yellow battery red accessory black ground purple right rear + speaker purple/black right rear - green left rear + green/black left rear - white fr left + white/black fr left - grey fr right + grey/black fr right - blue auto antenna blue/white rem amp brown phone mute orange/white illumination grass green handbrake but if u want to play dvd's whilst u drive connect this to earth
pls rate people arnt rating hope this helps
it sounds like you have hooked the power wires up wrong try trace back your wires with this diagram
there is a switch connected to the dvd door you should see a pin hole in the casing, a pin on the door pushes this down to say the lid is closed they are common to brake off and then the dvd play does not know the door is shut. this video should help you locate the switch https://youtu.be/ucNedtR256g
power off phone, put in sim card, power on, hit cancel key for invalid sim or secrity message, then put in restriction code 48570552 and hit enter key. your phone is ready for use. Have fun and live for free.
Sounds like the CDR deck has an issue. When the disc comes out has it's position changed i.e has it been spun at all? Can you hear any motors moving? Does it work with any type of disc ( cd/cdr/cdrw)?
Sport4320, you have to have a switch on the wire, so you can break the ground. The alternate method, which I found online, is this:
This will work with out haveing to do anything to the pink wire just
tape it and leave it alone. But the next time you unhook ur battery
cable you will have to put the code in again. Put in DVD right when the blue screen comes up hit STOP twice punch in 1,2,6, and 4 hit DOWN 1 time not 2 hit PLAY/ENTER **at this point the display became visible and i could now see the menu which made it much easier. hit DOWN one more time to change macrovision hit PLAY/ENTER hit SYS SETUP twice to save and exit menu
