Question about Kenmore KBC12 Coffee Maker
Replacment KBC12WHT: Model 69327 Want to replace the reusable filter P/N 31047 AND need a phone number for future parts.
  • mwand12348 Jan 15, 2009
    I need to buy a replacement for the filter.
    Problem Solver:
  • 59 Answers
Go to google then click on shopping it is the best way to get items hope this helps.
Posted on Jan 01, 2009
I have Coleman Evcon Presidential furnace. I can't find where is filter. I want to replace it but can't locate it on furnace. is there any?
If the filter is not mounted on the inside of the wall intake and serviced by a hinged door then it maybe located in the air handler directly below the blower fan in a thin tray that is just shy of the width of the air handler and as thin as a 1/2 inch. There is usually a single thumb pull in the center to access the tray. Here's the bad news. Out of the 5 times I've run into this the reusable filter was removed and thrown out, no one knew what happened to it, there were no disposable replacements that thin to fit. I ended up installing an intake vent door that fit standard disposable filters which cost less than going back to the manufacturer for the original reusable replacement part. Hope you find this helpful.Make sure you check the upstairs ceilings for intake filters first before you give up.
Oct 09, 2015 | Coleman Heating & Cooling
Where is the oil filter
The engine oil filter can be in a variety of places depending on the model and type. Sometimes they are direct on the lower engine block and sometimes fitted to an oil filter head which could be part of the oil pump housing or could be bolted direct to the cylinder block.
Some filters are horizontal and some hang down and some point upwards and are accessed from the top. Some filters are canister or spin-on types and some are replaceable paper elements in a removable and reusable metal or plastic bowl or container.
Mar 15, 2015 | Cars & Trucks
How to order / replace motor exhaust foam filter?
Hi, it's Allie from Crucial Vacuum!
Maintaining your unit's filter clean and clog-free is crucial in keeping your unit working properly. Your Dyson DC39 has a washable and reusable pre-filter, part number 923413-01.
Washable filters are recommended to be washed after every 1 or 2 uses and replaced every 3 to 6 months, depending on the use of your unit.
First, make sure your unit is 'off' and unplugged. Remove the dust bin by pushing the button next to your unit's handle and remove the filter from the bin. Wash your filter under running lukewarm water until the water runs clear. Allow your filter to air dry for 24 hours before placing it back into your unit. Do not use any soaps or detergents and only dry your filter naturally. Placing your unit in a dishwasher and/or dryer may damage the filter.
Having a spare filter is a great idea to have while washing the unit's filter.
You can purchase direct your replacement filters from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/dyson-dc39-pre-filter.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Sep 04, 2014 | Dyson Vacuums
I have a Generac 5000 Power Plus 10HP Model 09856-0 Series 401 4891. It works fine but the gas tank petcock leaks. Where can I get a replacement and for reference I'd like to get a parts manual for future...
The original part number your looking for is 78298 (Plastic tank valve). It has been superseded by part number 080270 and it it available here:
http://www.ordertree.com/ARI.aspx?Mfg=36&Model=9856-0%20POWERPLUS,%205,000%20Watt
http://www.ordertree.com/AddtoCart.aspx?&ProductID=78298&ProductQlfr=GEN $5.34
Part Mfg: GENERAC Part Number: GEN 78298 This Part has been superseded arrowdown.gif Part Number: GEN 080270 Price: $5.34
When you do parts searches in the future for your generator use 9856-0 (Powerplus 5000Watt) for the model number.
You can also order the 080270 tank valve here:
http://www.jackssmallengines.com/searchdb2.cfm
If you enter the part number on the search page.
$4.60
Thanks for using FixYa.
Kelly
Jun 10, 2010 | Generac 13,000 Watt / 13,000 Watt Home...
Air filter - where is it - how do you check it
This will vary by model. Pari compressors have a small round, slotted cover which holds the filter. Other manufacturers may place them in other locations, such as the side, or the back. Filters should be replaced on a regular schedule, such as every six (6) months, depending on use. Pari rates their filters for 500 hours, but recommends replacing the filter when you replace the nebulizer cup (if using reusable cups), which should be every 6 months to 1 year.
Source: http://www.pari.com/pdd/pdd-faqs.htm
Jan 17, 2010 | Pari Proneb Ultra II Compressor Nebulizer...
I have a ED2FHEXN Whirpool Refrigerator. Where is
Your fridge was made with 2 different types. it will be either one or the other.
the first one could be:WF-NL240 part number :#4396508 use replacement NL240
should run about $32.99
the second one could be:WF-L400 part number:#4396508 use replacement L400
this as well should run about $32.99
I would highly recommend that you contact whirlpool to find out which filter you will need since they used 2 different ones on your model.
You can reach them by phone or e-mail.
phone:1-800-253-1301
e-mail:www.whirlpool.com
I hope this helps you. IF you need further assistance please feel free to contact us at any time.
Jan 08, 2010 | Whirlpool ED2FHEXN Side by Side...
I need a replacement DCM18 reusable filter
Filters for these and the earlier model are still available, if you dig deep on the internet (the part number is 175181-00, Fits Models: DCM7, DCM18) but the prices plus shipping are as much or more than a new complete machine. I have found the entire unit for around $15 or so. Shop around and buy a new one......
Jan 07, 2010 | Black & Decker Brew N Go DCM18 Coffee...
Replacement water filter for rm255lash samsung refrigerator
You can go on Samsungparts.com to find the part number. Just enter the unit model number to find it under search by model number. You can order it right on that site. Hopefully the light indicator isn't red yet.
Jan 04, 2008 | Samsung RM255LASH Side by Side...
Kenmore KBC12 Coffee Maker Logo
119 people viewed this question
Top Kenmore Coffee Makers & Espresso Machines Experts
Steven Clarke
Steven Clarke
Jude24
ray gallant
Are you a Kenmore Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
