Question about Creda W100FW Front Load Washer
Door lock broke and machine not start
The machine would not start when door shut,i had to keep on opening and shutting it untill it started.So i tried to see if i could fix the problem and removed the screws from the door lock latch but when i tried to take it out it broke.
  • Creda Master
  • 3,463 Answers
You need to fit a new door lock.
Remove front of door seal, and fit new door lock.
Posted on Feb 10, 2009
My Kenmore HE was started, the doors locked, and a few seconds later, the whole thing shut off. Tried every cycle to see if changed it but only had the same results, help!
Dump it. sears has a horrible reputation with their appliances. I owned a sears dishwasher for two years until it broke down. Fukk sears.
Apr 01, 2016 | Kenmore Washing Machines
Door wont stay locked to run a load
You have a faulty door latch assembly and it will need to be replaced. Here is the part you need.
Oct 21, 2012 | Maytag Neptune MAH5500B Front Load Washer
My dryer light will not shut off even when door closed and it will not start up when in push start button it does a rapid beep
is the door switch broke?first what kind of dryer and send the model number,when the door closes it hits the door switch and shuts the light off,the dryer will not run if the switch is broke,it's like trying to start the dryer with the door open if the switch broke.
Apr 25, 2011 | Dryers
Frigidaire Front Load Washer Model LTF2140FS1. Put clothes in washer, fill detergent dispenser, close it, shut the door, set my cycle hit start then the door lock clicks, clicks again, panel shuts off....
Make sure that the switch for the door is closing properly at all times. If not, unit will not start up or will shut down while operating because the switch has opened.
Sep 12, 2017 | Washing Machines
My maytag front louder door won't lock or even stay shut?
it sounds like you have broken the switch which keeps the door latched when not in use as well as locks when the washer is started. These latches often fail when someone forces the door open to add more clothes without pushing the pause button AND waiting until the "locked" light goes off. Older children and teens and yes, uninformed men, are apt to do this. You will need a repair person.
Jun 21, 2009 | Maytag MAH6700AWW Neptune Front-Load...
HE front loader washer door opened during cycle and will not shut
the latch broke within( the hook inwhich actually hold doorshut) , youll need a new latch assy.
Mar 14, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Door open!
i had the same prob..and the cure was to change the bushes on the motor.its been fine since
Oct 28, 2008 | Whirlpool AWM6100 Front Load Washer
Self cleaning oven will not start for cleaning door lock problem
hi alot of people have been having this same problem with either the door locking before clean cycle and not opening or it goes through clean cycle and then the door is stuck shut and wont open.
You could try this it sometimes works before you press start push the door shut and keep pressure on it i mean lean on the door so your pushing it shut further than it is now then whilst putting pressure on the door try pressing start button again if it then starts cleaning cycle keep pushing door for about a minute then gently let go of the door.
This should then allow it to go through clean cycle but remember when clean cycle has finished dont try opening the door strait away as you will then have the problem door stuck and wont open you need to let the oven cool down before the door will open.
If after pushing the door shut a bit further you still have problem then the only thing you can try is switching off at mains for 24 hours this should release the lock let me know how you get on ok
Feb 10, 2008 | Frigidaire FGFB75D Gas Kitchen Range
Creda W100FW Front Load Washer Logo
198 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
