Question about Gigabyte 8VM533M-RZ (GA-8VM533M-RZ) Motherboard
Not booting Computer won't boot just giving long constant beeps
  • Seymour Graham Jul 26, 2008
    thanks I did have to change memory
  • 781 Answers
You have a motherboard system fault.
1) try different memory sticks
2) check if hard drive wired in correctly
the broad ribbon cable to it should have the stripe next the the power 4 pin plug
3) try a different video card
there are other things to try but try these first
Posted on Jul 25, 2008
  • David
    David Jul 26, 2008
    could you please mark as fixya thanks
CONTINOUS BEEP WHEN COMPUTER IS TURNED ON
To do this properly I need to know which model your computer is - is it an eMachines MB.NBK09.003 Motherboard El1850 Desktop S775 G41T-Ad ? I need this to try to establish the BIOS seller and version. You might try finding the BIOS version by (continuously) tapping the F1, F2 or esc key (or possibly another)immediately after you turn on. The "splash screen" that appears aftrer you turn on may have some lettering which tells what key to enter the BIOS.
In the absence of this information here are two suggestions
EMachines that beeps constantly and won boot up
if it is the above it is serious and the computer will need serious (difficult) repair, or main board replacement or whole unit replacement (by which I mean new computer)
The other suggestion was about the RAM not being properly in place, but I doubt this as this usually gives a different beep code
19.January.2016
Jan 19, 2016 | eMachines MB.NBK09.003 Motherboard El1850...
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Somehow your MBR (Master Boot Record) likely got corrupted or possibly your hard drive went bad coincidentally.
Simply, you will start your computer from your Windows CD/DVD install disk, then when at a DOS prompt ( D:\ ) you will then type: FDISK /MBR (press enter).
Find your Operating System install DVD and start your computer with it, then follow instructions within this discussion:
Restore Windows XP MBR without Windows XP disc
Alternatively, review my search results for other instructions:
fdisk mbr windows xp Google Search
Nov 22, 2017 | Gateway MP8708 Notebook
Windows won't start up? Well, try this Download Tenorshare Data Recovery from its offical site and install it. Burn it into CD/DVD, or USB flash, put into the computer you need to repair, Bios setting. It can make sure your important data will not lose. Best of luck
Related: windows won't start
Aug 25, 2012 | Gateway MP8708 Notebook
PCV R44G, won't boot, no fans, won' turn on.
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 22, 2012 | Sony Computers & Internet
I purchased 2 GB chips to try to increase the speed of my desktop. After putting in the chips my computer won't boot back up, my monitor is black and the computer is making a constant beeping nois
OK. First, I'm assuming that you have a Dell Vostro 200 as per the topic title. That said, you machine has a maximum memory capacity of 4GB. So, if you added the 2 - 2GB DIMMS in slots 3 and 4, leaving your original memory in the machine, you will have problems. You must be using DDR2 667 or 800 MHz RAM and the two DIMMS must be in slots DIMM1 and DIMM2 ( closest to the processor). No more than that can be installed.
Apr 03, 2012 | Dell Vostro 200 PC Desktop
Acer computer won't boot has long buzzing noise
The long buzzing sound indicate the nature of the problem. Depending on the manufacture of your bios will determine the problem. With only one long beep you may have memory problem. The computer cannot initiate the boot sequence. Did you add any devices to the computer prior to your problem. if you did undo what you did. Make sure the computer is on, if nothing happens ( no lights, no sound, no fans etc.) the computer has a power failure. Make sure you listen to the beep if it is a numerous beep sequence note it down and check the web for computer beep during boot up.
Mar 25, 2012 | Computers & Internet
My computer has a RAMDDR2 but would not start up,can u help me diagnose and troubleshoot?
First make sure you haven't installed too much memory. The computer uses DDR 2 memory but what is the maximum amount it can use. If it can only support 2mb and you have 4 installed the computer will read that as an error during boot up. Second, disconnect the Keyboard and as the computer is booting access the BIOS. disable the stop on all errors setting so it can get past not sensing the keyboard and see if that boots. If the computer boots after that the problem is a fault in your keyboard like a stuck key which will give you the constant beep. If you see the spalsh or BIOS screens then the problem is not the Video Card. If you don't get those screens double check and make sure the Video card is properly installed with nothing installed in a slot directly below it as this sometimes causes conflicts.
Nov 17, 2011 | EliteGroup P4M800-M7 Motherboard
My computer won't boot up and the orange light just stays on. The moniter is working, the fans in the power supply is working. I was fine yestyerday. I put in hibernate and tried to cut back on today...
Remove the RAM and install it again and restart.....it will work if still not work then change remove RAM again and start your machine..it will give beep sound...if it will not give beep sound then understand your machine's mother board is faulty......
Sep 09, 2011 | E-Machines eMachines Desktop PC
I kep getting an error on bootup about A: configuration in bios I can not boot the machine due to this problem. Also, I need to boot from UB drive, FINALLY got into bios, but it is still giving me the...
Is there a floppy disk in the A: drive? That "port" is usually reserved for a floppy disk, either 3.5 or 5.25in. You probably need to disable the floppy drive in the BIOS.
Jan 24, 2018 | AOpen Computers & Internet
Computer won't boot , constant PWR problem (
i am also using same motherboard dg31pr intel but it does not reboot .......
because this is the problem with you monitor , just you change the monitor and try again .
this is only the solution to solve this as the tecnition said me.
Mar 20, 2009 | ASUS A7V400-MX Motherboard
Gigabyte 8VM533M-RZ (GA-8VM533M-RZ) Motherboard Logo
74 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
