Question about GPS
Garmin NUVI 200W USB Port port pulled loose
I have a Garmin NUVI 200W and the USB Port has pulled loose. Its still attached but it doesn't take a charge anymore. I think spending 125 dollars to send it back to Garmin is crazy if its something I can repair myself. I'd appreciate any suggestions.
  • Anonymous Jan 21, 2009
    I have the same problem. I've had mine for almost 1 year and love it! I noticed the port was loose about a week ago. I tried holding the power cord in there and had to hold it on there hard for it to recognize it and if I held it a certain way then it was thinking it was connected to the computer when it wasn't. Now it won't stay on but maybe 5 seconds because it's not charged. :( I don't think I'll be sending mine to get it fixed either for $125 when I saw at WalMart it was only $130 brand new. I don't know what we paid for it, but if I knew this I wish I had went ahead and bought another for $100 when they were on sale. :S Oh well..
  • GPS Master
  • 2,130 Answers
The problem with repairing it yourself is that this is a surface mount connector. The solder pads are so small, it would be very difficult to solder with a standard soldering iron. Most likely you would apply too much solder and short out the connector. You really need to use a surface mount soldering/desoldering device and that can be fairly expensive. I have done this before but I have access to the right equipment.
Also, there is a possiblility that the printed circuit board tracks have been pulled up off the main board. If that has happened, there's a lot more work involved in fixing that. You might have to put in a different type of power jack and run wires from it to the main board.
If you're going to try to salvage the USB connector, I would remove it completely and install a new one. Over time, these connectors wear out, so you're better off removing the old one and putting a new one in. Again, this all depends upon whether the tracks on the board have been damaged or not.
Please let me know if I can be of further assistance to you.
Good Luck,
- Jim
You also have to know how to take apart the Nuvi.
Posted on Jul 21, 2008
  • Olivert Sep 21, 2011
    I started repairing one myself, and am finding much of what sharcnet-usa wrote to be true. I seem to have restored power but now when the charging cable is in use it seems to think that it is hooked up to a computer. Does anyone know what needs to be sent to each pin so that it doesnt think that its talking to a computer?
Stop 'computer' mode when plugging cable into usb port in car
Often caused by a loose USB port where the pins have broken away from the printed circuit board. See this page for more info:
http://www.sharc.net/gps_charger_repair.htm
Nov 25, 2015 | Garmin nuvi 200W GPS Receiver
Won't turn on
Try holding the power switch to left for 10 seconds and then release. Your USB charging port may be loose, preventing the battery and charger from supplying power to the unit.
Aug 19, 2013 | Garmin nuvi 200W GPS Receiver
My garmin nuvi 2595 lmt will not turn on, recharge, nothing but a black screen. I pressed what i think was the reset button several times but nothing. Once I heard a sound as if it was going to turn on...
Take a look at rear USB port. Insert the plug. Gently wiggle the plug. Does the USB port appear loose? A common problem with this model is that there is little mechanical support for the USB connector. If it breaks off of the printed circuit board, there battery will nit be able to be charged and the unit will appear dead. Have you tried holding down the power switch for at least 10 seconds?
Aug 14, 2013 | Garmin nuvi 200W GPS Receiver
The power and mini USB connector on my Garmin Nuvi 200 has gotten loose and it will not hold the connection through the power cord without being held by hand. Is there a repair for this?
USB connectors are too fragile for the constant in-out service they get. But I have solved the "loose USB" problem, at least for standard Type A. The plug end (its steel case slips into the port end's steel case) is functionally female; it accepts the 4-pin tongue of the port and squeezes it between the 4-pin tongue of the plug end and the steel case of the plug end. So when the plastic tongues wear down, the squeeze isn't tight enough. Solution: take a small vise-grips and make the plug's steel case a little thinner, like a weight on a grilled cheese sandwich you're making. Then when you plug it in, it will resist a bit and feel tighter. And it will now work!
Dec 29, 2010 | Garmin nuvi 200W GPS Receiver
I have just purchased a sendai universal home charger, when I plug it is my Garmin 200, and the other end into the electrical socket I get a picture on the screen, looks like a computer with a plug running...
The nuvi thinks you've connected it to the USB port of your home computer. It's charging, so pay no attention to the screen.
If you HAD connected it to the USB port, you would also see the nuvi as a storage device attached to your computer. That's how you can download pictures that you can display on your nuvi. It's also the mechanism used when you update your maps and/or software.
Apr 16, 2010 | Garmin nuvi 200W GPS Receiver
My Nuvi 200 will not charge and the USB port
My condolences. I would suggest you plug the unit in to your computer's USB port using an appropriate data cable (in case you no longer have the Garmin data cable, there are lots of devices, including cameras, that use such a cable with the large USB plug at one end and the mini-USB at the other). That would give you a handle on where the fault lies -- in the auto charger cable itself vs the nuvi's socket. If the nuvi charges from your computer, you're halfway home; if not, I suspect the cost of repairing the nuvi's USB jack could exceed the cost of a replacement unit.
Mar 16, 2010 | Garmin nuvi 200W GPS Receiver
How do you recharge the battery in the Garmin nuvi 200W GPS?
you can use the usb cable, home charger or the car charger. all of them get plugged in to the usb port on the gps
let me know if you need further help.
bill
Oct 18, 2009 | Garmin nuvi 200W GPS Receiver
Nuvi 200 froze in middle of trip reset with button on bottom and now all i get is a screen that says garmin and thats all
Use the USB cord that came with your Garmin. Plug it into the side of the Garmin and the other end into the USB port on your computer. Go to www.garmin.com. Look for downloads of your NUVI 200. Download the latest update and see if that solves the problem.
Jun 23, 2009 | Garmin nuvi 200W GPS Receiver
Broken USB Connector (Garmin nuvi 200)
USB connectors are too fragile for the constant in-out service they get. But I have solved the problem, at least for standard Type A. The plug end (its steel case slips into the port end's steel case) is functionally female; it accepts the 4-pin tongue of the port and squeezes it between the 4-pin tongue of the plug end and the steel case of the plug end. So when the plastic tongues wear down, the squeeze isn't tight enough. Solution: take a small vise-grips and make the plug's steel case a little thinner, like a weight on a grilled cheese sandwich you're making. Then when you plug it in, it will resist a bit and feel tighter. And it will now work!
Nov 20, 2008 | Garmin nuvi 200W GPS Receiver
GPS Logo
999 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
