Question about Akai LCT2721AD 27 in. LCD Television
Won't power on
The red standby led stays lit after pushing on button or using the remote.
  • iqof25 Aug 12, 2008
    Akai LCT2721TD
    Akai LCT2721AD
    Brigadier General:
  • 6,966 Answers
The red light indicates that the Akai is receiving power. Normally, if a fault has developed and detected by the built-in protection circuitry, on power up, the same red light would blink as an indication of fault. The number of blinks would point to a probable fault where further diagnosis could be initiated. This then would require familiarity with electronic components and circuitry, use of a DVM and possibly a soldering iron as well as safe practices when repairing electrical electronic devices. Access to a service manual or at the very least a schematic diagram with voltage readings is a necessity. Should you be uncomfortable, thne your best bet may be to seek the services of a qualified professional.
There are instances where the unit will not continue powering up if it detects the absence of any usable signal, cable or video.
If you are considering a DIY, foremost to check would be the standyby +5 VDC for the logic/controller circuitry. This would be in the power supply board and is always hot/on whenever the unit is plugged to the mains. The +5 s powers the remote receiver and the controller board as said. It turns the unit on by giving a go signal for the other parts of the power supply to kick in to supple the rest of the other boards.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 13, 2008
  • 4,472 Answers
Are you trying to repair this yourself or have it repaired? If you reject a persons solution you are basically rejecting their help. I will be more then happy to assist you further but what is it you are trying to do with the tv. It will need servicing one way or another.
Thanks,
Lee
Posted on Aug 12, 2008
    Genius:
  • 2,035 Answers
Try connecting to different power source and turn it on if this did not work then there is the problem with PCB board and
If you would like to attempt a DIY, you will need a service manual to guide you. You can find one here:http://servicemanuals.vstore.ca/
Good luck...
    Master:
  • 623 Answers
Buy a new one here compare price to technician
www.overstock.com/Electronics/Akai-LCT2701TD-27-inch-LCD-TV-DVD-Player-Combo/1893567/product.html
  • ritchie dempacco
    ritchie dempacco Aug 12, 2008
    there is short circuit on your board call your friendly neighborhood tv reparman
  • 10,594 Answers
Hi, most probably Power Board will be replaced. Please ask This Shop to arrange power supply board in little money. Hope they will arrange it.
  • Shahid Electronics
    Shahid Electronics Aug 12, 2008
    Check battery of remote and confirm the power button on TV as well. Try to power up tv by using channel / preset buttons, on remote and TV.
    Shahid Electronics Aug 15, 2008
    Hows your Akai LCT2721TD ? Hope problem is solved.
  • Akai Master
  • 19,396 Answers
Unplug power cable for 5 minutes and connect it back , in some case this clear the error, most likely it is a blown component on PCB board.
If hard reset does not work you will have to take the monitor to a local repair shop, or to call the phone number printed on user manual to arrange repair.
    Master:
  • 521 Answers
It is the some capacitor defective in the powersupply board get it repaired.
  • 1 more comment
  • tech expert12 Aug 12, 2008
    if you get it repaired from professional company technician you will get the warranty for it.
    if you your self get it and fix it by local engenieer there will be no warranty and it will be risk.
    Did the solutions from all of us experts solved your problem if not then let us know the current updates so all the fixya experts can assist you further.
  • tech expert12 Aug 13, 2008
  • 3,037 Answers
The light never changes to green or flashes, correct? The first source to look into for a problem is the power supply then. Make sure you unplug the tv and wait 8 hours to let it discharge especially if you don't usually work with electronics
let me know of any further questions that you have
  • Benjamin Patri
    Benjamin Patri Aug 12, 2008
    Please provide information to answer my previous questions. This is most likely not going to be an easy fix but if the light never changed colors or never blinked (or did do one of these things), please let me know. Most likely the power supply module will have to be replaced.
    Genius:
  • 1,847 Answers
Seems issue with the power supply.
  • Legin Varghese
    Legin Varghese Aug 12, 2008
    I
    figured out that if i unplug the set then plug it back in it worked. We
    did that for about 2 weeks. Then one day nothing, no matter how long I
    left it unplugged.
    My tv is 18mos. old out of warranty and Polaroid refuses to do anything
    about. I am extremely upset because I know that this is a manufacturing defect.
    This may or may not work for other Polaroid models I have no idea. Here is a picture of my info.
    Anyway here is how i fixed my set.
    Total parts cost $5.12
    This has worked for me, I am no technician so I can't say that it will work for you. Click here for information on caps. Or here
    If you try this it is at your own risk!
    Defective Parts:2 CapXon 1000uf 10v caps.
