Question about Microwave Ovens
When i am keeping things in microwave there i sparles in it .what to do for that?...
  • Microwave Ovens Master
  • 9,086 Answers
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
In some models it is a larger stirrer cover type made of thicker plastic in the ceiling of the oven.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
Please write back with your brand and model number if you need further help.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 20, 2008
Why woll sharp R-530E microwave not turn off when door opens.
It is very dangerous, you're filling the room with radiation, may be best to just dump that one, unless you are a little bit competant with mechanical stuff, in which case it's probably the sensor on the door not registering that it is open,. might be a physical thing, i.e. moved a little. or maybe a electronic thing, requiring a new sensor itself.
Sep 04, 2014 | Sharp R-530ES Microwave Oven
Breaker to microwave keeps tripping. Electrician can't find problem. Could it be the microwave itself?
It can be related to short in the main capacitor , short in the transformer or the surge capacitor. Also it can be due to short in the Magnetron or even the fault in the board.
You can isolate the short by disconnecting these one by one till the circuit holds which will confirm the case.
Jan 31, 2013 | GE SpaceMaker Microwave Ovens
Ge spacemaker microwave, new, keeps tripping the GFI but keeps running
The first thing you need to check is the GFI--when it trips, it definitely should shut off power to the circuit. It may be wired incorrectly, or is faulty. There should be a 20 amp breaker and wiring to the oven.It is also much better is the oven is the only appliance on this circuit. Hope this helps!
May 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Our Microwave keeps running and won't stop. It is
The fan you hear is probably the magnetron cooling fan and that, and the light, are probably both controlled by the electronics board that controls everything else. You might inquire online at Maytag or the Sears parts department to determine the cost of a replacement board but I suspect it will either not be available at all or cost 3/4 of a new microwave.
Jan 23, 2010 | Maytag MMV4205 Microwave Oven
Microwave keeps beeping
that may be one of the setting it has like how a grandfather clock oes off every hour. could be the same thing. your going to need to read the manuel and see if that is a possible problem
Aug 07, 2009 | Microwave Ovens
Microwave blowing fuses
Sanyo isn't that great of a manufacturer.. I had a microwave from them a few years back that did the same thing.. The wiring inside the microwave is shot.. if you were to open it up, you'd probably see some burnt wires from a short. If you use the microwave over a range, it may be because of grease build-up...
anyhow, its better that you invest in a new microwave, rather than fix it. It will be much more cost efficient
Jun 02, 2009 | Sanyo EM-U1000W Microwave Oven
Active vent keeps opening and closing though fan is off.
When the unit begins the never ending opening and closing cycle, turn the vent fan on for a few seconds and then turn the fan off. This seems to stop the active vent from opening and closing. If this is GE quality, this is the last thing that I am going to purchase. GE refrigerators are garbage and now I am having problems with a new microwave oven.
Apr 27, 2009 | General Electric PVM1870SMSS Microwave...
how do you re-set microwave oven
P70D20AL-D4 is the
Apr 15, 2008 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
