I have seen the higher power cb's fry the fm front end sectioon of the tuner section....did you try to put it on an aux input?....the click you hear is the amp protection relay and it sounds like it is working ok....if it were the output side of the power amp, then the relay wouldn't click after power up...it is probably the front end...this is the entire fm tuning section usually contained inside a metal box near where the antenna comes in
Testimonial: "was very fast and helpful.. thanks .."
I tried all the imputs,fm, dvd ,tv ect with no change. Is this repairable or just throw it away and update? Thanks for the fast response by the way.
sounds like the switching IC may have been fried....these aren't terribly expensive but if you were to take to service dept..labor may be a bit of cake...don't know what you have in the unit, but units are much cheaper these days...it is probably worth fixing, but that would be your choice
I bought it new but that has been a while. I might just buy a new one for the house and fix this one and put it in my shop. Thanks. I will tear into it tomorrow..
I will probably get a new one for the house and fix this one and put in my shop. I will tear into it tomorrow.. thanks
