WLSE 4210 how would i know if gears or drum was broken
  • anbet1002 Jul 20, 2008
    ok; it does not turn at all. it is a top load washer and i'm sure it ever turned when powered off. agitates ok. spins only if not much weight in the tub
  • 2,427 Answers
When you turn it with your hands , just give it a spin, you will see if is hanging to one side, or if its running rough or gets hard to turn
Posted on Jul 20, 2008
  • Rishi Roshan Ali Jul 21, 2008
    it turns you just need to turn it with your hand, :(
Why does suzuki TF 125 jump out of neutral into gear
One of several reasons...
1. You are not getting the transmission into neutral correctly
2. The neutral detent spring/plunger is weak/broken
3. The shift drum locator is worn or broken
4. The shift shaft arm that moves the shift drum is worn or broken
5. You have extremely worn shift forks.
Its time to have a professional look at it... this jumping into gear will eventually cause serious damage to your transmission.
May 17, 2014 | 2004 kawasaki VN 1500 Vulcan Classic
Washing machine drum does not turn
You need to know if your machine is band driven(older model) or gear driven(newer model). Google model to find out or look it up in manual if you have it.
If older model the rubber belt is broken and needs to be replaced OR if newer model the gear that turns the drum is burned out and needs to be replaced. Either way, it best to have a service tech come out and fix it. The rubber band might be old and hard to find & if gear & motor are gone may be too expensive to fix, cheaper to buy another unit.
Apr 11, 2014 | Washing Machines
Where is the drain plug for the transmission on the john deere 4210 tractor
There should be a pipe type plug in the bottom of the transmission housing near the draw bar inline with the rear axle housings. Whether you have a hydrostatic drive or gear drive, the plug is in the same place. Reference # six in drawing.
Feb 16, 2011 | John Deere Seat 4210 4310 4410 4510 4610...
When I try to use my Singer 4210 with the feed dogs covered the cover plate pops off.
I was just looking at page 27 of your manual, and was wondering if one of your pins is broken off and that is why it won't lock in place. Take a look at it and your manual and see if that is the problem. Then call Singer at 1-800-4singer and see if they will send you another one. If, it is the first time you tried to use it, I am sure that they will help you for free. It probably was damaged when you got it.
Nov 20, 2010 | Singer Inspiration 4210 Mechanical Sewing...
My washer will start but it will just make a winding sound
Sounds like the motor to drum belt or gear is broken. The motion generated by the motor is not getting to the drum because the belt is slipping or broken, or the gears are stripped causing the winding sound.
Sep 26, 2010 | Kenmore HE2 Plus Front Load Washer
Orange light on drum. drum making a loud hammering sound when printer is put on or attempting to print.
Sounds like a broken drum drive gear. Try another known good drum assembly first. Parts can be googled and found. But, difficult for end user to replace. You have to remove all covers and fuser asm. Then gear housing from the left side to change the drum drive gear.
Dec 30, 2009 | Brother HL 1440 Laser Printer
My P0745 code: My 2002 ford explorer has a problem shifting from 2 gear to 3 gear. All other gears work fine
Some 2002 Explorer/Mountaineer vehicles built prior to 3/4/2002 with 5R55W transmission, may exhibit no 3rd gear or slipping 2-3 shift with diagnostic trouble codes (DTCs) P0733 and P0745 present. This may be due to a broken intermediate band.
ACTION
If the conditions described are verified:
^ Follow Service Procedure "A" to confirm band is broken.
^ Follow Service Procedure "B" after verifying a band is broken.
Per Procedure "B", if a broken band is found replacement of both the OD and intermediate bands and pistons will be necessary. However, only an inspection of the direct clutch drum may be necessary. The drum should not be replaced unless damage is found.
Dec 18, 2009 | 2002 Ford Explorer
Gear shift moves up and down wont select gears . gear shift is not lose on the sharft .thanks
You have an internal problem with the shift mechanism.You will need to remove the clutch cover to identify what is broken.It is rare that you can't fix a problem such as this from behind the clutch cover.(ie no need to split the crankcase).pull of the clutch cover & look to see if when you try to select gears if the selector drum turns. It should then be apperent what has gone wrong.(circlip fallen off,selector drum actuator or spring broken)
If you find something broken you need to find all broken pieces before it goes back together so it/they don't find there way into the gearbox or BANG your gearbox will go.
Hope this helps
Regards Andrew porrelli
Dec 07, 2009 | KTM SX 125 Motorcycles
Drum drive gear is broken
I don't know if you found the part number yet, but it is called a "Pawl" part # 1136-2528-01 . Good Luck finding it.. I believe it is the same part in some other models made around the same time.
Oct 08, 2008 | Minolta EP4000/5000 CS/PRO Copier
Broken kenmore washer
I have a Kenmore style master model #4217013 but it stopped spinning last night. Please let me know what to do.
Mar 27, 2008 | Washing Machines
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
