New first assembly. Brother MFC 7220. Unable to enter the drum unit assembly. Slides in but does not bottom in the unit. I am replacing a MFC 4550 which that drum unit slides in like a drawer. This feels like something is blocking the entry and I do not want to force it. It needs about 8mm futher penetration. I used a flashlight and see no foreign objects. What do I do next? I am a Prof. Eng. and reasonably adept but am missing something. Help! rwtbirchard@cogeco.ca Ron birchard
Why would I pay to start a new product? I solved the problem by forcing it into the receptical. It seems to be a poor fit but it now works
RWTB
Posted on Jul 21, 2008
MFC 7220 Brother Fax machine keeps telling me that the Drum is not working. we've moved the blue tab a million times and still nothing... it's not turning right. Are there other things that we...
I recommend replacing the drum unit with a new one. Do not forget to follow the instructions on programming the unit to recognize the new drum unit. Otherwise you will still be faced with the message to replace your drum unit.
Sep 20, 2011 | Brother MFC-7220 All-In-One Laser Printer
Unit has about 20k copies. Just replaced toner and drum. Keep getting "drum error", and tells me to take out drum and slide blue tab back and forth, which I do. Then when I put the drum back...
Install the drum unit and toner cartridge
assembly in the machine.
Press Options.
To confirm you are installing a new
drum, press 1.
When the LCD shows Accepted, close
the front cover.
If this doesnt correct it after installing the new drum return it to the store you got it from and get a new one could be defective
Jan 06, 2011 | Brother MFC-7220 All-In-One Laser Printer
My Brother MFC-7220 shows the error message "Dust
Try cleaning the drum in the toner cartridge with a soft cloth. If this does not work then a replace toner cartridge is the other solution.
Nov 26, 2010 | Brother MFC-7220 All-In-One Laser Printer
How do i reset the drum counter on the mfc 7220
Welcome to FixYa
Dear User
Open your Front Cover
In Control Panel Press Options.
You can See -Replace Drum -Yes/ No
You have to Press 1 to Reset it.Then you can Close the Cover.
Hope you did it....Thanks for Connecting FixYa..
Sep 06, 2010 | Brother MFC-7220 All-In-One Laser Printer
Need new drum for brother mfc-7220 all in one. Not even 1 year old. Is there something I can repair or fix instead of replacing the drum for about $100+ ?
If the print quality is still good, just reset the drum counter. Open the front door, press OPTION, press 1, close front door.
Oct 05, 2009 | Brother MFC-7220 All-In-One Laser Printer
Brother MFC 7220 prints vertical line from top to
The photosensitive drum needs to be cleaned or replaced. If after cleaning it the vertical line continues, the printer may need maintenance.
Sep 17, 2009 | Brother MFC-7220 All-In-One Laser Printer
I have a Brother MFC 7220 printer. When printing, there is an almost indelible, yet noticeable line down the left-center of the page. How do I get rid of it? In short, how do I clean the Brother MFC...
This could be the result of several problems. The quickest, cheapest, and easiest thing to try is to clean the "corona wire". This is done by removing the drum/toner unit. On the drum unit (the big grey cradle) is a blue tab with an arrow on it. Slide this back and forth twice, being sure that the two arrows line up when you are done. Put it back in the machine, and make a copy or print from your computer to test the quality. If this does not solve the problem, you may need a new drum (every 12,000 pages) or a new toner cartridge (about every 2,500 pages).
Apr 09, 2009 | Brother MFC-7220 All-In-One Laser Printer
Brother MFC6800-says change drum soon - is that hard to do?
yes anyone can do this, the drum is the unit the toner fits into, remove as though you were removing the toner cartridge, that the toner all the way out of the drum unit and install the old toner in the new drum and slide back into printer, again the drum unit is just the casing that your toner cartridge slips in and out of
Apr 02, 2009 | Brother MFC-7220 All-In-One Laser Printer
Printer ghosting(?) after replacing toner cartridge/drum assembly
helo braxtol! tell me, are you using brother oem toner and drum or are you using a generic brand. you could also have a bad power supply. this is what charges the drum and toner. good luck brother tech
Jan 31, 2009 | Brother MFC 7420 All-In-One Laser Printer
Reset drum - brother mfc-8860dn
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
Jan 06, 2008 | Brother MFC-8860DN Printer
48 people viewed this question
jasbo
jasbo
