Question about KitchenAid Kitchen Ranges
We have a 30inch built in convention wall oven. After the self clean...we could get no heat. The oven turns on to 350 and then goes right down to low and never heats up. We replaced the element a few days ago but that made no diffrence in getting any heat...Oven number YKEBS107DB. The oven is 9 years old. Thank you
catriver
  • 878 Answers
SOURCE: Oven will not heat to requested temperature
Shaffy, When baking only the bake element should heat. When broiling only the broil element (upper) should heat. Your oven is a Kitchenaid, you have a 5 year warranty on any electronic element or control board. You may have a temperature sensor that is not working right. The oven just might need to be calibrated, the instructions would be in your owners manual. Your bake element might be failing, it would have to be ohmed out. You also need to verify that the bake element is getting 240V. when turned on. Catriver...post back
Posted on Sep 07, 2006
jsrock516
  • 5911 Answers
SOURCE: broiler quit
Have you checked the broil element resistance? Unplug the range and remove the back cover. Remove the wires from the broiler element and place a meter across the element posts. See if the element reads close to a short (It should read very low resistance if good). If the element reads infinite (open), you will have to replace the broil element. If the readings are normal, you may have a bad Electronic Range Control (ERC) board. The board controls the bake and broil features of the oven through two separate circuits. Usually a relay on the board goes bad. Since the ERC is considered "non-serviceable", replacement components can be hard to find. For this reason, the entire assembly is usually replaced. The ERC runs around $100 for your range, while the broil element can run anywhere from $35 to $60. Now...as far as your self-cleaning function is concerned - most electric ranges use BOTH elements to super heat the oven cavity to about 700 - 800 degrees F. With one of the elements not working, there's a good possibility the self-cleaning function will not work either Double check the items I mentioned and let me know if this helps you.
Posted on Feb 02, 2008
  • 150 Answers
SOURCE: whirlpool electric wall oven rbs305 oven
you have a thermal fuse open it is called a "T.O.D" it is located on the back of the unit or up in the top. the self clean very often pops these especially on the whirlpool units made 4-5 years ago very cheap part like $20 you can find it with the wiring diagram easy fix good luck
Posted on Apr 22, 2008
SOURCE: Oven will not heat up
same problem here. Looking for solution..
Posted on Jul 04, 2008
huuum
  • 750 Answers
SOURCE: electrolux built in wall oven,
Hello stevefer
Welcome.
You said, Your Electrolux built in wall oven, lights and digital display work fine, fan works fine, but the oven will not heat regardless of the mode (broil, bake, convention roast, convection bake)
First,
1.What is the Model Number and the year of your wall oven?
2.Did the oven light up and display with any error codes?
3. Did you try to turn the breaker off for 5 minutes to see if this will reset the system?
Perhaps the heating element is failing and may need to be replaced.
I will be able to better assist you when you reply with this information.
Waiting your response.
Huuum
Posted on Oct 16, 2008
I have a Frigidaire oven that is over heating. I turn it on to 350 and the temp goes up to 500. Were is the sensor located and am I able to change the thermostat myself???thank you,
My guess is it's in the oven box towards the top. looks like an ice pick and screws to the oven wall. Find where the wire feeds through the wall and remove the access cover behind it. It can be disconnected and checked for ohms. No model number, so replacement parts are easy to look up by model number. 25315439-zejmo41uy3tce5x43qikgza0-5-0.jpg
Dec 09, 2014 | Frigidaire Gallery 30" Self-Cleaning...
Whirlpool Built In Oven - Accubake - RB5275PD06 After self cleaning last week, the control panel is not functioning properly. For example, when we press the temp button, it won't go above 350. When...
Good Evening!
This is a common problem that Ledgestone Technologies and Fixyourboard.com can solve. The touchpad on your oven has failed and will need to be replaced. Read more about the failure and solution below. Message us if you have any questions!
info@fixyourboard.com
Whirlpool Oven Wont Increase Temperature Stuck at 350
May 27, 2017 | Whirlpool Ovens
We purchased our Frigidare Double Oven, Model Number FPET3085KFA, October 2009 (15 months ago). We ran the self-clean process for the first time yesterday on the top oven using the 4 hr option and it...
try turning your breaker off for 20 minutes, then try it again,, if this does not help it could have burnt out a element or the main board has went out,,, also make for sere you are getting the full 220 volts to the unit,, this will involve taking the unit out
Jan 19, 2011 | Frigidaire 30 in. Electric Gallery Series...
After using self cleaning feature...oven door locks up...4th time this has happened...kitchenaid says "no known issues with your unit or the problem you reported...can you halp
Hello - we have had this same issue a number of times as well. Do you lose all power on the unit too? We do - have discovered that using the self-cleaning isn't really a good idea with these ovens. The ovens aren't really made to heat to such high heats that are used in the cleaning cycle and during that last hour of cleaning it hits it highest peak - and it blows it's fuses. We recently blew 2 fuses at the same time, locking both doors (Double oven) and knocking out the power for the entire unit. Our repair man said that the average on wall ovens is anywhere between 6 - 12 cleanings before you will blow the same fuses and the whole cycle starts all over again. Our expense was $350. So, self-cleaning now means elbow grease around this house. How this information was a bit helpful for you.
Jul 02, 2010 | KitchenAid KEBC208 Electric Double Oven
I have a Thermador wall oven (POMW301/02) when bake is selected, heats up very slowly until the pre-heat light goes off. And then the oven light stays on but it doesn't hold the set temperature. While it...
Due to the nature of the self-cleaning cycle heating the oven to above normal temperatures what likely happened is that the temperature sensor went bad. The sensor is a small rod about 6 inches long and 1/4 inches wide that sits in the back of the oven. You can remove it from the back side of the oven which will need to be pulled from the wall. Replacing it should solve the problem.
Let me know how this works out for you.
Benjamin
Dec 28, 2009 | Ovens
Hello stevefer
Welcome.
First,
Huuum
Oct 16, 2008 | Kitchen Ranges
Need help
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Aug 21, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Whirlpool Electric Wall Oven RBS275PDQ6
had same problem, had computer checked out by profesisonal. Was ok. But it seems it is the control pad that clean cycle screws up. Try this (thanks to my wife and her experimental prowess). 1. turn oven on to custom broil. 2. push down temp button to 375. 3. press bake button. 4. You should now have up or down temp. We think you have to get past pre heat cycle in order for this to work. But work it does.
May 07, 2008 | Whirlpool GBD307PDS Electric Double Oven
Kitchen Ranges Logo
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
