Question about Apple iPod nano
How to get cd text on itunes
Whenever I insert a cd itunes just shoes the track number and not the actual name of the song. How do I get the cd text to come up again? That way I don't have to keep inserting the text myself every time.
  • Mike
    Mike Oct 21, 2008
    agreed help would be appreciated
  • Anonymous Nov 16, 2008
    same problem with cds that you make on itunes
If its a burned cd disk then you have to keep changing the names manually by clciking on them then typing the title in but if it is a brought cd from a shop then i dont know why you would have that problem.
Posted on Dec 13, 2008
Tip
How to Play iTunes Music on Windows Media Player
There's a good chance when you buy music from the iTunes Store that the files that you download will be copy protected by Apple's FairPlay DRM system. It's a great system that protects the rights of the artist and publisher by making it difficult for the consumer to distribute copyrighted material. However, DRM can also be very restrictive by stopping you playing legally purchased music on your MP3 compatible hardware. So, what happens if you want to play your DRM'ed music on a non-iPod?
This tutorial will show you a way to produce DRM-free music that doesn't require any special software that you would normally need to buy. All you'll need is the iTunes software, and a blank CD (preferably a rewritable (CD-RW)).
Before we begin, check for any updates that are available for your iTunes installation, or download the latest version from the iTunes website。
Configuring iTunes to burn and rip an audio CD
CD Burner Settings: In order to set up the iTunes software to burn an audio CD, you first need to go into the settings menu and select the correct disc format. To do this, click on the Edit tab on the main menu and select Preferences from the menu list. On the preferences screen, select the Advanced tab, followed by the Burning tab. First, make sure your CD burner is selected from the drop-down menu alongside the CD Burner option. Next, Select audio CD as the disc format that is to be written by your CD drive.
CD Import Settings: While you are still in the preferences menu, click on the Importing tab to access the CD ripping settings. Verify that the On CD Insert option is set to Ask to Import CD. Next, set the Import Using option to a format of your choice; the MP3 Encoder is your best choice if you want to import audio CDs as MP3 files that play on virtually all compatible devices. Choose an encoding bitrate from the Setting option; 128Kbps is the normal setting that is good enough for the average listener. And finally, make sure the Automatically Retrieve CD Track Names From Internet and Create File Names With Track Numbers and both checked. Click the OK button to save your settings.
Making a custom playlist
To be able to burn your DRM copy protected songs to audio CD you will need to make a custom playlist (File > New Playlist). You can add music tracks to a playlist easily by dragging and dropping them from your music library to your newly created playlist. For instructions on how to achieve this, why not follow our tutorial on How to Create a Custom Playlist Using iTunes.
While creating a playlist, make sure that the total playing time (displayed at the bottom of the screen) doesn't exceed the capacity of the CD-R or CD-RW you are using; typically, the total playing time of a 700Mb CD is 80 minutes.
Burning an Audio CD Using a Playlist
Once you have created a playlist, simply left-click it (located under the playlists section in the left pane), and then click on the File tab on the main menu, followed by Burn Playlist to Disc. The CD drive tray should now automatically eject so you can insert a blank disc; ideally use a rewriteable disc ( CD-RW) so you can reuse it multiple times. Before iTunes starts burning the DRM protected songs, it will remind you that creating an audio CD is for your own personal use only; once you have read this notice, click on the Proceed button to start burning.
Ripping an audio CD
The final step in this tutorial is to import (rip) the songs that you burned onto audio CD, back to digital music files. We have already configured iTunes (step 1) to encode any audio CD that is inserted into the CD drive as MP3 files and so this stage of the process will be mostly automatic. To start ripping your audio CD, simply insert it into your CD drive and click the Yes button to start. For a more in-depth look at this process, read the tutorial on How to Import CD Tracks Using iTunes.
Once this stage is complete, all the files that have been imported into your music library will be free from DRM; you will be able to transfer them to any device that supports MP3 playback.
