Question about Sony KDS-60A2000 60" HDTV
Shuts off after couple hours off viewing then blinks red four times.
I have had this recurring problem now for a couple of months now. After a couple hours of viewing the TV makes a clicking noise then shuts itself off. The led then blinks red four times. Unplug the set and wait 30 minutes or so then plug tv back in and it will turn on. Now it ill not turn on. If I open and then slam the door shut on the right side, I think this door is for one of the lamp replacement covers, it will come back on for another couple hours of viewing. The set is out of warranty and Sony claims that this is not an issue with a lot of sets. I thought it was an overheating problem,I took off the back of the set and blew out all of the dust I could find. This did not help. The thing that puzzles me is the fact that the set will come back on after slamming the door. Anyone else either have the same problem or have any ideas on how to fix this?
It certainly sounds like a thermal problem.  I would look to the (3) cooling fans as the most likely culprit.  Since this model will normally give an error indication (blinking lights and no picture) at startup if it detects a fan failure, my guess is that there one of the fans is underperforming, but not yet completely failed.  This is commonly caused by dust/pet hair/smoking residue on the fans themselves, or in the airways that bring in fresh air and exhaust hot air.  If the set is located near a heat register, radiator, or other heat source, that could also contribute to the fault you are describing. Whatever the cause, experience tells me that no good can come from repeatedly slamming any part of a high end piece of home theatre equipment.  I would not advise continuing this practice.
Posted on Aug 20, 2008
TV turns red,shuts off, stand-by light blinking 8Times
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Feb 27, 2014 | Sony KP-51HW40 51" Rear Projection...
Panasonic Viera TC-P46S30 14 blinks
14 blinks won't occur to Panasonic Plamas. Just count the number of blinks once more.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1100 posts to different brand TVs now. Pull up older posts there.
Blinking codes for Panasonic Plasmas are described in detail. Search the site with patience. You will get a solution.
Nov 11, 2012 | Panasonic 46 TCP46S30 Plasma TV
The charger is plug in and the battery is charging so in my acer 4736 , the blue red is on as the laptop is opwer on and another light is red as the battery is charging , when battery is fulling charged...
try cycling your battery it should be done to lithium ion every couple of months. Run your computer until it shuts down from low battery. Then leave it unplugged for at least 5 hours to make sure all residual power is gone. Then fully charge the battery, this will help fix battery health issues.
May 12, 2011 | Computers & Internet
HI I have a new View Sonic DLP PJD 6221 It does not have very many hours, It turns on normally, after three to four minutes, it blinks for a few seconds and then shuts down. The red lamp light...
is the filter timer enabled. what are the total filter hours it has recorded.
is the air filter and vents clean etc.
it seems to be getting too hot as you suggest
Apr 20, 2011 | ViewSonic Office Equipment & Supplies
InFocus IN72 shuts off after 20 min.
internal error. if the lamp looks ok and it doesn't have many hours on it, it might be the power supply. the capacitors dry out and do not supply sufficient voltage. the in72s do have that problem.
Aug 27, 2009 | InFocus IN72 Multimedia Projector
Sony 60" wega kdsr50xbr1 blinks red 4 times
Please check Fans are running in your DLP Sony TV as 4 times blinks shows that any one of four fans is stopped or not running.
Feb 10, 2009 | Sony KDS-R50XBR1 50" HDTV
Toshiba 61 inch TheaterView
Happened to my tv too and i have the same one. Theres nothing you can personally do about it, you got to call someone that repairs T.V's it will cost you about $350.
Jan 05, 2008 | Televison & Video
Sony KDS-60A2000 60" HDTV Logo
63 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
