Question about Hitachi 50UX57B 50" Rear Projection Television
Hitachi ultravision 5oux58
I could not find 5oux58 so i thought this would be close. My tv made a pop sound and then i smelled something smoking and i unplugged it. We were going to look and see if we could see what had burned after we took the back panel off. We plugged it in and a few of the green lights in the back of the tv came on and went off. When we tried turning it on nothing happened, no lights on front or in the back. We are trying to see what needs to be replaced or if it is worth it. My email is earnhardt05@yahoo.com
Thank you, Holly Carver
  • Anonymous Jul 30, 2008
    I have a hitachi 50UX58B and while watching tv it just turned off. It won't turn on. I took the back panel off and looked for burn marks and found none. I plugged it in and some green LED's turned on then went off. maybe a transister went or something? IT is 10 years old. how much to tell me what is wrong?
  • Pilot96 Aug 13, 2008
    I heard a snapping sound while watching tv and lost all power. I removed the back panel. in line fuse was okay. I unplugged and tried to reset and all I seen when trying to power up again was the green led's lighting up and then they went out, One of the green led's did not go on at all. I might have had a power surge. Do you have any suggestions?
    Thank You
    Pilot96@sbcglobal.net
    Problem Solver:
  • 5 Answers
Could be many things (components) on the board - might be visible, look for burned mark. Careful with the high-voltage leads. if you don't have some knowledge of what you are doing, don't.
Posted on Jul 25, 2008
2 Suggested Answers
ahhsoo69
  • 167 Answers
SOURCE: hitachi ultravision 5oux58
hello it sound's like you have a bad fly back transformer . !!! that might need to be replaced.!!tell me is the set hdtv.? if not you might buy a new set. well hope this help's you "Good luck"
Posted on Aug 06, 2008
Hitachi 42" ultravision...power light on, hear
Tries pushes the power switch on the remote few times,each times push wait like a 1 mins or 2 mins for the tv Tuner signal board to take it effect.This process should get ur tv picture back,because the tv Tuner signal board it is old and having problems,evenually require replacement of a refurbish tv Tuner signal board.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
May 23, 2011 | Hitachi UltraVision 42HDS52 42 in....
TV: Hitachi UltraVision no Picture.
Hitachi Ultravision power light on but on picture
Nov 18, 2009 | Hitachi 57SWX20B 57" Rear Projection...
TV has no picture or sound. Was working fine then suddenly went black. Slight smell or something burning and just a clicking sound inside TV now. Any thoughts?
if it is 46F500 UNPLUG SET and remove back cover--on far right side as you look from the back you should see either two smaller or one very large heat sink with fins--the set listed has either one or two STK-392-110 OR STK-392-150 CONVERGENCE CHIPS.
Near them you will see about 12 resistors--look to see if any are burnt or slightly discolored in the middle---you have to look close at them--they can all be checked like checking a fuse--no reading and one is gone----
Point here is if any are bad or smoked--one of the convergence chips got them----the only other way to prove or disprove this is to get at the chips and un-solder all 18 pins on each chip--if set turns on--one is bad and BOTH NEED to be replaced along with any bad resistors--if you smelled something--something toasted--- these resistors are FLAMEPROOF or metal oxide--they will not catch on fire, just pop and go instantly.
Let me know what you find and I will help you--I am here to help people---If this helps you rate this solution as I do this here for free.
SD TECH
Nov 02, 2009 | Hitachi 46F500 46" Rear Projection...
TV Exploded
Sounds like the DLP lamp failed. You can decipher the Hitachi flashing red light. That should help to be sure.
The DLP lamp replacement is fairly straightforward and can be done with minimal tools
Sep 10, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Tv made a noise and shut off
I would first suggest checking the lamp and see if it has gone out.
If this is not the problem, then I would suggest calling a local service center to come to your home to diagnose the problem.
I hope that this helps.
asnowman
Aug 21, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 50V720 Rear Projection TV
Good Day, douganddawnc;
What ever is popping is locking up the CPU circuit. Call a Factory Authorized Service Center Have figure out what is popping, get an estimate first. Good Luck, big IRISH.
Aug 21, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Jul 23, 2008 | Hitachi 50UX58B 50" Rear Projection...
Hello
the clicking is the relay. I would suggest checking the voltage regulators and horizontal output transistors
May 11, 2008 | Hitachi 53UDX10B 53" Rear Projection...
No power all of a sudden
Check IC601, C603 for leakage, I601 and vertical pulse detector QN05
for poor convergence check RK42 for open circuit.
Jan 06, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 50UX57B 50" Rear Projection Television Logo
105 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
