Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Interference Lines My Mitsubishi WD-52525 has Grey (clear) lines appear when I have an input plugged into the TV and that input device (DVD player) is turned on. With the DVD off the blue screen shown is flawless. With my cable box the picture appears better with the understanding that regular definition cable looks pretty bad. I don't notice the lines on regular definition cable but on some of my HD sources the lines come back but are very close together. Perhaps this is the difference in resoluion. I'm tempted to try my HDMI input to see if that makes a difference as I'm solely using component connections now. Here are the steps I've tried so far: 1. Tried another set of component cables 2. Swapped with another DVD player 3. Unplugged EVERY device from my entertainment system including power cords with the exception of the DVD and TV. A friend thought it might be interference from my cable TV. 4. Tried a different power strip (current powerstrip is a Moster Power Powerbar 1100 with Clean Power Filtering) 5. Ran power from a different circuit in the house with an extension cord. 6. Replaced the lamp (the replace light was on anyway) Any tips are certainly appreciated but it seems the typical solution for most television problems is that it's *almost* cheaper to buy a new television than it is to repair the one you have. I'm fairly tempted after paying $4,000 for this TV 4 years ago to sell it for scrap parts and buy a 47" VISIO TV from Costco and be done. I've always hated how rediculiously loud the television fan is. When I bought it I was assured this problem had been addressed by Mitsubishi which is why I had to wait so long for it. My days of being an early adopter of technology are over after this purchase. Sorry for the rant.
  • alabeau Jul 24, 2008
    I've swapped between the two different component inputs 1 & 2 but I'm using both component inputs for both my cable box and DVD player.
    I have not tried the s-video or rca inputs. I have also not tried the HDMI input.
  • Anonymous Jan 13, 2009
    I have the same issue on my WD52525. It appears on any inputs to my tv, except HDMI. Unfortunately, I have yet to find a cause or solution.
    Problem Solver:
  • 9 Answers
Is it only happening in the audio video input?
Posted on Jul 24, 2008
My picture has veritical lines all through it.
Change the input to something else...like a DVD. Is it still there? If not, you have a signal problem either outside the tv..or perhaps a bad tuner. Do you have a computer near the tv? Or other high tech device near the unit? Try turning off any hi-tech devices in the house and check to be sure the connections are good to the tv and/or cable or satellite box.
Jun 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Verticle black lines on mitsubishi dlp tv screen
Press the Menu Key on your remote. If your menu shows clearly on the screen, then there is a problem with your source.
Mar 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Don't know which input the matches which device icon on screen
if you look on the back , the inputs are labled, then go into the tv menue and go under device lable and match the input it is plugged into, to the dvd icon
Jan 07, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Shadow lines on screen
the DM board is defective. there are approx 20 smd parts that need to be changed. if this board is going then it is just a matter of time before you have the bglod. check out www.tv-techs.com
Jan 06, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi DLP WD 52525 has small green lines on the screen
do the lines go from top to bottom, and are they about 1 inch apart? or do they move diagonally across the screen?
Dec 27, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WD 57733 picture color problem
Good Day;
Try resetting both devices TV & BOX, unplugg power for 2 to 5 minutes then plug back in.
good Luck, big IRISH.
Sep 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WS65909 and no DVD device recognition
This can be solved in the setup, the dvde input needs to be enabled. It will be one of the comp inputs depending on which one you are using.
Jul 13, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsibushi WD-52525
yes if the lines are on all inputs and also on the menu of the set itself then you may want to test your 5 volt power supply on plug j19 of the lite engine.this does require removing the back of set along w/the back shield,about 30 screws.good luck joe tv
Oct 27, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Static picture or flashing colors pictures wd-52525
HEY AWOOD,THIS SYMPTOM IS DUE TO POWER CAPACITORS GOING BAD IN THE POWER SUPPLY AND THESE CAPS CAN CAUSE A COUPLE DIFFERENT SYMPTOMS,YOURS SEEMS TO BE THE MOST COMMON.IF YOU'RE TECHY ENOUGH YOU CAN REMOVE THE BACK AND GET ACCESS TO THE TWO PLUGS ON THE LITE ENGINE TO TEST (WITH A VOLTMETER) THE 5 VOLT SUPPLY ON I BELIEVE PLUG J19 PINS 1 AND 3.IF LOW THEN REPLACE 6 CAPACITORS ON POWER BD. YOU SHOULD BE ABLE TO SEE IF THEY ARE BAD JUST BY A VISUAL INSPECTION.GOOD LUCK JOE TV
Sep 19, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
70 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
