Start cycle dl code comes on and I know that there is a reset. Thanks rw
Hi mate first thing I would do is unplug the machine and turn off the water valves red and blue before you take out the drain hose get a basin and keep it with you at the same time put the hose into the basin bring the two down to the floor when the last of the water is empty you should be able to open the door if you can still not open the door take the top off the machine MAKE SURE THE MACHINE IS STILL UNPLUGED if you have a narrow arm you can feel down where the interlock is and move your fingers around the interlock until it releases the lock maybe the pump is blocked our the interlock needs to be replaced
Good Morning steven hutchings, thanks for your inquiry!
I understand that your Electrolux dishwasher is displaying an error code 03. Normally, error code 03 means an issue with the wash motor, wash motor hall sensor, or control panel. I would suggest performing a reset on your dishwasher that could help clear any false error codes. You can reset your dishwasher by flipping the household circuit breaker in the off position for ten minutes. If you continue to have an issue with your dishwasher displaying an error code 03, I would recommend having a professional technician come out and properly diagnosis your dishwasher. This will help to avoid any unnecessary part purchases. Hope this is helpful. -Matt
I get the DL F11 code and even though the door locked light is off it's still locked, unplugging the stupid machine for days and doing all the other things, i.e., changing the cycle etc., doesn't work. I hate this machine and will never trust another whirlpool product again but in the meantime the stupid thing is holding my clothes hostage! How do I get the darn door open? And does anyone know what the fix for this problem is?
