Question about Whirlpool Washing Machines
Unit will not spin or pump water - Whirlpool Washing Machines
  • 25 Answers
Make sure u hear click when lid is shut slowly
could have bad lid switch and it will not do either of those if it is broken
Posted on Jul 20, 2008
My Asko washer model number WL6511XXLPP will not spin it is draining what's the problem
All front load unit must lock the door and drain all the water prior to spinning. If your filter inside the drain pump is clogged this unit will not spin. At the bottom of the washer is a door, open this door and unscrew the plastic cap. *This is the lowest spot on the washer, so this will hold water, be prepared for water* After you clean this out, run a rinse only cycle and re-test unit, if the unit fails to pump out completely, replace the pump. Good Luck
Aug 04, 2014 | Washing Machines
Machine will not spin..turns only as if to wash in spin cycle. washes o.k.
Check the drain pump and hoses . Is the machine full of water? If yes then it points to the drain pump...either blocked hose or electrical . The unit will not spin until the water is drained. The drain pump hoses are found both on the front of the bowl and behind the machine.
Jan 23, 2014 | Maytag Neptune MAH5500B Front Load Washer
The tub will not move back and fourth very well.clothes ome out soaking wet.
Something must be either in the pump or filter.9a2d46e.jpg 8132c08.jpg7788fff.jpgOR it could be something in between tubs. If that was the case you would remove the heater and fish out the item.
Jul 18, 2010 | Washing Machines
Will not drain the water and spin
this unit will not spin until the water is drained. your pump is jammed or faulty.if u r confident, remove and clean pump.please turn off power b4 u work on it do want any accidents . please reply if u need more help
Apr 08, 2010 | LG Washing Machines
The unit spins and clothes get hot, but no water collects in the water container. So things aren't drying...:(
if the water container is located at the top,then the pump is probably defective.
Oct 07, 2009 | Dryers
Washer-dryer # wm3677HW will not dry,heats up, run, on and on
You're a moron. This unit washes and dries. That's the whole point of it. Perhaps you should do some research before answering the question. the most likely cause is the water lever sensor.
Aug 09, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Spin speed slow
Sometimes this is a problem with the drain pump filter. It will get clogged with debris which will cause unit to spin slowly. The panel at the front bottom of unit will grant you access to the filter on the pump. Get a bowl or bucket and get ready to catch some water. Good luck
Jun 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Spin cycle not working, was making loud noises,water won't drain
i dont have a model number ..just tip unit prop it up try and spin unit with belt on with your hand ,,than take belt off and spin pump pully..by itself...onthejob
Jan 24, 2009 | Maytag Performa PAV2200
Washer doesn,t spin
It can be the motor coupler, the coupler should be checked and eventually replaced.
Check also the lid switch.
See It pumps, but doesn't spin.
Oct 27, 2008 | Frigidaire ATF6000ES Front Load Washer
Sears 110.23812100 washer leaks when spinning
There is a pause after the pump out that shift the tranmission into spin also if you open the lid the unit will go into spin before it pumps out completely . They have since fixed this issue...The newer models work offf the pressure switch to tell the unit when to go into spin only after the water level switch is open telling the machine there is no water left in the unit
May 28, 2008 | Washing Machines
Washing Machines Logo
20 people viewed this question
Dan Webster
Dan Webster
Sal De
