Contributor
- Posted on Feb 01, 2011
Re: The brand name Samsung is in the middle of the...
Method 1
To remove your TV from Shop Mode or Store Demo Mode, follow these steps:
- Press the Volume + button on the side panel of your TV. If your TV does not have a side panel, press the Volume button on the front panel. The TV displays the volume bar.
- With the volume bar displayed on the screen immediately press and hold the MENU button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the MENU button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Note: You may want to press the INFO button on your remote again to confirm you TV is no longer in Shop Mode or Store Demo Mode.
Method 2
- Press the Volume button on your remote. The TV displays the volume bar.
Method 3
- Change your TV to the "TV" source. The TV source is the coax (RF) source. It does not matter if you do not have anything connected to this source.
- Press the MENU button.
- Use the ??² or ??¼ button to select the "Setup" portion of the menu, and then press the ENTER button.
Note: On many TVs the menu sections name is displayed on the left side of the menu and sideways.
- The "Plug & Play" option should be highlighted if it is not use the ??² or ??¼ arrow to select "Plug & Play" option, and then press ENTER.
Note: If the "Plug & Play" option is grayed out and can't be selected this means that you are not on the TV (Coax (RF)) source. Please return to step 1.
- Follow the on screen instructions. When the options comes up select "Home" instead of "Shop".
- Finish going through the plug and play option and your TV will no longer be in Shop Mode or Store Demo.
