Power i have a magnavox 32MF605W/17 lcd hdtv. upon powering on, the power button(led) stays orange and displays no video. Please tell me what's wrong?
  • 558 Answers
Power board is damaged, most likely the capacitors are blown on the board service center could help you
Posted on Jul 22, 2008
A magnavox HDTV model 32MF605w/17. Is there a manual volume control on this set that is hidden somewhere? My remote is broken.
ok you have two different model #'s here so i went and found both pdf manuals , i assume the 32mf605w is the one you want though . but here is both
32mf605w link here , just scroll down and type the numbers shown below click download and open with adobe reader , once downloaded scroll down to page 7 , as you can see the controls are on the top of the tv
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
50ml8105d link here , scroll down to page 5 , as you can see the controls are just below the screen in the middle , probably behind a flip out or up door .
Dec 21, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Imac g5 17 gets some power but no display
Assuming you have the model with four diagnostic LEDs, the lack of LED-3 indicates that the computer and the LCD display are NOT communicating. This LED should be ON when the computer is turned on and video signal is being generated.
The first solution is to reset the PRAM (hold command-option-P-R after the boot chime until you hear another boot chime). If video does not appear, then power down the computer and reset the SMU by pressing the SMU button ONCE ONLY. (The SMU button is located just south of the fan housing and is the button further away from the fan; the other button is a power button.) If this does not fix the video, the next step is to remove the optical drive. If this does not fix the video, put everything back together and attach an external display using the dongle supplied with the unit. If the external display fails to work, you have a logic board problem; otherwise, you have an LCD panel, inverter, or cable problem.
Mar 30, 2010 | Apple iMac G5 Desktop
MAGNAVOX 32MF605W/17
Hi my name is Eric,
I hope I can help you with your issue ,
 You main a bad mainboard, a repairman will charge about $450 to replace it , use google to try and locate one yourself
If I have helped you with your issue please click accept.
If you have more questions you can still respond
I will reply asap
Thanks
Eric
Sep 26, 2009 | Philips 32MF605W Television
Magnavox 15mf605t/17 15'' LCD HDTV won't turn on
Have similar TV. If it is set to the PC source, it goes into standby when there is no signal, like a regular monitor. Even though the monitor is in standby, you can still press the Source button to change to, say, HD input, and will use the familiar on/off action when pressing Power on the remote.
A little weird, but I've gotten very used to it.
Mar 15, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
Displaying E15 in M160 all in one
Check your ink cartridges:
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 16, 2009 | Canon PIXMA MP150 All-In-One InkJet...
LED's blinking, no video
Your C5707 transistors in the monitor have failed. Suggest replacing all four with the Sanyo C5707 transistor. A common problem.
Dec 10, 2007 | Dell E173FP 17" LCD Monitor
All three LED's blinking, no video
hi, does the three lights blink only after u connect it to a display card??if yes then check if any of the connecter pins are damaged, or check out the display card..bye let me know
Dec 08, 2007 | Dell E173FP 17" LCD Monitor
Philips/Magnavox 32MF605W/17 32" LCD Wide Screen HDTV ready w/ATSC.
Yes you can. This TV has both VGA-In and component in support. The only thing you need to change is the input you're using with your remote control. As easy as changing the channel!
Oct 15, 2007 | Philips Computers & Internet
Magnavox 37" widescreen LCD HDTV
If the set has no led light on the front the proble is the power supply. If it has a blinking led please let me know how many times it blink and give me the model number thanks...
Mar 01, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Computers & Internet Logo
688 people viewed this question
David Payne
David Payne
