Question about Sony NWZ-S615F Walkman Video MP3 Player
Volume buttons stopped working...
Hi. I use this to go running with. A friend borrowed it for two hours and it poured down rain on her. I don't know if she got it wet, but am assuming she did. When I got it back it froze up and I pressed the reset button. The only thing now is that my volume buttons are not working.
I know it registers because if I put the "hold" on and press it, it will tell me I need to undo the hold before pressing anything.
I am currently setting it aside and hoping that if it got wet internally maybe letting it dry out may help. Anything you can think of will be appreciated since I love this player and don't want to lose it.
  • 66 Answers
Hi,try putting it in the hotwater cupboard to give it a good dry
hope this helps :-)
Posted on Sep 03, 2008
How do i open my phone after forgetting the password? It is an HTC one and I remember the pattern lock but not the 2nd security level where I need to know my gmail password. I never use it anymore and
You can format your mobile for factory condition. the method is given bellow
1. Press and hold the VOLUME DOWN button, and then press and hold the POWER button.
2. Wait for the screen with the three Android images to appear, and then release the POWER and VOLUME DOWN buttons.
3. Press VOLUME DOWN to select FACTORY RESET, and then press the POWER button. All data will be lost!
Oct 02, 2014 | HTC Nexus One Cell Phone
Does anybody out there have an owner's manual for Lifetime Furnace Model # 1500 VI by Del Rain?? PLEASE contact me!
I have used one of these for years and was looking to find a new one and came across your question. I don't have the manual but here is how the programming works:
On/Off (obvious)
Heat/Fan (if lit it makes heat if off it just runs fan)
Auto/Manual (if off the temperature slider causes the fan to run on high or low)
Preset on (I don't use this but probably can be used to set it to turn on after a selected number of hours)
Preset off (if lit the heater will turn itself off after the number of hours shown on the right)
Time select (press this button to change the number of lights shown vertically ... each is labelled and you add them up to get the hours you want from 1 to 15 ... so if bottom two numbers are lit (1+2) then heater will run for 3 hours then turn off)
Feb 17, 2012 | Del-Rain 1500-V 1500 Watt Ceramic Heater
MY FRIEND JUST GAVE ME HER OLD PHONE WHICH IS A MOTOROLA MB300. BUT THE PHONE HAS A PATTERN LOCK BUT SHE FORGOT WHAT IT IS. CAN SOMEONE HELP ME?
Welcome to Fixya. If the you don't know the lock code you can try the steps below so that you can reset the phone to it's factory state.
1. Power off phone. 2. Hold camera button and power on phone at the same time. 3. Release the camera button when prompted to. 4. You will see a message screen telling you to press the up or down volume button 5. Press and HOLD the down volume key (ignore message 'Volume Up Key Pressed') 6. When triangle and phone screen appears 7. Press on the screen just above the back key 8. You will now see the "Motorola system recovery" menu
At this point you will have three choices:
1. reboot system now [Menu+Back] 2. apply ssdcrad:update.zip [Alt+S] 3. wipedata/factory reset [Alt+W]
Select the third option to do a factory reset.
Thanks You can simply tap an item to select it.
Aug 02, 2011 | Cell Phones
Good day! I'm having problems with my laptop my acer aspire 5532. Last night it rained hard. I was using my laptop and it was connected to a broadband which the adapter is connected directly into my...
Try this..
Please connect the adapter to laptop.
Goto Run -> devmgmt.msc -> check any yellow marks or explanation marks or red x marks. Rightclick on those and Update Drivers.
Check for whether the adapter is detecting..
Otherwise remove the old drivers for that WAN miniport and re-install the drivers again.
As per you said, the adapter is working on another laptop means, your adapter is wokring oK.
Hope this helps to you.
Jun 18, 2011 | Computers & Internet
The x and y buttons on all my controllers and with all games have stopped working?????
if the buttons don't work in different games, then it all point as a hardware problem.
borrow a controller from a friend to make sure u can play on your xbox.
if everything works ok with a new controller then replace your controller.
if the problem persists, then your xbox might be sufferig form reception problems (very rare problem) and needs to be fixed by a technician on site.
good luck!
Mar 04, 2011 | Microsoft Xbox 360 Controller
Nokia BH-103 low volume.
bh 103 is fail product don't advie to other i suffer lot because i purchsed before 12 houres volue very low it is like 100 rs local ear phone & current it stop working with in 4 minits playback nokia now start bad production & try to foll to all customer
Jan 19, 2010 | Motorola Mobility H710 Bluetooth Headset
Windshield wipers on 1998 chevy venture
that was probably because it wears the engine that drives them to work. carry some internal contacts are called brushes and these are over. may also be that your system is damaged electrical wiring. or the alternator current nesecitas fail to bring a workshop to review electric luck
Aug 24, 2009 | 1998 Chevrolet Venture Cargo
I don't know how to load the film in?
Hi. This might be useful
http://www.youtube.com/watch?v=lCCCLagBKg8
May 16, 2009 | Minolta X-700 35mm SLR Camera
Trane HVAC Unit
If your condenser blow air up through the top of the condenser and you are concern about rain water affecting the unit.
You can install a roof or rain hood about 4ft above the unit to keep the rain off, The unit must be able to blow air off without causing Hi head pressure to affect the unit, The condenser must breathe or desipate heat freely.
Tell me if your question answered or if it works for you.
Mar 31, 2008 | Heating & Cooling
My Samsung YP-K3 MP3 Player That I borrowed from my friend
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Mar 20, 2008 | Samsung YP-K3 MP3 Player
Sony NWZ-S615F Walkman Video MP3 Player Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
