Question about Averatec (28370431) CD-RW/DVD-ROM Combo Drive
Reinstall drive d drive was deleted. how do i reinstall
  • 52 Answers
Use partion magic software and repartion ur disk....
it is the easiest software to handle such things.....
here is the link for tat software.....
http://www.4shared.com/file/36309461/616db244/Partion_Magic_80.html?s=1
Posted on Jul 20, 2008
Selling my Asus netbook... how can i do a mass delete??
Be careful.... you can reformat the hard drive BUT you will loose EVERYTHING on the hard drive including the Operating System. That will require you to reinstall Windows and all the drivers.
There is software that will "wipe" your hard drive so GOOGLE "deleting hard drive files".
GOOD LUCK
Aug 03, 2014 | Computers & Internet
Tip
Safely remove and reinstall the U3 software!
First of all, sorry for my worse english :P Reinstalling U3 on your drive is sometimes not possible. To solve this you must remove it using the OFFICIAL U3 remover from SanDisk. If you delete U3 using the launchpad itself, or using the U3 removal utility from U3, you can't reinstall it. I've archived older versions of this utility's, because they're the most stable versions. U3 removal tool: http://tinyurl.com/ysu7bt U3 installer: http://tinyurl.com/23e7rl Just use this utility's. Note if you have deleted NOT using this utility's, it's possible it won't succeed. Hope this works for you! I've tested this using two SanDisk Cruzer's. Kind Regards, Stijn.
on Jul 04, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I need to reset my controller so I can delete and reinstall netflix
Go into your system settings and then go to your hard drive menu. Netflix will be there for you to delete and then you can reinstall it.
Jan 24, 2014 | Microsoft Xbox 360 Wireless Controller
E drive was deleted from dell latitude d620,need to reinstall
Wait a minute, you gave your computer to someone and they deleted the E drive? What was the E Drive? Most times it only appears when you put something in the USB Port unless you have 2 Disc drives, a cd drive and a dvd drive.
Are you sure your E drive has not been hidden by a virus or infection? It might still be there.
Apr 20, 2012 | Computers & Internet
My disk cd dvd drive have deleted
you might have to physically unplug the leads for this cd rom then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if your computer came with a motherboard disc the sound drivers could be on it
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
May 17, 2011 | Computers & Internet
I deleted files from my simpletech 120 gb and now no computers recognize or will open the drive? Do I need to reinstall drivers?
While deleting files your hard drive files also have been deleted so you just re install and try it your probleem may be solved
Aug 27, 2010 | SimpleTech (SP-U25/120G) 120 GB USB Hard...
How to reload O/S from the D: partition?
Hi, not sure what you meen here i.e completely reinstall or repair? But here is to reinstall, let me know if you wish to repair! Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To install new version of XP. Insert XP CD into drive, reboot pc pressing ESC button, or delete in some machines. This takes you into BIOS, change your primary boot device to CDrom, save changes and reboot. Select boot from CD once this appears and wait for files to be installed. Select the part of the hard drive you wish to use for your operating system (usually the largest) and select partition this drive. Delete any previous os, and reformat hard drive. (Be aware this removes everything saved on your hard drive, so always back up first) Re boot afterwards and reinstall operating system.
Hope this helps
Jul 10, 2010 | HP Pavilion dv6226us Notebook
I had reinstall windows,now i only have 1%of disc space
You allocation of partion is too low while the time of os boot , so the only way is you have to change partion space , use this number during partition 60555 MB this 60GB so you cant get full easily , you have to run the DOS mode booting then only you can get the partition location , you may be runned the os from normal opening cd setup mode from already booted os , for further clarifications reply me , i will help you , thank you , dont forget to vote for me .
Nov 02, 2009 | Computers & Internet
I was reinstalling WindowsXP and hit the wrong drive to delete. I do not know if there is a way to get back all the data I had saved on the 250GB signiture mini. If not I will have to reformat it. Thank...
Try to make it a primary slave and use any partitioning software to undelete the partition. if it will not resolve your problem then you need to utilize a data recovery company or re-partion and re-format it.
Apr 26, 2009 | SimpleTech Signature Mini 250GB External...
\window\system32\ntknlpa.exe
Hope its under warranty probably a failing hard drive.
Mar 12, 2009 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
205 people viewed this question
Top Averatec Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