Note:The only downside in using this method is that if you have a lot of files that you need to convert, then it ends up a slow and tedious process. With this in mind, use a legal drm removal tool if you have a large quantity that you need to convert.
on Aug 25, 2010 | Computers & Internet
Any way to remove the DRM from iTunes Apple Music?
Here's one way:
1. Using iTunes, burn a music CD with the songs you want.
2. Import the CD you just created. Use the iTunes > Preferences > Import Settings to set the type of audio file you want iTunes to create when importing the songs.
3. iTunes will import the tracks as "Track 1", "Track 2", etc. You can rename the tracks to the original song titles.
Dec 03, 2015 | Apple Audio Players & Recorders
How do I burn copies of cd-r and get the text to show up as the music is fine
When you burn the cd to your MP3 are you online? I notice when I'm online when I'm burning cd to my iTunes or MP3 the name and songs come up. If I'm offline it show the tracking not the song.
Feb 13, 2015 | Audio Players & Recorders
How do i put music from the cd in my laptop to my ipod touch?
These are the steps here:
  • 1 Open iTunes.
  • 2 Insert your audio CD into your computer.
  • 3 Click on the CD name in the Source list. (This shows a list of songs on that CD.)
  • 4 Uncheck any songs you don't want to import to iTunes.
  • 5 Click "Import CD."
  • 6 iTunes you will now copy the selected songs from the CD to your iTunes Library.
  • 7 Once all of the songs are imported, click "Eject Disc."
  • cd-itunes.html#ixzz11zOLZdGQ
    Oct 10, 2010 | Apple iPod touch
    I have imported a CD to iTunes (a compilation album "American Anthems" - Various Artists) but instead of recognising the tracks as being a part of one album it has split them into their own individual...
    You need to modify the information on each of those songs.
    To do that, you need to open iTunes and go to your music library.
    Select one of the songs that you want to modify and right-click on it.
    Select Get Info.
    Select Info tab (second among the tabs on top)
    And type in the name of the album on the box under Album.
    And click OK to save changes.
    You can also Next or Previous if you see that the next/previous song belong to that album. That way you don't need to select and right-click on the next/previous song. It will automatically open the info of that song.
    For iPhone / iPod touch tips like jailbreaking and unlocking, click here.
    If you need online help about jailbreaking and unlocking, you can contact me personally at this email: sale-47hyk-1863377234@craigslist.org
    Jul 30, 2010 | Apple iTunes
    HP Tochsmart DVD-RW drive not playing cd's /dvd's
    The best player is Video Lan Controller (VLC) is plays everything.
    You need the RIP command as you have not a data disk but a multimedia disk (.CDA) file.
    Jun 13, 2017 | HP Pavilion TX2000Z Tablet PC
    Downloaded music, shows artist name but no tracks??
    It could be the wrong format. I used to play music off my psp. I'm guessing if you use iTunes, and imported a CD, its going to make your songs AAC format, which is also known as MP4. I have posted a link to where you can set the different compression methods. If you are using WMA format, you are using an even less compatible format, and if you import it into iTunes, it will convert it as well. To convert already imported music into iTunes, once you set the preferences to MP3, right click on the song, and click "create MP3 version." after that you may reveal the song in the finder/explorer by right clicking the song, and clicking "show in finder" or "show in explorer"
    Nov 19, 2008 | Sony PlayStation Portable (PSP) Console
    How to transfer music from a cd to yp-p2 when the description of file is track1
    modify the second CD by clicking on each individual song and giving it a title(It doesnt have to be the right song title you could put numbers also ex.1-13 if you wanted. just delete track in front of the numbers). That way the computer doesnt think that both of the cds are the samething
    May 09, 2008 | Samsung YP-P2 Digital Media Player
    Apple iPod nano Logo
    37 people viewed this question
    Top Apple Audio Players & Recorders Experts
    TO Lady
    Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
