Question about Canon PowerShot G9 Digital Camera
White balance presets
How do I access them--thanks
  • 2,039 Answers
You cannot access white balance settings while in the Auto or a Scene mode. Set the camera to P, Av, Tv, or Manual, then press the Func/Set button. White balance should be the top icon on the left side of the LCD (usually says AWB).
Posted on Jul 21, 2008
How do you find the white balance on this camera?
This camera does not have a customizable white balance. It does have some presets -- they are:
  • Auto (default)-automatically corrects white
balance. Ideal for general picture taking.
  • Daylight-for pictures in natural lighting.
  • Tungsten-corrects the orange cast of household
light bulbs. Ideal for indoor pictures under tungsten or
halogen lighting without flash.
  • Fluorescent-corrects the green cast of fluorescent
lighting. Ideal for indoor pictures under fluorescent
To access them, press the [Menu] button and look for White Balance -- the icon is a Sun and Light Bulb symbol.
Oct 28, 2013 | Kodak EasyShare Z760 Digital Camera
I'm using my Canon 350D to shoot jewellery in a pop up "cube" and it gives a very yellow light. Is there any way to adjust the 350D for a bright white light? Many thanks Anthony
Try the various white balance settings until you find the one you're looking for. If you don't find one in the presets, you can set a manual white balance using a white sheet of paper...check your owner's manual for instructions.
Nov 12, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Unsteady White balance
You must switch to preset, push the awb button on the front to switch from auto white balance indoor to auto white balance sunlight (3200k to 5600k). This will automatically balance the camera to the approximate settings needed. For fine tuning the white balance.....
If you want to set the A and B buttons, first switch to A, then hit the Auto button by the user 1,2 3 button until you are off of auto total white auto focus auto iris mode AWB A ch will show in the viewer hit the Auto again and ATW shows, meaning Auto total white is on, and you will not have control over the white balance, it will continue to float and try to automatically balance in the middle of your footage. Once you are on AWB A ch from hitting the AUTO button, then point the camera at the white you are balancing to (of course put the white under the lighting you want to balance to) push the AWB button on the front of the camera and hold it in until the camera goes through the white balance mode and the black balance mode,...the camera will go dark while this is being done but an OK with the correct color temperature will show briefly on the screen when it is done and you can release the AWB button. Now you have set the A button to the white balance for the current lighting.
If you are going to be switching between indoor and outdoor, do the same for the B button above and set it's white balance to the exterior light color temp. that way you can just switch between A and B when you are moving fast between interior and exterior shots and have the correct color temp.
You could always leave the switch on preset, and hit the AWB button on the front to switch from 3200 to 5600, but remember not all light is either 3200 or 5600, that is why we use the A and B settings and get the White balance for the exact color temp of the space being shot in.
Jul 25, 2009 | Panasonic AG-DVX100B DV Digital Camcorder
One touch white balance
white balance... you can go through the white balance menu and change the custom to whatever temperature you want... camera 1, wb, cwb, right to change temp. you can also change the red and green on the presets by pressing right at each preset temperature.
now if you are using one touch wb, then put the wb on one touch, then in camera ready hold in the one touch button and press the shutter button while pointing to white or gray card. this is stored as one touch until one touch is done again or the camera is reset. turning off camera will not reset the custom wb.
so to access your stored one touch put wb on one touch because this stores that last white balance done
Sep 22, 2008 | Olympus EVOLT E-500 Digital Camera
White balance/color correction
can you preset the white balance using a white card or anything white can you shoot in raw format
Jul 09, 2008 | Nikon Coolpix 5700 Digital Camera
Panasonic M3500 VHS Video Camera
to go to the last preset white balance after turning of and on the cam , you should just click (but not hold ) on the whit balance switch but you have to select manual first , and if you want to set white balance then you should hold on the white balance switch for more than 4 seconds regards
Jan 20, 2007 | Panasonic NV-M3500EN Camcorder
White Balance FD71
It's in the manual for sure. There are a couple of preset WB settings in the camera. You can access these by pressing the WB button on the lens, it will change the WB setting from one to another for every press. You can also do custom WB with one push botton.
Sep 13, 2005 | Sony Mavica MVC-FD71 Digital Camera
White Balance
Color reproduction differs depending on the lighting conditions. For instance, when daylight, the setting sun or indoor lighting is reflected on white paper, the shade of white produced will be slightly different for each. By setting the WB (White Balance), you can achieve more natural-looking color. You can also preview different color tones by trying the different settings under the actual light source, and checking the result on the viewfinder and monitor. You can choose mode from Auto, Preset 1, Preset 2, Custom, One-touch, and White balance compensation.
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
Balance Function
This function is useful when you need more precise white balance than the Preset White Balance can provide. To set the optimum white balance for the shooting conditions, point the camera at a white object under the light source that you want to use, and press the OK button to set the white balance.
Sep 04, 2005 | Olympus C-7000 Zoom Digital Camera
White Balance
Color reproduction differs depending on the lighting conditions. For instance, when daylight, the setting sun or indoor lighting is reflected on white paper, the shade of white produced will be slightly different for each. By setting the WB (White Balance), you can achieve more natural-looking color. You can also preview different color tones by trying the different settings under the actual light source, and checking the result on the viewfinder and monitor. You can choose mode from Auto, Preset 1, Preset 2, Custom, and One-touch.
Sep 04, 2005 | Olympus Camedia C-5060 Wide Zoom Digital...
Canon PowerShot G9 Digital Camera Logo
185 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
