SOURCE: Looking to disable the alarm system for a 1996 Jeep Cherokee Sport
you need to find out which wires go to what like the ones going into the alarm and the ones coming from the car u might have to put them back together..hopefully they are color coordinated for you good luck
SOURCE: Why does the car alarm keep going off? it's late-waking neighbor
what happenes when u try to start the car?also try to set and unset your arlarm. while the car is running.turn off the truck after u have turned off the arlarm that should fix that.
SOURCE: CD player on my 2004 Toyota Corolla Luna Hatchback won't work
your cd player track is misaligned youll need to replace it if you want a great deal on a new cd player or parts go to www.godspeedmotorsportsonline.comand click mobile I.C.E. tab
SOURCE: 2005 Toyota Corolla Car Alarm Problem
you may have to disconnect the battery for a minute or so ,this will reset the alarm. check your remote it does have a battery in it. otherwise you have to look for a fuse somewhere under the dash close to the fuse box.each one is diff. depending if it original toyota or aftermarket alarm.
