Question about Cell Phones
How do i open the door on my samsung mobile to change battery???
  • Anonymous Jan 13, 2009
    Can't open phone to install sim card
Close your mobile then place two thumbs on battery case and push upwards in direction of arrow
Posted on Feb 18, 2009
Samsung J7 mobile boot well with sound but nothing on the screen just white
turn off the phone , open the back door remove the battery turn the power button on , insert the battery , turn the power on again ... if the problem fixed then...otherwise you have to get to to the repair store specially Samsung repair ....
Dec 05, 2016 | Samsung Cell Phones
I AM USING SOMEONE ELSE'S SWAY & PLAY. HOW DO I CHANGE THE BATTERIES AND WHAT SIZE ARE THEY?
tools needed : 1 Phillips head screw driver, 4 d cell batteries.
as you look at the swing, from the front, you will see a mobile set into the side of the leg on the RIGHT side.
it's the leg with the on off switch.
insert the screwdriver through the hole in the mobile and into the screw inset at the top of the leg. You will see that it's at the top of a rectangular door..this is the battery door.
unscrew the 1 screw and remove the door. the mobile will come off as it's attached to that door. change the batteries and put the door back on and re-install the screw.
hope this helps!
Aug 02, 2013 | Cosco Juvenile Cosco Sway n Play Swing...
Samsung chat 335
Door stop. Time for a new one. It\'s done, sorry.
May 21, 2013 | Samsung Genuine Chat 335 Qwerty Pink...
I have the t mobile samsung D840 and I lost the instractions how to open it to change the sim card kindly can you help tony
Turn off your T-Mobile Samsung phone and place it on a flat surface with the back cover (battery compartment) facing up.
Press down on the phone cover and slide it off toward you. You should see the battery in the battery compartment.
Lift the battery from the compartment and pull it out. You should now see the T-Mobile SIM card in the card slot.
Hold the SIM card and simply pull it out. Reinsert the battery by aligning its gold contacts to the gold contacts in the battery compartment.
Place the cover back on the phone and slide it till it snaps back into place.
Mar 13, 2011 | Tablets & eReaders
I FORGRT MY PASSWORD IN MY MOBILE I CANNOT OPEN MY PHONE
*#06# Show IMEI
*#9999# Show mobile Software Version
*#0837# Show mobile Software Version (instructions)
*#0001# Show Serial Parameters
*#9125# Activates the smiley when charging
*#0523# LCD Contrast
*#9998*228# Battery status (capacity, voltage, temperature)
*#9998*246# Program status
*#9998*289# Change Alarm Buzzer Frequency
*#9998*324# Debug Screens
*#9998*364# Watchdog
*#9998*377# EEPROM Error Stack - Use side keys to select values
*#9998*427# Trace Watchdog
*#9998*523# Change LCD contrast
*#9998*544# Jig detect
*#9998*636# Memory status
*#9998*746# SIM File Size
*#9998*778# SIM Service Table
*#9998*785# RTK (Run Time Kernel) errors - if ok then phn is reset, info is put in memory error
*#9998*786# Run, Last UP, Last DOWN
*#9998*837# Mobile Software Version
*#9998*842# Test ******** - Flash the screenlight during 10 sec and vibration activated
*#9998*862# Vocoder Reg - Normal, Earphone or Carkit
*#9998*872# Diag
*#9998*947# Reset On Fatal Error
*#9998*999# Last/Chk
*#9998*9266# Yann debug screen (Debug Screens?)
*#9998*9999# Software version
*0001*s*f*t# Changes serial parameters (s=?, f=0.1, t=0.1)
*0002*?# unknown Samsung's comand
*0003*?# unknown Samsung's comand
For Mobile phones SGH (R210, T100, A300...)
if Samsung code is in format *#9998*xxx#
try write in this *#0xxx#
SGH-600
SGH-2100
*2767*3855# Full EEPROM Reset (THIS CODE REMMOVES SP-LOCK! but also changes IMEI to 447967-89-400044-0
*2767*2878# Custom EEPROM Reset
Samsung mobile phone codes: Samsung E700
*2767*688# remove USER CODE and SIMLOCK
Samsung mobile phone codes: Samsung V200
Unlocking:
Power on the mobile phone without SIM card and type these codes:
*2767*63342# and press green button
*2767*3855# and press green button
*2767*2878# and press green button
*2767*927# and press green button
*2767*7822573738# press button
Phone will be unlocked, but all trims are reseted !!!
Mobile phone must be fully charged
Samsung mobile phone codes: Samsung S500
Unlocking
*2767*MVT# (*2767*688#) E2P MVT Reset
*#SIMLOCK# (*#7465625#)
Jan 13, 2011 | Samsung SGH-D980 Cell Phone
Sgh e250 not opening
Change the Battery..
more than likely your phone has a dead battery and it doesn;t have the juice to run the phone.
May 22, 2009 | Samsung SGH-E251 Mobile Phone - Black
How to open the mobile to change the sim card
It opens at the back
Look at the back of it,its in two halves
Gently press and slide downwards the bottom half
JonnieC
Jan 22, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Battery
either change the battery or have the mobile reflash.....you can do that online or take the phone to a mobile service center and have them reflash it there for you.
Jan 28, 2008 | Samsung SCH-u740 Cellular Phone
How do I change the memory card for a samsung L730?
open the battery door and push on the wafer beside the battery gently it will release and pop uot some then grab it and pull it out
it has a spring trigger the pushes it out for you
Dec 27, 2007 | Samsung Digimax L730 Digital Camera
Cell Phones Logo
158 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
