Konica 7020 copier
It is an Error code F-35-9 that showed up on my Konica 7020. It asks me to contact a service professional.
I need to bypass this screen temporarily just to be able to print a written "copier count" report for my service company. We will not use the copier until the service professional comes out, but we need the official copier count report to reactivate the service contract.
Can you help temporarily bypass the message just to generate the report? We are contacting a local professional after generating report.
  • eschneider92 Jul 26, 2008
    Bummer. Thanks for responding.
  • 42 Answers
35-9 is a low temperature error in the fuser.If the fuser has a problem it will not make a copy period.Sorry. Mrbonz
Posted on Jul 26, 2008
Konica 7022 error F35-1
F 35-1 pertains to Abnormal Low fixing temp TH1. Try to clean the thermistor and reset the code by entering mode 25, software switch 3-1, make it zero. If the problem occur again, try to replace thermistor. Make sure that AC supply from mains is okay.
Aug 27, 2014 | Konica Minolta 7020 7022 7025 Copier Drum...
Konica 7020
Did you blow it up, probably not.
Click this link for the everything.
http://www.kmbs.konicaminolta.us/content/support/supporthome.html
  1. Choose the Category "Office Systems"
  2. Choose the model "7020"
  3. Click the error next to the Model dropdown box.
  4. Choose the 1876KB user manual called "User Manual for 7020, 7025, 7030 and 7035"
Or click on this link for the specific manual.
The error codes you seek are not in the manual, you'll have to call Konica to tell you what they are ... call Konica at (860) 683-2222.
Hope this helps. Rate a fixya!
Dec 10, 2007 | Konica Minolta DiALTA Di200 Copier
How to reset code 35-3 on photocopier konica 7020
DO THIS once because you are re-setting the FUSER it can catch on fire that will ruin a perfectly good day!!!!! Get a tech out to look at it.
Turn on the main and sub power switches.
Keep pressing the * button until the message
"Please enter service password." appears.
Input 9272 as the password and press the
[Start] key. (The password is fixed and cannot
be changed.)
[Mode Select Menu Screen]
Press 2 and 5 to select 25 mode. Then select soft switch. Set 3, then set 1 then change 1 to 0. to clear the code.
Jun 13, 2014 | Konica Minolta Konica 7020 W/fax Kit...
Error code c3905 in konica minolta bizhub 950
When C-35**,C-38** or C-39**(fusing temperature related
abnormality) occurs, be sure to repair defective parts before
setting DIPSW3-1 to 0. Setting DIPSW3-1 to 0 with defective
parts not repaired results in a fire.
Dec 21, 2013 | Konica Minolta Konica 7020 7022 7025 7030...
My printer Konica Minolta stopped working and showed me an error code F-26-6
The printer stops working & showed me an error code F-26-1
www.fixya.com/.../t16683015-printer_stops_working_amp_showed_me
Feb 20, 2013 - the printer stops working & showed me an error code F-26-1 , How can I repair it ? I think it s relating to a - Konica Minolta 26NA53040 7130 ...
Konica Minolta 26NA53040... Repair Questions - Fixya
www.fixya.com/.../p4700437-konica_minolta_26na53040_7130_7025_...
Konica Minolta 26NA53040 7130 7025 7020 Oem Lower Fixing Roller Assy New ... Theprinter stops working & showed me an error code F-26-1 , How can I ...
Feb 20, 2013 | Konica Minolta 26NA53040 7130 7025 7020...
HI, I have a Konica 7020. It is showing code 'F-35-1'.
Fixing low-temperature error
Set SW2 (sub power switch)OFF and then back ON, after set
to "0" the bit 1 in DIP SW3 in 25mode. (If you switch power back
on without releasing the latch, the error will recur.)
Oct 13, 2011 | Konica Minolta DiALTA Di200 Copier
F-35-4 this is over problem
Fuser error: lamp, thermistor, fuse problem, etc. Part needs to be replaced and code reset in service mode only. Call a tech
Jun 20, 2009 | Konica Minolta DiALTA Di200 Copier
Error Code F-35-6 on Konica 7020
Please call the techie, he would definetely solve the problem, because their is a risk for the rollers to be burned out
Jun 16, 2009 | Sharp AR-C160 Color Copier
KONICA 7020 GIVES ERROR MESSAGE F-35-1O WHAT IS WRONG
hi
error f 35 is fixing error,try to reset on 25 mode
Jan 08, 2009 | Toshiba E-Studio 3511 Color Copier
Konica 7020 Printer
HI,
you need to reset the fuser latch as it has a fuser error code most likely needs new thermisters,
anyways give this a go, hold down 2 and 5 keys together and power on machine, this will put you into to a service mode call 25 mode, go to dip switch 3 and bit 1 and then next to bit 1 hit the key that says turn off,
turn machine off and back on should clear error code, if it doesnt you need new thermisters, even when you put in new thermisters you still need to clear this error in service mode
Regards
Konica Tech
Feb 15, 2008 | Office Equipment & Supplies
441 people viewed this question
jasbo
jasbo
