Question about Haier hwr10xc6 Air Conditioner
Goldstar/air/window unit/runs for awhile and turns off
    Problem Solver:
  • 7 Answers
Does it have energy saver option? Check if you have timer option. If your units runs and then turns off without restarting by itself and you don't have those options call manufacturer or take it back and get your money back.
Posted on Aug 07, 2008
My questain is can you oil or grease the fan motor, it squeels when its running but other than that ot works fine. its a goldstar wg1005r 10,000 BTU unit?
Usually not on these types of units. If it is squealing, it will eventually seize. You could try spraying some wd-40 on the shaft when the motor is running and then turning it off and letting the wd soak for a while. Usually when wd is sprayed on a motor with bad bearings, it will loosen all the gunk up and make the motor louder than before, but I have had kill the squeal a few times. This is an at your own risk type fix as it could make the problem worse. Best option is to buy a new motor or unit. Sometimes the motor will cost a few dollars less than a brand new unit.
Aug 14, 2011 | Goldstar LG L1004R Window Air Conditioner
Where is the drain plug on this unit goldstar 6500 airconditione
There is no drain plug,if it is not draining,then the drain holes are stopped up with trash and debris,remove the unit from the window,and take it out side,use a water hose to clean it out,and you will be fine,if this was at all helpful,please rate,thank you.
Jul 05, 2010 | Goldstar KG6000R Window Air Conditioner
Have 5000BTU Goldstar window unit. Water dripping
the bottom of the case from the outside usually has a "divot" in it below the coil to allow flow from the hose that runs across the bottom of the unit, try pressuring up and "blowing out" any obstruction, if this does not work then you may have to disassemble the unit and verify the drainpan is not cracked below the indoor coil (rare)
Jul 13, 2009 | Goldstar WG5000 Air Conditioner
I have a Goldstar window unit 6500 BTU it has Cool, Fan, and Dry
in all honesty, it's a ridiculous gimmick. the system still runs the same as it would when you are using the A/C, however in Dry Mode there is a small heater in the unit which runs also, to prevent the system from lowering your room's air temp. a/c's always dehumidify air anyway, so basically dry mode is like running a/c and heat at the same time. $$$$$$.
Jun 11, 2009 | Goldstar Heating & Cooling
Way too loud
it is prob. a pipe vibration, window unit are not knowen for quiet running
May 02, 2009 | Goldstar KG6000R Window Air Conditioner
GOLDSTAR AIR CONDICION (WALL UNIT) MODEL # BG8000ERY3
Download it from the manufacture webpage and the model #.
Sep 04, 2008 | Goldstar Heating & Cooling
Goldstar Window A/C Unit Model GWHD5000
I recommend that if you have animal and you want to have the unit on all day that is fine if you have an ac unit with a thermostat and it is big enough to handle.  The unit that is in the window is ok if your home but it could cost alot if there is no thermostat because it will run and run and run.  Then if it don't cool the house enough means its not the right size.  The unit / compressor could overload and kick on and off and might not work when you get home and the house will be like a firecracker.   Best bet would be to replace it with a unit for the size needed for the apartment.  It would be effecient. if we can help further just let us know.
Jul 15, 2008 | LG Goldstar GWHD5000 wall/window Air...
Buttons
F1, F2, and F3 are the strength of the fan blowing the air conditioner. F1 circulates the least amount of air, F3 the most. I generally find that if the air conditioner isn't getting the job done on F1, F2 will do it. I typically only use F3 if I just want to circulate air fast in my place for awhile. As far as what is "better" with closed vent or open, that depends on what you want to do. If you are using air conditioning on a hot day, then vent closed is better because it will cool only air circulating in your place. Vent open will allow fresh air in from outside, and if it's a really hot day, the air conditioner might have a harder time cooling off the fresh air than the circulating air inside your place (as it's continually being cooled repeatedly by your air conditioner).
Jun 10, 2008 | Goldstar M1003R Air Conditioner
Haier hwr10xc6 Air Conditioner Logo
117 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
