Question about Intel Motherboard
Boot Issues Computer does not boot all I'm getting are some long beeps obne after the other.
    Brigadier General:
  • 8,619 Answers
Hi! What kind of beep patterns are you hearing?
Hope this might help---
1long, 2 short Video adapter error Either video adapter is bad or is not seated properly. Also, check to ensure the monitor cable is connected properly. Repeating (endless loop) Memory error Check for improperly seated or missing memory. 1long, 3short No video card or bad video RAM Reseat or replace the video card. High frequency beeeps while running Overheated CPU Check the CPU fan for proper operation. Check the case for proper air flow. Repeating High/Low CPU Either the CPU is not seated properly or the CPU is damaged. May also be due to excess heat. Check the CPU fan or BIOS settings for proper fan speed.
Posted on Dec 31, 2008
    President:
  • Intel Master
  • 1,314 Answers
Check the memory and the video.
Posted on Jul 20, 2008
2 Suggested Answers
sandrew
  • 2961 Answers
SOURCE: Computer wont boot up
when you fitted the hard drive, you must go into the bios and make sure your new hard drive is listed as it will be looking for your old one, there should be an option to press an 'F' key to detect hard drives, and also ensure the date and time is set correctly. Assuming that the new drive is the master and is set as master, unless it's a seondary drive and should be set as slave if on the same ide cable. If the hard drive is from another pc with an operating system already on it then the pc wont boot as the information already on the drive refers to another pc motherboards drivers and all the component drivers; so you will need to repair your windows operating system by way of your XP cd.
Posted on Sep 04, 2007
What if the computer has four short beeps every time and it doesn't boot up all the way
If your PC came with u manual when purchased it will tell you what the beeps mean?
usual ram has issues when beeping happens
good luck........
Aug 14, 2014 | Dell Computers & Internet
Nv53 reboot issues
over a year with the same windows installed?, first of all and most cheap solution probably, make a backup of all your info (Pics, videos, docs), be sure of having your laptop drivers and format your laptop hdd, depending on your sistem install window 7 or windows xp (Titan ue, will do it for you), then the drivers, antivirus, malware protection and a firewall, if that doesnt work maybe a loose memory, try to run some memory tests to be sure (You can find some software on the net for this purpose), try to remove the hdd from the laptop and check for virus and malware on other machine with a good and actualized antivirus using a sata/ide/usb cable this are cheap and it shouldnt be hard to find one on some electronics or computer shop... if none of this works you should take it to a tecnician. good luck.
Jun 04, 2013 | Gateway Nv53 Nv5378u 15.6" Notebook Amd...
Computer continuously reboots. I can get into the BIOS and it will stay running just fine, but it will not boot to any device. It just beeps once and restarts.
sounds like the MBR is infected with something virusy, try backing up the data you need and then repartition the main Hard drive you boot from, then format and then reload your OS and you should be fine after that.
Jul 16, 2012 | Foxconn Computers & Internet
Advent 7105 keeps beeping and boot up ?
If your computer is beeping during the boot up phase then you may have a problem with your laptop. Depending on your system model the beeps will tell you what the problem is and from there you can troubleshoot the problem. I wrote a tech article which goes over computer post issues and beep codes. Link - computer post and beep codes
Oct 28, 2011 | Advent Netbook
We have desktop xp and it is running on safemode how do we take this off
You can't take off Safe Mode, it's there for your protection. However, if you want to boot into Normal Mode, shut down the computer. When you hear the computer beep, start tapping F8 on your keyboard. Keep tapping it until you reach the Advanced Options menu. Once you've reached this, just select "Start Windows Normally".
Now it will boot you into Windows on Normal Mode, not Safe Mode.
Jan 01, 2011 | Computers & Internet
I have A dell gx270 desktop computer . i was searching on internet . Suddenly system hangs . When i restart computer it hangs on dell logo . i tried many time but it hangs on dell logo . i changed ram ,...
Firstly, make sure you installed the video card (if it has one) back into the same slot it was removed from.
If you are using on-board video, check the CPU is firmly seated into it's socket, you may have to remove the CPU fan to check this.
Next, check your RAM sticks again. Most (about 98%) of boot up issues arise from incorrectly seated ram sticks or ram sticks that have developed connection issues.
When you boot the machine, does it make any beeping noises..?
Usually, a single beep means all is ok. If you hear multiple beeps, then the bios is telling you about a possible fault and you should count the beeps for number and duration (long beeps or short beeps and how many of each and in what order)
Remove the ram and using some very fine emery cloth, gently remove any oxidisation from the contact pads to return them back to bright metal, then re install them making sure they are seated all the way down and the locking clips are fully seated too.
If you still have boot issues, I would suspect the ram sticks first and have them checked by installing them in another compatible machine, either a friends or at a repair shop.
I would suspect the board last so if the ram sticks check out as good, have a closer look at any other cards that may be installed, especially video cards and internal modems but also check out any network cards that may be installed..
If you are still not getting any display on the monitor, take the machine to a service centre or computer shop as they have the specialist equipment to check out the board electronically ( boot cards, scopes etc).
Let me know how you go and what you find..
swoop611
Dec 05, 2010 | Dell OptiPlex GX270 PC Desktop
Computer turns off then on after first boot
2 beeps is memory issues.  Either your RAM is bad or the Video card is bad.  If you are getting the BSOD, blue screen of death, then I would take out all your RAM and start it up with a single stick, so you can find out what stick is bad.  If you only have 1 stick, replace it.  I say to do the memory first, because it is the cheaper fix.
Mar 12, 2009 | Soyo P4VTE (SY-P4VTE) Motherboard
Computer boot but nothing show up on monitor
nothing, the computer just restart itself then at first nothing show up and no beep the keyboard has no power sound but i can open close the cd rom,now it boot up but with cmos error and the ddr speed get lwer from 333 to 266 and it boot just up to the boot from cd press any key part and then it hangs it did'nt boot the window xp
Jan 11, 2009 | Computers & Internet
Ibm2366
ok here it is it is a auto repair sys from lenovo
This page has automated features! You can use the automated features on this page by installing a special, free plug-in. This one-time installation will not affect your computer's performance or compromise your privacy or security. fw.gif Install the automated content plug-in
chat.gif Just relax and let Lenovo Experts Live do it for you. Buy it now! New!
Some of these steps may not apply to your computer. Test for system startup after performing each step.
Select your symptom from the following list or continue to the Need more help? section:
Mar 24, 2008 | IBM ThinkPad T30 2366 Notebook
Intel Motherboard Logo
120 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
