Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
Vienna Digital Hot water problem
The water in our machine does not warm up anymore. Can you give me a hint how / where I can get a new"boiler" for this machine. Thx.
  • freitsma Jul 20, 2008
    Thx for your fast response. The model is a Vienna Digital Model Nr. is SUP 018D. Made in Italy s/n 20014076055. I am living in Geneva Switzerland.
    Ciao, Frans.
  • freitsma Jul 21, 2008
    Mirran,
    Thx very much for your help.
    Ciao. Frans
  • 515 Answers
How old are the machine?
Do you have a mod.no?
There are two type of boiler to the machine. If you give me the mod.no then can i give you a spare part number.
Where are you from?
Posted on Jul 20, 2008
  • Mirko Blas
    Mirko Blas Jul 20, 2008
    Hi Frans,
    You can contact Saeco in Switzerland, the spare part number you need is 282058158.
    Here are the info to Saeco Switzerland:
    Saeco AG
    Nordringstrasse 9
    CH-4702 Oensingen
    Tel: +41 62 3881020
    Fax: +41 62 3881025
    E-mail: info@saeco.ch
    Visit the Web: www.saeco.ch
    Hope this can help you.
    /Mirran
Hi! One of my friends has an old Vienna Digital coffee maker (Saeco). It works fine. The only problem she has is that her coffee is never hot enough. She has to put her cup into the microwave if she...
There is a thermostat that is stuck on the boiler. I would suspect that this thermostat has either:
1- A bad contact with the boiler. Contact is assured by thermal paste
2- The thermostat is faulty and gives false readings, thus preventing the boiler to heat the water enough.
Hope this helps
Apr 09, 2011 | Saeco Vienna Digital Coffee Maker,...
How can I descale my Saeco Vienna without beans in the hopper?
Hi
Never run descaling solution through the brew unit. You should never descale the machine hot either.
1. To decalcify your boiler, remove your water tank and fill it with hot water (100 to 120 degrees). Open a pack of decalcifier and mix into the water tank. Place the tank back on the machine, then turn the machine on.
2. Open the steam knob and run approximately eight ounces of solution into a spare container. Turn the machine off and let set about 10 to 15 minutes. It is very important that the machine does not remain on to heat the boiler anymore than necessary.
3. Repeat step #2 for your type of machine. Do this until you have consumed the entire water tank of solution (approximately four to five cycles) .
4. Remove water tank and rinse it with fresh water.
5. Refill the water tank with fresh water and place it back on the machine.
6. Repeat step #2 to rinse the machine, only this time use the entire water tank at one time, and there is not need to let it set. Done, refill your tank and run some water, and you are ready to go.
Dec 02, 2010 | Saeco Vienna Deluxe 708461030122DE
I have Saeco Vienna digital coffee machine already for 7 years. It was working fine but now I have problems. Only small amount of water/coffee goes to the cup and rest (clear water) goes to the tray and...
Hi
You boiler is leaking. You need to replace the boiler. sorry. Your water hardness might be set to low if you have been descaling when it tells you to. Boilers usually last 7 to 10 years, but need to be replaced. If you need one let me know. I have some new and rebuilt boilers for that machine.
Mar 08, 2010 | Saeco Vienna Digital Coffee Maker,...
Machine will not steam
It sounds like the booster boiler is not functioning properly, either the thermostat tripped or the element is damaged.
Feb 07, 2010 | Saeco Vienna De Luxe Espresso Machine
Descale the saeco vienna not digital super aotomatic machine.
Remember, it is better to descale more often than not enough.
1. To decalcify your boiler, remove your water tank and fill it with hot water (100 to 120 degrees). Open a pack of decalcifier and mix into the water tank. Once it is dissolved, place the tank back on the machine, and then turn the machine on.
2. Open the steam knob and run approximately eight ounces of solution into a spare container. Turn the machine off and let set about 10 to 15 minutes. Longer is better. It is very important that the machine does not remain on to heat the boiler anymore than necessary.
3. Repeat step #2 for your machine. Do this until you have consumed the entire water tank of solution (approximately four to five cycles). (I do it at night before I go to bed and let the last cycle set in the boiler till morning.)
4. Remove water tank and rinse it with fresh water. Now open the knob and run the whole tank at one time to rinse.
5. Refill water tank with fresh water and place it back on the machine.
Done
Dec 24, 2009 | Saeco Vienna Espresso Machine
I've owned this saeco vienne de lux for about 3
Hi
When was the last time you descaled the machine? Scale will build up inside the boiler and insulate the water from the heating elements. The thermostat is on the outside by the heating elements so it gets hot but your water is warm. There are other things but check this first.
Nov 22, 2009 | Saeco Vienna De Luxe Espresso Machine
Only hot water comes out of the steam wand
Hi
Sounds like you might need a new steam boiler, or you may have a fuse that is blown for the steam boiler.
Oct 06, 2009 | Saeco Vienna Digital Coffee Maker,...
Takes forever to warm up
Have you decalcifyd the machine?
If there is calcium in the boiler then it takes long time to warm up and if you much calcium in it then it never be warm.
I think you have to replace the boiler on that machine:-(
May 07, 2008 | Saeco Vienna Espresso Machine
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
88 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
Mike Cairns
Mike Cairns
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
