg timer symbol (or two pyramids together) is an ignition indicator turn off and on again to see if it will fire with the tap running. reset the boiler with the lower right hand control knob.
Posted on Mar 26, 2009
Boiler vaillant ecotec 824 R1 no power
USE A ELECTRIC METER AND CHECK FOR 120 VOLTS AT CIRCUIT BOARD AT LINE IN AND COMMON , IF YOU DO HAVE 12 0 VOLTS THE LOOK FOR TAPPINGS FOR 24 VOLT OUT PUT MAYBE A BAD TRANSFORMER OR CIRCUIT BOARD
Jan 11, 2014 | Water Heaters
Vaillant ecotec plus 824 problems
The Symbols should be there whenever the boiler is in use, it confirms the pump is running and the gas valve is open...i.e firing.
the pump overrun may come on after a firing to dissipate excess heat and is what it says, i.e the pump continues to run to keep the hot water moving to prevent the boiler from getting noisey. Sometimes you may see a radiator symbol which means the boiler is doing a 'heating' cycle as against hot water.
Nov 20, 2013 | Computers & Internet
New Vaillant 360 eco plus boiler, takes almost 3/4s an hour for rads to come up to a decent temp. Hot water is fine. Called out install Engineer who is an excellent tradesman but he says everything
We have just had our old system boiler replaced with a vaillant ecotec plus 837 and sounds like a similar working operation to ours. At first I was a little concerned,but I was told by our installer that he was told by vaillant that these very latest boilers size the system on start up for about 10 mins, then take temperature to target flow which you set boiler at. So even by setting target flow temperature very high you still get the initial sizing cycle, which ours was about 30-35c temp. These boilers seem to run biased for efficiency as after a while they modulate the boiler burner down and the radiators run more on the side of warm than really hot like the old type boilers. You also get better efficiency as at lower temperature the boiler condenses better. You will also find you get a more constant temperature in your home rather than over shoots. I was concerned at first, shame there was no info/explanation in user manual as people do need to know that this is normal operation. We are used to ours now, took a month and by the way these boilers can make a creaking noise but was told this normal expansion/ contraction but annoying when sited in bedroom cupboard. Best of luck!
Oct 27, 2012 | Water Heaters
F22 error/ low pressure
F.22 Dry fire Too little water in the appliance, water pressure sensor defective,
cable to pump or water sensor defective, pump blocked or defective,
pump output too low
May 11, 2010 | Heating & Cooling
Lost my user manual for the vaillant boiler ecotec plus 824 R1
try to enter here all informations and you can find the manual: http://instructions-manuals.com/search.php?cmarque=VALLIANT%20&modele=ECOTEC%20PLUS%20824
Oct 27, 2009 | KDS Valiant 6380iPTD-01 Notebook
Vaillant Ecotec combi boiler - radiators working but no hot water flow to taps
David,
A.
Oct 05, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