    Replaced Parts:2 Off brand 1000uf 16v caps. (the closest match my local supplier had.)
    Once unplugged and flipped over I removed these three screws to access the control box.
    Carefully pry up and pull back on the vented cover.
    With the cover off I removed 3 more screws and again carefully pryed up on the control box cover to expose the inside.
    Circled is the location of the bad caps. (This is an after picture. I didn't take any pictures of the caps still on the board.)
    Press your index finger over the tops of the 2 caps and feel for a bulge. Good caps should be sunken in. Bad caps ballooned.
    These are mine removed
    In order to de-solder
    your caps you must unplug all connectors and remove the 4 screws
    holding down the board. Be very careful!, and only touch the sides of
    the board. Wear an anti-static band also.
    Once removed pull of the plastic shield underneath the board. Be careful and save it, YOU MUST PUT IT BACK.
    Carefully de-solder the old caps. Replace with new caps.
    Note the polarity This is very important! On the board look for the + sign. That is your positive. The longer lead should go here. Take your time and verify This step.
    CLICK HERE FOR CAPACITOR POLARITY
    (sorry no pics on the cap removal and install I wasn't positive that this would work so I didn't think about taking any.)
    Reverse the procedure to put your set back together.
    Now plug it up and hope it works for another year!
Preamp stuck in standby mode
a flaslight bulb and batteries and couple of wires can be used to make a continuity tester.and also pls check the small pushbutton(power button)try the remote if theres any
Feb 04, 2014 | Adcom GFP-710 2-Channel Amplifier
Sony KDL-40S20L1 Flashing Standby Led, No pic, No Sound
try some of the solutions on this link hope one will work for you. http://www.docs.sony.com/release/KDL32S20L1.pdf look under troubleshooting for no picture good luck
Aug 25, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Wii remote won't sync
  1. Press the Power button on the Wii console to turn it on.
  2. Remove the battery cover on the back of the Wii Remote to be synced. Open the SD Card Slot cover on the front of the Wii console.
  3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED on the front of the Wii Remote will blink. While the lights are still blinking, quickly press and release the red SYNC button on the front of the Wii console.
  4. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
  5. This sync procedure must be followed for each additional Wii Remote added to the system.
Mar 08, 2012 | Nintendo Video Game Consoles & Games
I have a 56' that wont show picture
Power board is bad.. I had the same issue.
Apr 13, 2010 | Samsung HL-S5679W 56" HDTV
I bought my son a 19" philips tv model # 19pfl340d/27.in order to turn tv on it must be unplugged for 10-15 minutes.The first one I bought did the same thing and I returned it.this one is exactly the...
The remote control will not operate the TV when the TV is in the OFF mode (No LED lit on front bezel). To change the mode from OFF to STANDBY or ON, press the POWER button on the side of the TV. Once the POWER button is pressed, the LED will change to either red to indicate STANDBY or green to indicate ON, whichever mode the TV was in prior to being turned off with the TV POWER button.
By pressing the POWER button on the side of the TV, the mode will toggle from OFF to either STANDBY or ON. If the POWER button is pressed and then the LED on the bezel is red, the TV is in STANDBY mode and will need to be turned on using the remote control. If the POWER button is pressed and then the LED on the bezel is green, the TV is ON.
Nov 11, 2009 | Philips 19PFL3403D/27 19 in. LCD TV
I have a 56" samsung rear projection tv that won't turn on. the red standby light is lit and when i push the power i hear two clicks and the green timer light flashes quickly then the green led stays lit...
I suspect you probably have a bad LED assembly. It could be either the red, green or blue that is bad and give you the same symptom. The problem is locating parts for it as it looks like the light engine is no longer available. I would have a technician look at the TV to verify this and what parts are needed for repair.
Nov 03, 2009 | Samsung HL-S5679W 56" HDTV
Nad c350 no power at all
check your output stage for bad speakers cable or bare wire of cable touch the body of amp----short circuit speaker cable----bad speaker it self------ bad input cable or defective input device .
disconnect all and check if it is ok---start to connect one by one from input to outputs------if all above failed you must contact service center for help.
Aug 22, 2008 | NAD C320 2-Channel Amplifier
Flashing light - video going out
When you push Power Button on remote, TV goes to Standby state i.e its power light (LED) lit but no picture / no sound. Power button on remote has symbol looks like.. ( ! )
Aug 14, 2008 | Sony KP-53HS10 TV
TV WILL NOT TURN ON
The power supply, and or one of the circuit board is defective. The set will require shop service.
Jerry G.
Jul 26, 2008 | Audiovox FPE3000 30 in. HD-Ready LCD...
Akai LCT2721AD 27 in. LCD Television Logo
231 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
